Symbolic Nixie Tubes Become Useful For Artistic Purposes
When it comes to Nixie tubes, the most common usage these days seems to be in clocks. That has people hunting for the numerical version of the tubes, which are usually paired with a couple of LEDs to make the colon in the middle of the clock. However, other Nixie tubes exist, like the IN-7, which has a whole bunch of neat symbols on it instead. [Joshua] decided to take these plentiful yet less-popular tubes and whip them up into a little art piece.
The IN-7 is a tube normally paired with the numerical IN-4 tube in instrumentation, where it displays unit symbols relevant to the number being displayed. It can display omega, +, M, pi, m, A, -, V, K, and ~.
[Joshua]’s build is simple enough. It spells the word “MAKE” in Nixie tubes as a neat sign for a makerspace. It uses “M” for Mega, “A” for Amps, “K” for Kilo for the first three letters. The fourth letter, “e”, is achieved by turning the tube 90 degrees, so the “m” for milli approximates that character. Two rows spelling “MAKE” (or “MAKe”) are assembled, powered via a small circuit which [Joshua] assembled on a custom-etched board using the toner transfer process. The electronics are all wrapped up in a neat laser-cut acrylic enclosure which was designed in Inkscape.
It’s a neat little project which makes good use of a Nixie tube that is, by and large, unloved. It also recalls us of a misspent youth, writing silly words on scientific calculators using only the available Greek characters. Meanwhile, if you’re working on your own Nixie builds, we’ve featured some neat drivers that you might just find valuable.
Continue reading “Symbolic Nixie Tubes Become Useful For Artistic Purposes” →
A vaguely boat-shaped vehicle with three wheels and a mast. It sits in a barren-looking plain with short mountains in the distance
Sailing The High Steppes
Sails typically bring to mind the high seas, but wind power has been used to move craft on land as well. Honoring this rich tradition, [Falcon Riley] and [Amber Word] decided to sail across Mongolia in “Moby the Land Sailing vessel.”
Built in a mere three days from $200 in materials they were able to scrounge up the week before, the cart served as their home for the 300 km (~186 mi) journey across the Mongolian countryside. Unsurprisingly, bodging together a sailing vessel in three days to traverse uneven terrain led to a failed weld to the front tire, but a friendly local lent a hand to get them back on the road.
Built mostly out of plywood, the fully-laden cart tipped the scales at 225 kg (500 lbs) and could still be towed by hand. Under sail, however, they managed 70 km in one particularly windy day. They covered the distance in 46 days, which isn’t the fastest way to travel by any means, but not bad given the quick build time for this house on wheels. We suspect that a more lightweight and aerodynamic build could yield some impressive results. Maybe it’s time for a new class at Bonneville?
If you want to learn to sail in your own landlocked region, maybe learn a bit first? Instead you might want to build an autonomous sailing cart or take a gander at sailing out of this world?
[Thanks to Amber for stopping by to suggest some corrections!]
A Power Supply With Ultra High Resolution Current Measurement Built In
Need to do some real fine power consumption measurements? [Gero Müller] was in that exact situation, and wasn’t happy with the expensive off-the-shelf tools for doing the job. Thus, he built his own. Meet nanoTracer.
nanoTracer measures small current draws in very high resolution.
The concept of the device is simple. It’s a power supply that measures current on a nanoampere scale, and on microsecond intervals. It can deliver from 0 to 5.125 volts in 256 steps, and up to 100 mA of current. It has a sampling bandwidth of 1 MHz, at 2 million samples per second, with effective dynamic range from 100 mA all the way down to 100 nA. For capturing microscopic changes in current draw, that’s invaluable. The device also features a UART for talking to an attached project directly, and additional pins for taking further ADC measurements where needed.
Right now, it’s at an early prototype stage, and [Gero] tells us the software is “very basic” right now. Still, it’s easy to see how this device would be very useful to anyone working to optimize power consumption on low-power projects. One wonders if there are some applications in power-based side-channel attacks, too.
We’re hoping to learn more about nanoTracer from [Gero] soon—how it was built, how it works, and what it’s really like to use. Perhaps one day down the line, the design might even become available for others that could use such a nifty tool. There’s no mucking about when you get down to nanoamps, after all. If you’ve cooked up something similar in your own lab, don’t hesitate to let us know!
Building A Sound Camera For Under $400
[Benn Jordan] had an idea. He’d heard of motion amplification technology, where cameras are used to capture tiny vibrations in machinery and then visually amplify it for engineering analysis. This is typically the preserve of high-end industrial equipment, but [Benn] wondered if it really had to be this way. Armed with a modern 4K smartphone camera and the right analysis techniques, could he visually capture sound?
The video first explores commercially available “acoustic cameras” which are primarily sold business-to-business at incredibly high prices. However, [Benn] suspected he could build something similar on the cheap. He started out with a 16-channel microphone that streams over USB for just $275, sourced from MiniDSP, and paired it  with a Raspberry Pi 5 running the acoular framework for acoustic beamforming. Acoular analyses multichannel audio and visualizes them so you can locate sound sources. He added a 1080p camera, and soon enough, was able to overlay sound location data over the video stream. He was able to locate a hawk in a tree using this technique, which was pretty cool, and the total rig came in somewhere under $400.
The rest of the video covers other sound-camera techniques—vibration detection, the aforementioned motion amplification, and some neat biometric techniques. It turns out your webcam can probably detect your heart rate, for example.
It’s a great video that illuminates just what you can achieve with modern sound and video capture. Think SIGGRAPH-level stuff, but in a form you can digest over your lunchbreak. Video after the break.
Continue reading “Building A Sound Camera For Under $400” →
Supercon 2023: Receiving Microwave Signals From Deep-Space Probes
Here’s the thing about radio signals. There is wild and interesting stuff just getting beamed around all over the place. Phrased another way, there are beautiful signals everywhere for those with ears to listen. We go about our lives oblivious to most of them, but some dedicate their time to teasing out and capturing these transmissions.
David Prutchi is one such person. He’s a ham radio enthusiast that dabbles in receiving microwave signals sent from probes in deep space. What’s even better is that he came down to Supercon 2023 to tell us all about how it’s done!
Continue reading “Supercon 2023: Receiving Microwave Signals From Deep-Space Probes” →
Photochromic Dye Makes Up This Novel Optical Memristor
Despite being much in the zeitgeist lately, we have to confess to still being a bit foggy about exactly what memristors are. The “mem” part of their name seems to be the important bit, implying a memory function, but the rest of the definition seems somewhat negotiable — enough so that you can make a memristor from a bit of photochromic dye.
Now, we’ll leave the discussion of whether [Markus Bindhammer]’s rather complex optical memory cell officially counts as a memristor to the comments below, and just go through the technical details here. The heart of this experimental device is a photochromic dye known as cis-1,2-dicyano-1,2-bis(2,4,5-trimethyl-3-thienyl)ethene, mercifully shortened to CMTE, which has the useful property of having two stable states. Transitioning from the open state to the closed state occurs when UV light shines upon it, while switching back to the closed state is accomplished with a pulse of green light. Absent the proper wavelength of light, both states are stable, making non-volatile information storage possible.
To accomplish this trick, [Markus] filled a quartz cuvette with a little CMTE-doped epoxy resin. Inside a light-tight enclosure, two lasers — one at 405 nm wavelength, the other at 532 nm — are trained on the cuvette through a dichroic mirror. On the other side of the CMTE resin, he placed a VEML7700 high-accuracy ambient light sensor. An Arduino Nano reads the light sensor and controls the lasers. Writing and erasing are accomplished by turning on the proper laser for a short amount of time; reading the state of the cell involves a carefully timed pulse from the 405 nm laser followed by a 532 nm pulse and watching the output of the sensor.
Is a one-bit memory device that uses a dye that goes for €300 per gram and a pair of laser diodes practical? Of course not, but it’s still pretty cool, and we appreciate all the effort and expense [Markus] went to with this one. Now, if you want some fuel for the “It’s not a memristor” fire, memristors might not even be a thing.
Continue reading “Photochromic Dye Makes Up This Novel Optical Memristor” →
Meet The Optical Data Format You’ve Never Heard Of Before
You consider yourself a power user. You’ve got lots of files, and damn it, you like to keep them backed up. Around a decade ago, you gave up on burning optical discs, and switched to storing your files on portable hard drives. One local, one off-site, and a cloud backup just to be sure. You’re diligent for a home gamer, and that gets you done.
The above paragraph could describe any number of Hackaday readers, but what of bigger operations? Universities, businesses, and research institutions all have data budgets far in excess of what the individual could even imagine. What might shock you is that some of them are relying on optical media—just not the kind you’ve ever heard of before. Enter Sony’s Optical Disc Archive.
Continue reading “Meet The Optical Data Format You’ve Never Heard Of Before” →
