The Oscilloscope From 1943
[Thomas] comes up with some unusual gear. In his latest teardown and repair video, he has a vintage 1943 Danish oscilloscope,  a Radiometer OSG32 on the bench. It isn’t lightweight, and it certainly looks its age with a vintage cracked finish on the case. You can check out the tubes and high-voltage circuitry in the video below.
If you’ve only seen the inside of a modern scope, you’ll want to check this out with giant condensers (capacitors) and a slew of tubes. We love seeing the workmanship on these old chassis.
Continue reading “The Oscilloscope From 1943”
Dealing With The 1970s EPROM Chaos In 2025
It could be argued that erasable programmable ROMs (EPROMs) with their quaint UV-transparent windows are firmly obsolete today in an era of various flavors of EEPROMs. Yet many of these EPROMs are still around, and people want to program them. Unfortunately, the earliest EPROMs were made during a time when JEDEC standardization hadn’t taken root yet, leading to unique pinouts, programming voltages, and programming sequences, as [Anders Nielsen] explains in a recent video.
[Anders]’s Relatively Universal-ROM-Programmer project recently gained the ability to program even the oldest types of EPROMs, something which required modifying the hardware design to accommodate EPROMs like Ti’s TMS2716 and the similar-but-completely-different TMS2516. Although not the hardest thing to support – requiring just a diode and resistor added to the BOM along with a firmware update – it’s just one of those pre-standardization traps.
As [Anders] put it, it’s sometimes good to be unencumbered by the burden of future knowledge. Who would have willingly subjected themselves to the chaos of incompatible pinouts, voltages, etc., if they had known beforehand that in a few years EEPROMs and JEDEC standardization would make life so much easier? Maybe that’s why messing with retro hardware like this is fun, as afterwards you can go back to the future.
Continue reading “Dealing With The 1970s EPROM Chaos In 2025”
Picking An Old Operating System
We usually at least recognize old computer hardware and software names. But [Asianometry] taught us a new one: Pick OS. This 1960s-era system was sort of a database and sort of an operating system for big iron used by the Army. The request was for an English-like query language, and TRW assigned two guys, Don Nelson and Dick Pick, to the job.
The planned query language would allow for things like “list the title, author, and abstract of every transportation system reference with the principal city ‘Los Angeles’.” This was GIM or generalized information management, and, in a forward-looking choice, it ran in a virtual machine.
Continue reading “Picking An Old Operating System”
LeRobot Brings Autonomy To Hobby Robots
Robotic arms have a lot in common with CNC machines in that they are usually driven by a fixed script of specific positions to move to, and actions to perform. Autonomous behavior isn’t the norm, especially not for hobby-level robotics. That’s changing rapidly with LeRobot, an open-source machine learning framework from the Hugging Face community.
The SO-101 arm is an economical way to get started.
If a quick browse of the project page still leaves you with questions, you’re not alone. Thankfully, [Ilia] has a fantastic video that explains and demonstrates the fundamentals wonderfully. In it, he shows how LeRobot allows one to train an economical 3D-printed robotic arm by example, teaching it to perform a task autonomously. In this case, the task is picking up a ball and putting it into a cup.
[Ilia] first builds a dataset by manually operating the arm to pick up a ball and place it in a cup. Then, with a dataset consisting of only about fifty such examples, he creates a machine learning model capable of driving the arm to autonomously pick up a ball and place it in a cup, regardless of where the ball and cup actually are. It even gracefully handles things like color changes and [Ilia] moving the cup and ball around mid-task. You can skip directly to 34:16 to see this autonomous behavior in action, but we do recommend watching the whole video for a highly accessible yet deeply technical overview.
Continue reading “LeRobot Brings Autonomy To Hobby Robots”
A hand holds a charcoal-colored rectangle with a black and white screen in taking up most of its face. A bulleted list of items are displayed: "Start work on new blog, Update eSticky FW, Start working on eSticky PCB, New enclosure for eSticky, Buy 18650 battery, Buy 3DP extruder anycubic, FW Update Sigma 18-35."
ESticky Is A Paperless Post-It
E-paper screens have opened up a wide variety of novel use cases that just wouldn’t work with the higher power draw of an LCD. [gokux] thought it would be perfect for a digital sticky note.
Using a Waveshare 2.9″ e-paper display hooked up to a Seeed Studio XIAO ESP32C3, a battery, and a switch all inside the 3D printed enclosure, the part count on this is about as simple as it gets. Once everything is soldered together and programmed, you get a nifty little display that can hold some of your thoughts without having to reopen an app to get to them.
Access is currently provided via a web page, and there are a few minor hiccups like text alignment and image upload support. This project is open source, so [gokux] has expressed interest in anyone wanting to help refine the concept. We think it might be nice to add a magnet on the back for an easier way to actually stick to things.
If you prefer a different way to use electricity for a sticky note, why not do it at 2,000 V? If that’s not your jam, how about a plotter that writes your label or message on masking tape?
Continue reading “ESticky Is A Paperless Post-It”
Who Is Your Audience?
Here at Hackaday HQ, we all have opinions about the way we like to do things. And no surprise, this extends to the way we like to lay out circuits in schematics. So when we were discussing our own takes on this piece on suggested schematic standards, it was maybe more surprising how much we did agree on than how much we had different preferred styles. But of course, it was the points where we disagreed that provoked the most interesting discussion, and that’s when I had a revelation.
Besides torturing electronics, we all also write for you all, and one thing we always have in mind is who we’re writing for. The Hackaday audience, not to blow you up, is pretty knowledgeable and basically “full-stack” in terms of the hardware/software spectrum. This isn’t to say that everyone is a specialist in everything, though, and we also have certain archetypes in mind: the software type who is just starting out with hardware, the hardware type who isn’t as savvy about software, etc. So, back to schematic layout: Who is your audience? It matters.
For instance, do you organize the pinout for an IC by pin number or by pin function, grouping the power pins and the ADC pins and so on? If your audience is trying to figure out the circuit logic, you should probably go functional. But if you are trying to debug a circuit, you’re often looking at the circuit diagram to figure out what a given pin does, and the pin-number layout is more appropriate.
Do you lay out the logical flow of the circuit in the schematic, or do you try to mimic the PCB layout? Again, it could depend on how your audience will be using it. If they have access to your CAD tool, and can hop back and forth seamlessly from schematic to PCB, the logical flow layout is the win. However, if they are an audience of beginners, or stuck with a PDF of the schematic, or trying to debug a non-working board, perhaps the physical layout is the right approach.
Al Williams, who has experience with projects of a much larger scale than most of us self-taught hackers, doesn’t even think that a schematic makes sense. He thinks that it’s much easier to read and write the design in a hardware description language like VHDL. Of course, that’s certainly true for IC designs, and probably also for boards of a certain complexity. But this is only true when your audience is also familiar with the HDL in question. Otherwise, you’re writing in Finnish for an audience of Spaniards.
Before this conversation, I was thinking of schematic layout as Tom Nardi described it on the podcast – a step along the way to get to the fun parts of PCB layout and then to getting the boards in hand. But at least in our open-source hardware world, it’s also a piece of the documentation, and a document that has an audience of peers who it pays to keep in mind just as much as when I’m sitting down and writing this very newsletter. In some ways, it’s the same thing.
(And yeah, I know the featured image doesn’t exactly fit the topic, but I love it anyway.)
Candle Oscillator Really Heats Things Up
As the timebase for a clock, almost anything with a periodic oscillation can be used. Traditionally, that meant a pendulum, but in our time, we’ve seen plenty of others. Perhaps none as unusual as [Tim]’s candle flicker clock, though.
Candles are known for their flickering, a property of the wick and the fuel supply that candle manufacturers have gone to great lengths to mitigate. If you bring several of them together, they will have a significant flicker, with a surprisingly consistent 9.9 Hz frequency. This is the timebase for the clock, with the capacitance of the flame being sensed by a wire connected to a CH32 microcontroller, and processed to produce the required timing.
We like this project, and consider it a shame that it’s not an entry in our One Hertz Challenge.  Oddly, though, it’s not the first candle-based oscillator we’ve seen; they can even be turned into active electronic devices.
