Passive Saturation Box Is A Cheap Way To Distort Your Sound
Distortion pedals and overdrive effects usually have a bunch of lovely transistors or op-amps inside and lots of knobs and dials to tweak the sound to your personal taste. However, it’s possible to get some crunchiness in your audio signal without all that fuss, as [Simon Hutchinson] demonstrates with his $2 “analog saturation box”.
The effect is achieved quite simply by installing a pair of diodes in opposite orientations, connected from the signal path to ground. This configuration is also known as wiring diodes in “anti-parallel.” When the signal increases in amplitude beyond the diode’s forward voltage, the diode conducts and the signal’s peak is clipped off, which creates a distorted tone. Since there are two diodes, one in each orientation, both the tops and bottoms of the AC audio signal are clipped in this manner.
The amount of clipping is highly dependent on the diodes chosen and the strength of the signal you’re working with. Silicon diodes clip around 0.7 V, while germanium diodes clip at about 0.3 V, but that doesn’t give you much flexibility. You can work with this to some degree, though. You can up the minimum clipping level by stacking more diodes in series in each direction, or you can put in a potentiometer to vary your signal’s level before it hits the diodes. Really, though, this hard voltage limit is why more commonly, we use active distortion or overdrive effects that have more options for gain and level and such.
[Simon Hutchinson] does an able job of explaining the effect and demonstrates its use with some simple beats. As a passive device, it’s pretty one note—there’s no EQs to mess with the frequency response, and no ability to change anything else about the sound, either. Still, it’s interesting to hear the effect it does have on a signal, and you might just find this is all the distortion you need. If you’d rather go into full-fat distortion though, we’ve covered that too.
Continue reading “Passive Saturation Box Is A Cheap Way To Distort Your Sound”
Slide Rule By Helix
It is no secret that we like slide rules around the Hackaday bunker, and among our favorites are the cylindrical slide rules. [Chris Staecker] likes them, too, and recently even 3D printed a version. But spurred by comments on his video, he decided to try something that might be unique: a helical slide rule. You can see how it works in the video below.
With a conventional slide rule, the scale is rotated around a cylinder so that it is the same length as a much longer linear scale. However, this new slide rule bends the entire rule around a cylinder and allows the slide to move, just like a conventional slide rule. If you have a 3D printer, you can make your own.
Continue reading “Slide Rule By Helix”
A circuit board is shown, with the tip of a soldering iron applied to a piece of solder wick positioned above a pad.
Making Solder Wick Less Painful
For some people (e.g. this author) solder wick is a tool of last resort. Unfortunately, solder suckers and vacuum pumps lose most of their utility when you move from through-hole to SMD components, forcing us to use the dreaded wick. For those of us in this mindset, [nanofix]’s recent video which we’ve placed below the break on tips for solder wick could make desoldering a much less annoying experience.
Continue reading “Making Solder Wick Less Painful”
Adding Assistive Technology To A Doorbell
The advent of affordable computing over the last few decades has certainly been a boon for many people with disabilities, making it easier to access things like text-to-speech technology, automation, or mobility devices, and even going as far as making it easier to work in general by making remote work possible. Some things still lag behind, though, like user interfaces that don’t take the colorblind into account, or appliances that only use an audio cue to signal to their users. This doorbell, for example, is one such device and [ydiaeresis] is adding features to it to help their mother with some hearing issues.
The first thing up for this off-the-shelf remote doorbell is a “brain transplant” since the built-in microcontroller couldn’t be identified. There are only a few signals on this board though so an ATtiny412 made for a suitable replacement. A logic analyzer was able to decode the signals being fed to the original microcontroller, and with that the push of the doorbell can be programmed to do whatever one likes, including integrating it with home automation systems or other assistive technology. In [ydiaeresis]’s case there’s an existing LED lighting system that illuminates whenever the phone rings.
Although it would be nice if these inexpensive electronics came with the adaptive features everyone might need from them, it’s often not too hard to add it in as was the case with this set of digital calipers. To go even further, some other common technology can be used to help those with disabilities like this hoverboard modified to help those with mobility issues.
Thanks to [buttim] for the tip!
The Blackberry Keyboard: How An Open-Source Ecosystem Sprouts
What could happen when you open-source a hardware project?
No, seriously. I hold a fair few radical opinions – one is that projects should be open-source to the highest extent possible. I’ve seen this make miracles happen, make hackerdom stronger, and nourish our communities. I think we should be publishing all the projects, even if incomplete, as much as your opsec allows. I would make ritual sacrifices if they resulted in more KiCad projects getting published, and some days I even believe that gently bullying people into open-sourcing their projects can be justified. My ideal universe is one where companies are unable to restrict schematics from people getting their hardware, no human should ever hold an electronics black box, by force if necessary.
Why such a strong bias? I’ve seen this world change for the better with each open-source project, and worse with closed-source ones, it’s pretty simple for me. Trust me here – let me tell you a story of how a couple reverse-engineering efforts and a series of open-source PCBs have grown a tree of an ecosystem.
A Chain Of Blackberry Hackers
Continue reading “The Blackberry Keyboard: How An Open-Source Ecosystem Sprouts”
A Vintage ‘Scope Comes Back To Life
We’re suckers for a vintage electronic teardown here at Hackaday, and thus it’s pleasing to see [Thomas Scherrer OZ2CPU] with a 1962 AEG oscilloscope on his bench. It’s definitely seen better days, and is a single-trace 10 MHz unit of the type you might have seen in a typical general purpose electronics lab back in the day.
Pulling the cover off, and as expected there’s a row of tubes each side of the centrally mounted CRT. No printed circuits in sight, and no transistors either, though the rectifiers are selenium parts. After a clean-up it’s time to look at the tubes, and they show the metallic deposits characteristic of long operation. We’re more used to that from older televisions than test equipment,
Gently bringing the power up it looks promising, but there’s a purple glow from one of the PCL82 triode-pentodes. Replacing that and a double-triode results in a ‘scope that surprisingly, is working. It was evidently a high quality device in the first place, with components capable of lasting for over six decades.
We’ve seen more from his bench involving tubes, including this device using a magic-eye tube as the heavy lifter.
Continue reading “A Vintage ‘Scope Comes Back To Life”
