Aerial Photography platforms
[Eric Austin] is using a Canon 7D with this RC helicopter to capture some amazing HD video. His success has manifested itself in a company that is now manufacturing these platforms ready-to-use. Take a look at their blog to see some of the hardware they’re working on, such as a tricopter and hexacopter photo platforms. We’ve also embedded a video after the break of the unit seen above and the stunning shots it’s able to grab.
Continue reading “Aerial Photography platforms” →
Mind Controlled Rovio
[youtube=http://www.youtube.com/watch?v=NNkkuMO5l7A]
[Robert] at Extremetech was going to write a review of the Emotiv EEG headset but found the bundled software lacking. He decided to write something to really show off what could be done with an EEG in your home. He is now controlling his Rovio with his mind. He had already written a new control program for the Rovio, so redoing the same program with the EEG controls would give him a great comparison. If you recall from the mind controlled TV, meditating on a single thought can be cumbersome for quick controls. Instead, he used facial expression recognition. Maybe this should be called “face controlled Rovio” instead.
Printable mecanum wheel
[Zaggo] developed a printable mecanum wheel. These are designed to allow a wheeled vehicle to move in any direction. He uses parts printed with a Makerbot along with commonly available bearings, bolts, washers, and nuts. Download the STL files need for printing and watch the assembly video after the break. We’ve also included a clip of an unrelated robot project using mecanum wheels so you can see what [Zaggo] will have once he fabricates the rest of the of the wheels. Continue reading “Printable mecanum wheel” →
Learn console hacking
This bright red handheld is [Bacteria’s] portable N64 console. We’re beginning to feel a bit saturated with N64 portable hacks, having seen one that looks like a Game Boy, another in a shiny black case, and yet another in a white case. This time around it’s not just the end product, but [Bacteria] has posted a saga discussing the build progress. Check out the 20 videos on his worklog page. If you’re looking to take existing hardware and put it into a different enclosure you should pour over this resource for ideas you can use.
Bonfire – Interactivity Using Pico Projectors And Cameras
[youtube=http://www.youtube.com/watch?v=O3MZYRAZJNk]
This video shows a demonstration of Bonfire, an additional interface for computers. It consists of a pico projector and camera hang on the back of either side of a laptop. The projector displays information on the table top and the camera monitors the area for interaction. It can recognize your hand or objects such as a smartphone or headphones and react accordingly. An accelerometer in the laptop picks up tapping (we’d guess you have to tap pretty hard) and there is also support for gestures. This was presented at 2009 UIST and unfortunately the published article is not available for free [Thanks for the link Ciflet].
We hope to see this kind of thing, as well as skin based input, come to the market some day. Until then, you’ll have to build your own.
[via Procrastineering]
Report From ESC Silicon Valley 2010
Ah, the heady aroma of damp engineers! It’s raining in Silicon Valley, where the 2010 Embedded Systems Conference is getting off the ground at San Jose’s McEnery Convention Center.
ESC is primarily an industry event. In the past there’s been some lighter fare such as Parallax, Inc. representing the hobbyist market and giant robot giraffes walking the expo. With the economy now turned sour, the show floor lately is just a bit smaller and the focus more businesslike. Still, nestled between components intended to sell by the millions and oscilloscopes costing more than some cars, one can still find a few nifty technology products well within the budget of most Hack a Day readers, along with a few good classic hacks and tech demos…
Continue reading “Report From ESC Silicon Valley 2010” →
Multiple Buttons And A Pot On one pin
[Kevin Fodor] shares his method of reading multiple inputs on one pin of a microcontroller. The analog to digital convert function of the microcontroller is used to read a potentiometer but with some careful calculations a resistor network can be built into the circuit that provides a unique voltage value for each button pushed. The only real drawback is that the system cannot read multiple button presses at the same time. Theoretically up to ten momentary push buttons can be used but [Kevin] estimates that only four plus the potentiometer will work reliably.
[Thanks Charper]
