Recently [ETA Prime] felt a bit underwhelmed by the raw performance of his MacBook Neo when it came to running for extended periods under full load, such as when gaming. Thus the obvious solution is to mildly over-engineer a cooling solution that takes care of issues like thermal throttling.
The Apple MacBook Neo with its repurposed iPhone 16 SoC seems to have leaned hard into answering the question whether a smartphone can be a good general purpose personal computer. Ignoring the lack of I/O, it’s overall not a bad SoC for a laptop, but like when you try to push the CPU and GPU on a smartphone, they do get pretty toasty. Due to the minimalistic cooling solution in the MacBook Neo it’ll easily hit the 105°C thermal throttle limit.
Technically the ‘heatsink’ for this laptop is the aluminium case, as the SoC is coupled via a thermal pad to the case. This doesn’t leave a lot of space and the case will heat soak pretty fast, while also making retrofitting a cooling solution a challenge.
Continue reading “Water Cooling The MacBook Neo Laptop To Double Gaming Performance”
