80-PIC32 Cluster Does Fractals
One way to get around limitations in computing resources is to throw more computers at the problem. That’s why even cheap consumer-grade computers and phones have multiple cores in them. In supercomputing, it is common to have lots of processors with sophisticated sharing mechanisms.
[Henk Verbeek] decided to take 80 inexpensive PIC32 chips and build his own cluster programmed in — of all things — BASIC. The devices talk to each other via I2C. His example application plots fractals on another PIC32-based computer that has a VGA output. You can see a video of the device in action, below.
Continue reading “80-PIC32 Cluster Does Fractals” →
A Beacon Suitable For Tracking Santa’s Sleigh?
High-altitude ballooning is becoming a popular activity for many universities, schools and hacker spaces. The balloons, which can climb up to 40 km in the stratosphere, usually have recovery parachutes to help get the payload, with its precious data, back to solid ground safely. But when you live in areas where the balloon is likely to be flying over the sea most of the time, recovery of the payload becomes tricky business. [Paul Clark] and his team from Durham University’s Centre for Advanced Instrumentation are working on building a small, autonomous glider – essentially a flying hard drive – to navigate from 30 km up in the stratosphere to a drop zone somewhere near a major road. An important element of such a system is the locator beacon to help find it. They have now shared their design for an “Iridium 9603 Beacon” — a small Arduino-compatible unit which can transmit its location and other data from anywhere via the Iridium satellite network.
The beacon uses the Short Burst Data service which sends email to a designated mail box with its date, time, location, altitude, speed, heading, temperature, pressure and battery voltage. To do all of this, it incorporates a SAMD21G18 M0 processor; FGPMMOPA6H GPS module; MPL3115A2 altitude sensor; Iridium 9603 Short Burst Data module + antenna and an LTC3225 supercapacitor charger. Including the batteries and antenna, the whole thing weighs in at 72.6 g, making it perfectly suited for high altitude ballooning. The whole package is powered by three ‘AAA’ Energizer Ultimate Lithium batteries which ought to be able to withstand the -56° C encountered during the flight. The supercapacitors are required to provide the high current needed when the beacon transmits data.
The team have tested individual components up to 35 km on a balloon flight from NASA’s Columbia Scientific Balloon Facility and the first production unit will be flown on a much smaller balloon, launched from the UK around Christmas. The GitHub repository contains detailed information about the project along with the EagleCAD hardware files and the Arduino code. Now, if only Santa carried this on his Sleigh, it would be easy for NORAD to track his progress in real time.
A DIY Net Gun To Catch Whatever You Want
Suspicious drones hovering about your property? Burglars or other ne’er-do-well test subjects giving you trouble? Need to catch a dog that keeps meandering through your workshop? [William Osman] suggests you build yourself a pneumatic net gun that can shoot 20-30 feet to catch them all.
The net gun is built largely out of PVC pipe; the air tank — filled via a tire valve — uses adapter fittings to shrink it down to a 1″ sprinkler valve, with an air gun to act as a trigger. The net launcher is made of four lengths of pipe bent with the use of a heat gun — an Occam’s Razor solution compared to his first attempt — and is coupled to the end, while the net loads in using wooden dowels with washers as weights. It won’t trap any large game, but it will certainly net you some fun.
Continue reading “A DIY Net Gun To Catch Whatever You Want” →
Portable Apple II On An AVR
The Apple II was one of the first home computers. Designed by Steve “Woz” Wozniak, it used the MOS technologies 6502 processor, an 8-bit processor running at about 1 MHz. [Maxstaunch] wrote his bachelor thesis about emulating the 6502 in software on an AVR1284 and came up with a handheld prototype Apple II with screen and keyboard.
pic_15
Prototype on veroboard
Originally, [maxstrauch] wanted to build an NES, which uses the same 6502 processor, but he calculated the NES’s Picture Processing Unit would be too complicated for the AVR, so he started on emulating the Apple II instead. It’s not quite there – it can only reference 12K of memory instead of the 64K on the original, so hi-res graphic mode, and therefore, many games, won’t work, but lo-res mode works as well as BASIC (both Integer BASIC and Applesoft BASIC.)
[Maxstrauch] details the 6502 in his thesis and, in a separate document, he gives an overview of the project. A third document has the schematic he used to build his emulator. His thesis goes into great detail about the 6502 and how he maps it to the AVR microcontroller. The build itself is pretty impressive, too. Done on veroboard, the build has a display, keyboard and a small speaker as well as a micro SD card for reading and storing data. For more 6502 projects, check out the Dis-Integrated 6502 and also, this guide to building a homebrew 6502.
Continue reading “Portable Apple II On An AVR” →
Samy Kamkar Illustrates How To Be A Hardware Hacker
Samy Kamkar is well known for many things, but lately it has been his hardware security hacks that have been turning heads. The nice thing to know is that, despite not having a background in hardware, Samy is able to run with the best of hardware researchers. At the Hackaday SuperConference he offered words of advice for anyone trying to walk the path of discovery with an exciting new piece of electronics. One might say it’s a crash-course in how to be a hardware hacker.
Continue reading “Samy Kamkar Illustrates How To Be A Hardware Hacker” →
How Has Amazon Managed To Make Hackers Love Alexa?
Our hackspace has acquired an Amazon Dot, courtesy of a member. It mostly seems to be used as a source of background music, but it has also spawned a seemingly never-ending new entertainment in which the hackspace denizens ceaselessly bait their new electronic companion with ever more complex and esoteric requests. From endless rephrasing and careful enunciation of obscure early reggae artists to try to settle a musical argument to hilarious mis-hearing on the part of our silicon friend, the fun never stops. “Alexa, **** off!” it seems results in “I’m sorry, I can’t find a device of that name on this network”.
amazon-dot-always-listeningThat is just the experience of one hackspace, but it evidently does not end there. Every other day it seems that new projects using Alexa pass through the Hackaday timeline, so it looks as though Amazon’s online personal assistant has been something of a hit within our community.
Fair enough, you might say, we’re always early adopters of any new technology. But it’s a development over which I wonder; am I alone in finding it surprising? It’s worth taking a moment to look at the subject.
Continue reading “How Has Amazon Managed To Make Hackers Love Alexa?” →
Password-Free Guest WiFi From Raspberry Pi
Anytime you’re having more than a handful of people over to your place for a wild rager or LAN party (or both), you’ll generally need a way to make sure everyone can get their devices on the network. Normally, this would involve either putting your WiFi password into more phones than you can count or yelling your password across a crowded room. Neither of these options suited [NicoHood] and his partner, however, so he came up with another more secure solution to the WiFi-in-a-crowded-room problem.
He calls his project “guestwlan” and it’s set up to run on a Raspberry Pi with a touch screen. When a potential WiFi user approaches the Pi and requests access to the network, the Pi displays a QR code. Within that code is all of the information that the prospective device needs to connect to the network. For those who have already spotted the new security vulnerability that this creates, [NicoHood] has his guest WiFi on a separate local network just to make sure that even if someone nefarious can access the Internet, it would be more difficult for them to do anything damaging to his local network. As it stands, though, it’s a lot more secure than some other WiFi networks we’ve seen.
[NicoHood] also released his software on Git but it has been configured for use with Arch. He says that it would probably work in a Debian environment (which the Raspberry Pi-specific OS is based on) but this is currently untested. Feel free to give it a try and let us know how it goes.
