Accidental Climate Engineering With Disintegrating Satellites
For many decades humankind has entertained the notion that we can maybe tweak the Earth’s atmosphere or biosphere in such a way that we can for example undo the harms of climate change, or otherwise affect the climate for our own benefit. This often involves spreading certain substances in parts of the atmosphere in order to reflect or retain thermal solar radiation or induce rain.
Yet despite how limited in scope these attempts at such intentional experiments have been so far – with most proposals dying somewhere before being implemented – we have already embarked on a potentially planet-wide atmospheric reconfiguration that could affect life on Earth for centuries to come. This accidental experiment comes in the form of rocket stages, discarded satellites, and other human-made space litter that burn up in the atmosphere at ever increasing rates.
Rather than burning up cleanly into harmless components, this actually introduces metals and other compounds into the upper parts of the atmosphere. What the long-term effects of this will be is still uncertain, but with the most dire scenarios involving significant climate change and ozone layer degradation, we ought to figure this one out sooner rather than later.
Continue reading “Accidental Climate Engineering With Disintegrating Satellites”
AI Might Kill Us All (With Carbon Emissions)
So-called artificial intelligence (AI) is all the rage right now between your grandma asking ChatGPT how to code in Python or influencers making videos without having to hire extras, but one growing concern is where the power is going to come from for the data centers. The MIT Technology Review team did a deep dive on what the current situation is and whether AI is going to kill us all (with carbon emissions).
Probably of most interest to you, dear hacker, is how they came up with their numbers. With no agreed upon methods and different companies doing different types of processing there were a number of assumptions baked into their estimates. Given the lack of information for closed-source models, Open Source models were used as the benchmark for energy usage and extrapolated for the industry as a whole. Unsurprisingly, larger models have a larger energy usage footprint.
While data center power usage remained roughly the same from 2005 to 2017 as increases in efficiency offset the increase in online services, data centers doubled their energy consumption by 2023 from those earlier numbers. The power running into those data centers is 48% more carbon intensive than the US average already, and expected to rise as new data centers push for increased fossil fuel usage, like Meta in Louisiana or the X data center found to be using methane generators in violation of the Clean Air Act.
Technology Review did find “researchers estimate that if data centers cut their electricity use by roughly half for just a few hours during the year, it will allow utilities to handle some additional 76 gigawatts of new demand.” This would mean either reallocating requests to servers in other geographic regions or just slowing down responses for the 80-90 hours a year when the grid is at its highest loads.
If you’re interested in just where a lot of the US-based data centers are, check out this map from NREL. Still not sure how these LLMs even work? Here’s an explainer for you.
An artist's depiction of a lystrosaurus munching on a prehistoric plant. It looks kind of like a hippo with a beak. The main body of the animal is grey-ish green and it's beak is ivory with two tusks jutting out from its top jaw.
Mammalian Ancestors Shed Light On The Great Dying
As we move through the Sixth Extinction, it can be beneficial to examine what caused massive die-offs in the past. Lystrosaurus specimens from South Africa have been found that may help clarify what happened 250 million years ago. [via IFLScience]
The Permian-Triassic Extinction Event, or the Great Dying, takes the cake for the worst extinction we know about so far on our pale blue dot. The primary cause is thought to be intense volcanic activity which formed the Siberian Traps and sent global CO2 levels soaring. In Karoo Basin of South Africa, 170 tetrapod fossils were found that lend credence to the theory. Several of the Lystrosaurus skeletons were preserved in a spread eagle position that “are interpreted as drought-stricken carcasses that collapsed and died of starvation in and alongside dried-up water sources.”
As Pangea dried from increased global temperatures, drought struck many different terrestrial ecosystems and changed them from what they were before. The scientists say this “likely had a profound and lasting influence on the evolution of tetrapods.” As we come up on the Thanksgiving holiday here in the United States, perhaps you should give thanks for the prehistoric volcanism that led to your birth?
If you want to explore more about how CO2 can lead to life forms having a bad day, have a look at paleoclimatology and what it tells us about today. In more recent history, have a look at how we can detect volcanic eruptions from all around the world and how you can learn more about the Earth by dangling an antenna from a helicopter.
How Pollution Controls For Cargo Ships Made Global Warming Worse
In 2020 international shipping saw itself faced with new fuel regulations for cargo ships pertaining to low sulfur fuels (IMO2020). This reduced the emission of sulfur dioxide aerosols from these ships across the globe by about 80% practically overnight and resulting in perhaps the biggest unintentional geoengineering event since last century.
As detailed in a recent paper by [Tianle Yuan] et al. as published in Nature, by removing these aerosols from the Earth’s atmosphere, it also removed their cooling effect. Effectively this change seems to have both demonstrated the effect of solar engineering, as well as sped up the greenhouse effect through radiative forcing of around 0.2 Watt/m2 of the global ocean.
The inadvertent effect of the pollution by these cargo ships appears to have been what is called marine cloud brightening (MCB), with the increased reflectivity of said clouds diminishing rapidly as these pollution controls came into effect. This was studied by the researchers using a combination of satellite observations and a chemical transport model, with the North Atlantic, the Caribbeans and South China Sea as the busiest shipping channels primarily affected.
Although the lesson one could draw from this is that we should put more ships on the oceans burning high-sulfur fuels, perhaps the better lesson is that MCB is a viable method to counteract global warming, assuming we can find a method to achieve it that doesn’t also increase acid rain and similar negative effects from pollution.
Featured image: Time series of global temperature anomaly since 1980. (Credit: Tianle Yuan et al., Nature Communications Earth Environment, 2024)
Climate Change May Make Days Longer
For those who say there’s never enough time in a day, your wish for more time is getting granted, if ever so slightly. Scientists have now found a new source of our days getting longer — climate change.
You may have already been aware that the length of the day on Earth has been getting longer over time due to the drag exerted on our planet by our friendly neighborhood Moon. Many other factors come into play though, including the Earth’s own mass distribution. As the Earth warms and polar caps melt, the water redistributes to the Earth’s equator causing it to slow more rapidly.
In the worst-case scenario, RCP8.5, it would result in climate-related effects to planetary rotational velocity even larger than those caused by lunar tides. Under that scenario, the earth would probably be a less pleasant place to live in many other ways, but at least you’d have a little more time in your day.
While we’re talking about time, we wonder what ever happened to getting rid of Daylight Savings in the US? If you long for a simpler time, perhaps you should take up repairing mechanical watches and clocks?
The Greenhouse Effect Isn’t For Greenhouses
Think of a greenhouse. It’s a structure with glass walls that lets light in and traps heat, all for the benefit of the plants inside. As for how it works, that’s elementary! It’s all down to the greenhouse effect… right?
Alas, no. So many of us have been mislead. Let’s rexamine how we thinkĀ greenhouses work, and then explore what’s actually going on.
Continue reading “The Greenhouse Effect Isn’t For Greenhouses”
Measuring Trees Via Satellite Actually Takes A Great Deal Of Field Work
Figuring out what the Earth’s climate is going to do at any given point is a difficult task. To know how it will react to given events, you need to know what you’re working with. This requires an accurate model of everything from ocean currents to atmospheric heat absorption and the chemical and literal behavior of everything from cattle to humans to trees.
In the latter regard, scientists need to know how many trees we have to properly model the climate. This is key, as trees play a major role in the carbon cycle by turning carbon dioxide into oxygen plus wood. But how do you count trees at a continental scale? You’ll probably want to get yourself a nice satellite to do the job.
Continue reading “Measuring Trees Via Satellite Actually Takes A Great Deal Of Field Work”
