Not Repairing An Old Tape Recorder
When you think of a tape recorder, you might think of a cassette tape. However, [Michael Simpson] has an old Star-Lite small reel-to-reel tape machine. It isn’t a repair so much as a rework to make it work better. These cheap machines were never the best, although a $19 tape player back then was a luxury.
Part of the problem is that the design of the tape player wasn’t all that good to begin with. The motor runs off two C cells in parallel. When these were new in the 1960s, that would have meant conventional carbon-zinc batteries, so the voltage would have varied wildly. That didn’t matter, though, because the drive was directly to the tape reel, so the speed also varied based on how much tape was left on the reel.
The amplifier has four transistors. [Michael] decided to replace the capacitors on the unit. He noticed, too, that the volume control is in line with the microphone when recording, so even though the recording was supposedly in need of repair, it turned out to be simply a case of the volume control being turned down. Pretty impressive for a six-decade-old piece of consumer electronics.
The capacitor change-out was simple enough. Some cleaning and lubing was also in order. Did it help? You’ll have to listen and decide for yourself.
So, no real repair was in the works, but it is an interesting look back at an iconic piece of consumer tech. Tape recorders like this were an early form of social media. No kidding. If you’d rather not buy a tape recorder, you could roll your own.
Continue reading “Not Repairing An Old Tape Recorder”
When The UK’s Telephone Network Went Digital With System X
The switch from analog telephone exchanges to a purely digital network meant a revolution in just about any way imaginable. Gone were the bulky physical switches and associated system limitations. In the UK this change happened in the early 1980s, with what the Post Office Telecommunications (later British Telecom) and associated companies called System X. Along with the system’s rollout, promotional videos like this 1983 one were meant to educate the public and likely any investors on what a smashing idea the whole system was.
Although for the average person in the UK the introduction of the new digital telephone network probably didn’t mean a major change beyond a few new features like group calls, the same wasn’t true for the network operator whose exchanges and networks got much smaller and more efficient, as explained in the video. To this day System X remains the backbone of the telephone network in the UK.
To get an idea of the immense scale of the old analog system, this 1982 video (also embedded below) shows the system as it existed before System X began to replace it. The latter part of the video provides significant detail of System X and its implementation at the time, although when this video was produced much of the system was still being developed.
Thanks to [James Bowman] for the tip.
Continue reading “When The UK’s Telephone Network Went Digital With System X”
Comprehensive Test Set Released For The Intel 80286
Remember the 80286? It was the sequel to the 8086, the chip that started it all, and it powered a great number of machines in the early years of the personal computing revolution. It might not be as relevant today, but regardless, [Daniel Balsom] has now released a comprehensive test suite for the ancient chip. (via The Register)
The complete battery of tests are available on Github, and were produced using a Harris N80C286-12 from 1986. “The real mode test suite contains 326 instruction forms, containing nearly 1.5 million instruction executions with over 32 million cycle states captured,” Daniel explains. “This is fewer tests than the previous 8088 test suite, but test coverage is better overall due to improved instruction generation methods.” For now, the tests focus on the 286 running in real mode. There are no “unreal” or protected mode tests, but [Daniel] aims to deliver the in the future.
[Daniel] uses the tests with the ArduinoX86, a platform that uses the microcontroller to control and test old-school CPUs. The tests aid with development of emulators like [Daniel’s] own MartyPC, by verifying the CPU’s behavior in a cycle-accurate way.
We’ve explored some secrets of the 286 before, too. If you’ve been doing your own digging into Intel’s old processors, or anyone else’s for that matter, don’t hesitate to notify the tipsline.
[Thanks to Stephen Walters for the tip!]
The bed of a small CNC machine is shown. A plastic tub is on the bed, and in the tub is a sheet of metal under a pale green solution. In place of the spindle of the CNC, there is a rectangular orange tube extending down into the solution. A red wire runs to this tube, and a black wire runs to the sheet of metal in the tub.
Painting In Metal With Selective Electroplating
Most research on electroplating tries to find ways to make it plate parts more uniformly. [Ajc150] took the opposite direction, though, with his selective electroplating project, which uses an electrode mounted on a CNC motion system to electrochemically print images onto a metal sheet (GitHub repository).
Normally, selective electroplating would use a mask, but masks don’t allow gradients to be deposited. However, electroplating tends to occur most heavily at the point closest to the anode, and the effect gets stronger the closer the anode is. To take advantage of this effect, [ajc150] replaced the router of an inexpensive 3018 CNC machine with a nickel anode, mounted an electrolyte bath in the workspace, and laid a flat steel cathode in it. When the anode moves close to a certain point on the steel cathode, most of the plating takes place there.
To actually print an image with this setup, [ajc150] wrote a Python program to convert an image into set of G-code instructions for the CNC. The darker a pixel of the image was, the longer the electrode would spend over the corresponding part of the metal sheet. Since darkness wasn’t linearly proportional to plating time, the program used a gamma correction function to adjust times, though this did require [ajc150] to recalibrate the setup after each change. The system works well enough to print recognizable images, but still has room for improvement. In particular, [ajc150] would like to extend this to a faster multi-nozzle system, and have the algorithm take into account spillover between the pixel being plated and its neighbors.
This general technique is reminiscent of a metal 3D printing method we’ve seen before. We more frequently see this process run in reverse to cut metal.
2025 One Hertz Challenge: 555 Timer Gets A Signal From Above
One of the categories we chose for the One Hertz Challenge is “Could Have Used a 555.” What about when you couldn’t have, but did anyway? The 555 is famously easy to use, but not exactly the most accurate timer out there — one “ticking” at 1 Hz will pulse just about once per second (probably to within a millisecond, depending on the rest of the circuit), but when you need more precise timing, the 555 just won’t cut it. Not on its own, anyway.
An Allan deviation plot
Allan Deviation can be a bit confusing, but generally — lower is more accurate
This entry by [burble] shows us how the humble 555 can hold its own in more demanding systems with some help from a GPS receiver. He used the One Pulse per Second (1PPS) output from a GPS module to discipline the 1 Hz output from a 555 by modulating the control voltage with a microcontroller.
Okay, this sounds a bit like baking a cake by buying a cake, scraping all the icing off, then icing it yourself, but what better way to learn how to ice a cake? The GPS-disciplined 555 is way more accurate than a free running one — just check out that Allan Deviation plot. While the accuracy of the standard 555 begins to decrease as oscillator drift dominates, the GPS-disciplined version just keeps getting better (up to a point — it would also eventually begin to increase, if the data were recorded for long enough). Compared to other high-end oscillators though, [burble] describes the project’s accuracy in one word: “Badly.”
That’s okay though — it really is a fantastic investigation into how GPS-disciplined oscillators work, and does a fantastic job illustrating the accuracy of different types of clocks, and some possible sources of error. This project is a great addition to some of the other precision timekeeping projects we’ve seen here at Hackaday, and a very fitting entry to the competition. Think you can do better? Or much, much worse? You’ve got a few weeks left to enter!
A hand with dark skin holds a black device. The bottom is a small keyboard and touchpad. The upper half is split with a square LCD on the left and a square, pink notepad on the right. A sketch of a woman wearing a puffy jacket is on the notepad and an illustration of a woman looking through an old timey film video camera is on the screen on the left.
KeyMo Brings A Pencil To The Cyberdeck Fight
Computers and cellphones can do so many things, but sometimes if you want to doodle or take a note, pencil and paper is the superior technology. You could carry a device and a pocket notebook, or you could combine the best of analog and digital with the KeyMo.
[NuMellow] wanted a touchpad in addition to a keyboard for his portable terminal since he felt Raspbian wouldn’t be so awesome on a tiny touchscreen. With a wider device than something like Beepy, and a small 4″ LCD already on hand, he realized he had some space to put something else up top. Et voila, a cyberdeck with a small notebook for handwritten/hand drawn information.
The device lives in a 3D printed case, which made some iterations on the keyboard placement simpler, and [NuMellow] even provided us with actual run time estimates in the write-up, which is something we often are left wondering about in cyberdeck builds. If you’re curious, he got up to 7.5 hours on YouTube videos with the brightness down or 3.5 hours with it at maximum. The exposed screen and top-heaviness of the device are areas he’s pinpointed as the primary cons of the system currently. We hope to see an updated version in the future that addresses these.
If you’d like to check out some other rad cyberdecks, how about a schmancy handheld, one driven by punch cards in a child’s toy, or this one with a handle and a giant scroll wheel?
Supersonic Flight May Finally Return To US Skies
After World War II, as early supersonic military aircraft were pushing the boundaries of flight, it seemed like a foregone conclusion that commercial aircraft would eventually fly faster than sound as the technology became better understood and more affordable. Indeed, by the 1960s the United States, Britain, France, and the Soviet Union all had plans to develop commercial transport aircraft capable flight beyond Mach 1 in various stages of development.
Concorde on its final flight
Yet today, the few examples of supersonic transport (SST) planes that actually ended up being built are in museums, and flight above Mach 1 is essentially the sole domain of the military. There’s an argument to be made that it’s one of the few areas of technological advancement where the state-of-the-art not only stopped moving forward, but actually slid backwards.
But that might finally be changing, at least in the United States. Both NASA and the private sector have been working towards a new generation of supersonic aircraft that address the key issues that plagued their predecessors, and a recent push by the White House aims to undo the regulatory roadblocks that have been on the books for more than fifty years.
Continue reading “Supersonic Flight May Finally Return To US Skies”
