Editor’s Note: Over the course of nearly 300 posts, Jonathan Bennett set a very high bar for this column, so we knew it needed to be placed in the hands of somebody who could do it justice. That’s why we’re pleased to announce that Mike Kershaw AKA [Dragorn] will be taking over This Week In Security! Mike is a security researcher with decades of experience, a frequent contributor to 2600, and perhaps best known as the creator of the Kismet wireless scanner.
He’ll be bringing the column to you regularly going forward, but given the extended period since we last checked in with the world of (in)security, we thought it would be appropriate to kick things off with a review of some of the stories you may have missed.
Hacking like it’s 2009, or 1996
Hello all! It’s a pleasure to be here, and it already seems like a theme of the new year so far has bringing in the old bugs – what’s old is new again, and 2026 has seen several fixes to some increasingly ancient bugs.
Telnet
Reported on the OpenWall list, the GNU inetd suite brings an update to the telnet server (yes, telnet) that closes a login bug present since 2015 linked to environment variable sanitization.
Under the covers, the telnet daemon uses /bin/login to perform user authentication, but also has the ability to pass environment variables from the client to the host. One of these variables, USER, is passed directly to login — unfortunately this time with no checking to see what it contains. By simply passing a USER variable of “-froot”, login would accept the “-f” argument, or “treat this user as already logged in”. Instant root!
If this sounds vaguely familiar, it might be because the exact same bug was found in the Solaris telnetd service in 2007, including using the “-f” argument in the USER variable. An extremely similar bug targeting other variables (LD_PRELOAD) was found in the FreeBSD telnetd service in 2009, and other historical similar bugs have afflicted AIX and other Unix systems in the past.
Of course, nobody in 2026 should be running a telnet service, especially not exposed to the Internet, but it’s always interesting to see the old style of bugs resurface.
Glibc
Also reported on the OpenWall list, glibc — the GNU LibC library which underpins most binaries on Linux systems, providing kernel interfaces, file and network I/O, string manipulation, and most other common functions programmers expect — has killed another historical bug, present since 1996 in the DNS resolver functions which could be used to expose some locations in the stack.
Although not exploitable directly, the getnetbyaddr resolution functions could still ease in breaking ASLR, making other exploits viable.
Address Space Layout Randomization (ASLR) is a common method of randomizing where in memory a process and its data are loaded, making trivial exploits like buffer overflows much harder to execute. Being able to expose the location of the binary in memory by leaking stack locations weakens this mechanism, possibly exposing a vulnerable program to more traditional attacks.
MSHTML
In February, Microsoft released fixes under CVE-2026-21513 for the MSHTML Trident renderer – the one used in Internet Explorer 5. Apparently still present in Windows, and somehow still accessible through specific shortcut links, it’s the IE5 and Active-X gift that keeps giving, being actively exploited.
Continue reading “This Week In Security: Getting Back Up To Speed” →
