Rage Against The Dying Of The Light With A Raspi Night Vision Camera
One of the most interesting things about hacking is the difference between the vision we have at the beginning and the reality of we’ve built at the end. What began as a simple plan to build a night vision VR headset turned into a five-month adventure for [facelessloser] that culminated in this great-looking camera. He thought it would be easy, but almost every aspect presented some kind of challenge. The important thing is that he kept at it.
One of the major issues [facelessloser] encountered was power. He found that the Pi (Zero W), the screen, and the IR LEDs draw between 1.5 and 2A altogether. He was able to solve this one by using the charging board from a 2A power bank paired with a 1200mAh Li-Po built for the high draw required by vaping. If not for space issues, he might have used a 18650 or two.
Another challenge he faced was storing the video and images. He’d considered setting up the Pi as an access point to view them from a phone browser, but ultimately extended a USB port with an OTG cable to use flash drives. With a bit of Python he can watch for the drive to mount and then write to it. If the flash drive suddenly disappears, the Pi starts saving to the SD card.
There are two videos after the break, a walk through and a night vision demo. You’ll see a bit of a lag happening in the demo video—that’s because [facelessloser] is running the feed through PyGame first. No matter what nightlife you want to peep, it might be nice to add automated zoom with a rangefinder or get a closer look with some PiNoculars.
Continue reading “Rage Against The Dying Of The Light With A Raspi Night Vision Camera” →
Zigbee-Based Wireless Arduinos, Demystified
Hackday regular [Akiba] is working on a series of video tutorials guiding newbies into the world of the 802.15.4 wireless protocol stack — also known as ZigBee. So far, his tutorials include a “getting started with chibiArduino”, his own Arduino-based wireless library, as well as a more basic tutorial on how radio works.
[Akiba] already made a name for himself though a large number of wireless projects, including his Saboten sensor boards, which are ruggedized for long-term environmental monitoring. The Saboten boards use the same wireless stack as his Arduino-compatible wireless development boards, his Freakduino products. The latest version features an ATmega 1284P with 8x the RAM and 4x the flash of the older, 328P-based Freakduinos. It comes in both 900 MHz and 2.4 GHz and there’s also a special 900 Mhz “Long Range” variant. The boards include some great power-saving features, including switchable status LEDs and on-board battery regulation circuity allowing one to run a full year on two AA cells while in sleep mode. They also have a USB stick configuration that is great for Raspberry Pi projects and for running straight from the PC.
For more [Akiba] goodness, check out our colleague [Sophi]’s SuperCon interview with him as well as our coverage of his Puerto Rico lantern project.
Intellibuoy Keeps Track Of The Water
With world oceans ranging in cleanliness from pretty nasty to OMG, we need to get a handle on what exactly is going on. High School students from Hackensack, NJ built the Intellibuoy, a floating water quality sensor. The buoy has an anemometer and digital rain gauge up top, as well as a LED beacon to comply with maritime regulations.
Flotation is provided by a framework of sealed 3/4″ and 3″ PVC pipes that look strong enough to protect the electronics from a casual boat-bump. High above the water (under ideal conditions) there is the waterproof control box, packing two Arduino UNOs which listen to the sensors. A turbidity sensor measures how much silt is in the water; the other sensors measure Ph, dissolved oxygen, and temperature. The sensor pod is suspended inside a double ring of PVC for maximum protection. Each ‘Duino also has a SD card shield that stores the data of the respective sensors.
Continue reading “Intellibuoy Keeps Track Of The Water” →
Gesture Keyboard For Universal Input
Keyboards are currently the most universally accepted computer input devices. They may be wired, wireless, or virtual, but the chances are that you’re within a few centimeters of a keyboard right now. [Federico Terzi] built a prototype from an Arduino and an accelerometer which conceptually resembles writing in Palm’s old Graffiti, though this version is performed in mid-air with a handheld instead of a little square at the bottom of an LCD screen.  He can also operate wirelessly with a Bluetooth module and battery.
The task of the Arduino is to take data from the accelerometer and feed it to the computer whenever a 12mm switch is pressed. Each letter is individually learned by his Python code and scikit-learn’s Support Vector Machine. There’s nothing holding a user back from giving single-letter commands to your favorite programs. For example, it would be possible to give a thumbs-up in meatspace when you want to upvote or covering your ears could mute the audio.
We love keyboard hacks like this mechanical macro keyboard, a minimal and elegant USB Morse key(board), and Brian Benchoff’s open love-letter to mechanical keyboards.
Continue reading “Gesture Keyboard For Universal Input” →
Friday Hack Chat: Reverse Engineering The Digital Compact Cassette
For this week’s Hack Chat, we’re talking about reverse engineering the Digital Compact Cassette. Why should we care about an obsolete format that was only on the market for four years?  Because if a copy of the Spin Doctor’s Pocket Full of Kryptonite costs $50 USD on the used market, it has to be good.
In the early 1990s, several different digital magnetic tape formats came onto the scene. The MiniDisc was magneto-optical, yes, but back in the day it was amazing for recording bootlegs. DAT also appeared in the early 90s, and it was a godsend for recording studios. There was another format introduced in 1992, the Digital Compact Cassette. It was backward compatible with standard audio cassettes, an important feature, because no one would want to replace their entire cassette-based music collection with a new-fangled digital format. That would be just lunacy.
Our guest for this week’s Hack Chat will be [Jac Goudsmit], prolific creator on Hackaday.io, with projects ranging from the L-Star Software Defined 6502 Computer to a GPS Controlled FischerTechnik Clock. [Jac] grew up on a PET 2001, and in the years since he’s worked on projects ranging from motion control systems for lithography equipment, pick and place machines, and even at a Radio Shack. In this Hack Chat, he’ll be discussing the history of the Digital Compact Cassette, the behind the scenes on how stereo PCM is recorded to tape, and other topics like the difference between CS/EE careers in the Netherlands and the USA.
join-hack-chatOur Hack Chats are live community events on the Hackaday.io Hack Chat group messaging. Our Hack Chats usually happen on Fridays at Noon, so buckle up because this is going down Friday, December 1, at 12:00 PST. What time is that where you live? Who cares! Here’s a time zone converter!
Click that speech bubble to the left, and you’ll be taken directly to the Hack Chat group on Hackaday.io.
You don’t have to wait until Friday; join whenever you want and you can see what the community is talking about.
Mike Ossmann And Dominic Spill: IR, Pirates!
Mike Ossmann and Dominic Spill have been at the forefront of the recent wave of software-defined radio (SDR) hacking. Mike is the hardware guy, and his radio designs helped bring Bluetooth and ISM-band to the masses. Dominic is the software guy who makes sure that all this gear is actually usable. The HackRF SDR is still one of the best cheap choices if you need an SDR that can transmit and receive.
So what are these two doing on stage giving a talk about IR communication? Can you really turn traffic lights green by blinking lights? And can you spoof a TV remote with a cardboard cutout, a bicycle wheel, and a sparkler? What does IR have to do with pirates, and why are these two dressed up as buccaneers? Watch our video interview and find out, or watch the full talk for all of the juicy details.
Continue reading “Mike Ossmann And Dominic Spill: IR, Pirates!” →
Ask Hackaday: How On Earth Can A 2004 MP3 Player Read An SDXC Card?
What were you doing in 2004? Can you even remember 2004? Maybe it’s like the old joke about the 1960s, if you can remember it, you weren’t really there, man. Cast your mind back, [Lance Armstrong] was winning the Tour de France, and SpaceShipOne made it into space.
[Gregg Eshelman], wrote to us to say that in 2004 he bought an MP3 player. Ask your parents about them, they were what hipsters used before they had cassette tapes: portable music players that everyone thought were really cool back then, onto which music didn’t come from the Internet but had to be manually loaded from a computer.
Jokes about slightly outdated consumer electronics aside, [Gregg]’s player, a GPX MW3836, turned out to be a really good buy. Not only does it still work, it packs an unexpected bonus, it reads 64Gb SD cards when they are formatted as FAT32. This might not seem like a big deal at a cursory glance, but it’s worth considering a little SD card history.
Back when the GPX was made, the maximum capacity of an SD card was 2Gb, a figure that must have seemed huge when the standard was created, but by the middle of the last decade was starting to look a little cramped. The GPX player is designed to only read these original 2Gb cards. In the years since then there have been a couple of revisions to the standard, SDHC, and SDXC, which have given us the huge cards we are used to today. Many other devices from the 2Gb SD era, made before SDHC and SDXC existed, cannot read the modern cards, yet [Gregg]’s GPX can.
Hackaday’s readership constantly amaze us with the sheer breadth of their knowledge and expertise, so we are sure that among you reading this piece will be experts on SD card standards who can shed some light on this mystery. Why can a player designed for the original SD card standard read the much newer cards when other contemporary ones can not? [Gregg] would love to know, and now our curiosity has been whetted, so would we.
If you think you’ve heard [Gregg]’s name before, it might be for his expertise in resin casting automotive parts.
SD card image: Andreas Frank (CC BY 2.5).
