TOBE: Tangible Out-of-Body Experience With Biosignals
TOBE is a toolkit that enables the user to create Tangible Out-of-Body Experiences, created by [Renaud Gervais] and others and presented at the TEI ’16: Tenth International Conference on Tangible, Embedded, and Embodied Interaction. The goal is to expose the inner states of users using physiological signals such as heart rate or brain activity. The toolkit is a proposal that covers the creation of a 3D printed avatar where visual representations of physiological sensors (ECG, EDA, EEG, EOG and breathing monitor) are displayed, the creation and use of these sensors based on open hardware platforms such as Bitalino or OpenBCI, and signal processing software using OpenViBE.
In their research paper, the team identified the signals and mental states which they have organized in three different types:
  • States perceived by self and others, e.g. eye blinks. Even if those signals may sometimes appear redundant as one may directly look at the person in order to see them, they are crucial in associating a feedback to a user.
  • States perceived only by self, e.g. heart rate or breathing. Mirroring these signals provides presence towards the feedback.
  • States hidden to both self and others, e.g. mental states such as cognitive workload. This type of metrics holds the most
    promising applications since they are mostly unexplored.
By visualising their own inner states and with the ability to share them, users can develop a better understating of their own selves as well others. Analysing their avatar in different contexts allows a user to see how they react in different scenarios such as stress, working or playing. When you join several users they can see how each other responds the same stimuli, for example. Continue reading “TOBE: Tangible Out-of-Body Experience With Biosignals”
Using SDR To Take Control Of Your Home Security System
[Dan Englender] was working on implementing a home automation and security system, and while his house was teeming with sensors, they used a proprietary protocol which was not supported by the open source system he was trying to implement. The problem with home automation and security systems is the lack of standardization – or rather, the large number of (often incompatible) standards used to ensure consumers get tied in to one specific system. He has shared the result of his efforts at getting the two to talk to each other via his project decode345.
The result enabled him to receive signals from Honeywell’s 5800 series of wireless products and interface them with OpenHAB — a vendor and technology agnostic open source automation software. OpenHAB offers “bindings” that allow a wide variety of systems and hardware to be integrated. Unfortunately for [Dan], this exhaustive list does not yet include support for the (not very popular) 345MHz protocol used by the Honeywell 5800 system, hence his project. Continue reading “Using SDR To Take Control Of Your Home Security System”
Security camera detecting a human
Motion Detecting Camera Recognizes Humans Using The Cloud
[Mark West] and his wife had a problem, they’d been getting unwanted guests in their garden. Mark’s solution was to come up with a motion activated security camera system that emails him when a human moves in the garden. That’s right, only a human. And to make things more interesting from a technical standpoint, he does much of the processing in the cloud. He sends the cloud a photo with something moving in it, and he’s sent an email only if it has a human in it.
Continue reading “Motion Detecting Camera Recognizes Humans Using The Cloud”
Ham Radio Trips Circuit Breakers
Arc-fault circuit breakers are a boon for household electrical safety. The garden-variety home electrical fire is usually started by the heat coming from a faulty wire arcing over. But as any radio enthusiast knows, sparks also give off broadband radio noise. Arc-fault circuit interrupters (AFCI) are special circuit breakers that listen for this noise in the power line and trip when they hear it. The problem is that they can be so sensitive that they cut out needlessly. Check out the amusing video below the break.
Our friend [Martin] moved into a new house, and discovered that he could flip the breakers by transmitting on the 20-meter band. “All the lights in the place went out and my rig switched over to battery. I thought it was strange as I was certainly drawing less than 20 A. I reset the breakers and keyed up again. I reset the breakers again and did a [expletive] Google search.” Continue reading “Ham Radio Trips Circuit Breakers”
M&Ms And Skittles Sorting Machine Is Both Entertainment And Utility
If you have OCD, then the worst thing someone could do is give you a bowl of multi-coloured M&M’s or Skittles — or Gems if you’re in the part of the world where this was written. The candies just won’t taste good until you’ve managed to sort them in to separate coloured heaps. And if you’re a hacker, you’ll obviously build a sorting machine to do the job for you.
Use our search box and you’ll find a long list of coverage describing all manner and kinds of sorting machines. And while all of them do their designated job, 19 year old [Willem Pennings]’s m&m and Skittle Sorting Machine is the bees knees. It’s one of the best builds we’ve seen to date, looking more like a Scandinavian Appliance than a DIY hack. He’s ratcheted up a 100k views on Youtube, 900k views on imgur and almost 2.5k comments on reddit, all within a day of posting the build details on his blog.
As quite often happens, his work is based on an earlier design, but he ends up adding lots of improvements to his version. It’s got a hopper at the top for loading either m&m’s or Skittles and six bowls at the bottom to receive the color sorted candies. The user interface is just two buttons — one to select between the two candy types and another to start the sorting. The hardware is all 3D printed and laser cut. But he’s put in extra effort to clean the laser cut pieces and paint them white to give it that neat, appliance look. The white, 3D printed parts add to the appeal.
Rotating the input funnel to prevent the candies from clogging the feed pipes is an ace idea. A WS2812 LED is placed above each bowl, lighting up the bowl where the next candy will be ejected and at the same time, a WS2812 strip around the periphery of the main body lights up with the color of the detected candy, making it a treat, literally, to watch this thing in action. His blog post has more details about the build, and the video after the break shows the awesome machine in action.
And if you’re interested in checking out how this sorter compares with some of the others, check out these builds — Skittles sorting machine sorts Skittles and keeps the band happy, Anti-Entropy Machine Satiates M&M OCD, Only Eat Red Skittles? We’ve Got You Covered, and Hate Blue M&M’s? Sort Them Using the Power of an iPhone!  As we mentioned earlier, candy sorting machines are top priority for hackers.
Continue reading “M&Ms And Skittles Sorting Machine Is Both Entertainment And Utility”
More Power: Powel Crosley And The Cincinnati Flamethrower
We tend to think that there was a time in America when invention was a solo game. The picture of the lone entrepreneur struggling against the odds to invent the next big thing is an enduring theme, if a bit inaccurate and romanticized. Certainly many great inventions came from independent inventors, but the truth is that corporate R&D has been responsible for most of the innovations from the late nineteenth century onward. But sometimes these outfits are not soulless corporate giants. Some are founded by one inventive soul who drives the business to greatness by the power of imagination and marketing. Thomas Edison’s Menlo Park “Invention Factory” comes to mind as an example, but there was another prolific inventor and relentless promoter who contributed vastly to the early consumer electronics industry in the USA: Powel Crosley, Jr.
Continue reading “More Power: Powel Crosley And The Cincinnati Flamethrower”
Will Your CAD Software Company Own Your Files, Too?
We’re used to the relationship between the commercial software companies from whom we’ve bought whichever of the programs we use on our computers, and ourselves as end users. We pay them money, and they give us a licence to use the software. We then go away and do our work on it, create our Microsoft Word documents or whatever, and those are our work, to do whatever we want with.
There are plenty of arguments against this arrangement from the world of free software, indeed many of us choose to heed them and run open source alternatives to the paid-for packages or operating systems. But for the majority of individuals and organisations the commercial model is how they consume software. Pay for the product, use it for whatever you want.
What might happen were that commercial model to change? For instance, if the output of your commercial software retained some ownership on the part of the developer, so for example maybe a word processor company could legally prevent you opening a document in anything but their word processor or viewer. It sounds rather unreasonable, and maybe even far-fetched, but there is an interesting case in California’s Ninth Circuit court that could make that a possibility. Continue reading “Will Your CAD Software Company Own Your Files, Too?”
