thermostat
Arduino Thermostat Includes Vacation Mode
When [William’s] thermostat died, he wanted an upgrade. He found a few off-the-shelf Internet enabled thermostats, but they were all very expensive. He knew he could build his own for a fraction of the cost.
The primary unit synchronizes it’s time using NTP. This automatically keeps things up to date and in sync with daylight savings time. There is also a backup real-time clock chip in case the Internet connection is lost. The unit can be controlled via the physical control panel, or via a web interface. The system includes a nifty “vacation mode” that will set the temperature to a cool 60 degrees Fahrenheit while you are away. It will then automatically adjust the temperature to something more comfortable before you return home.
[William’s] home is split into three heat zones. Each zone has its own control panel including an LCD display and simple controls. The zones can be individually configured from either their own control panel or from the central panel. The panels include a DHT22 temperature and humidity sensor, an LCD display, a keypad, and support electronics. This project was clearly well thought out, and includes a host of other small features to make it easy to use.
Multiplexing Pi Cameras
The Raspberry Pi and its cool camera add-on is a great way to send images and video up to the Intertubes, but what if you want to monitor more than one scene? The IVPort can multiplex up to sixteen of these Raspi camera modules, giving the Pi sixteen different views on the world and a ridiculously high stack of boards connected to the GPIO header.
The Raspberry Pi’s CSI interface uses high-speed data lines from the camera to the CPU to get a lot of image data quickly. Controlling the camera, on the other hand, uses regular old GPIOs, the same kind that are broken out on the header. We’ve seen builds that reuse these GPIOs to blink a LED, but with a breakout board with additional camera connectors, it’s possible to use normal GPIO lines in place of the camera port GPIOs.
The result is a stackable extension board that splits the camera port in twain, allowing four Raspi cameras to be connected. Stack another board on top and you can add four more cameras. A total of four of these boards can be stacked together, multiplexing sixteen Raspberry Pi cameras.
As far as the obvious, ‘why’ question goes, there are a few interesting things you can do with a dozen or so computer controlled cameras. The obvious choice would be a bullet time camera rig, something this board should be capable of, given its time to switch between channels is only 50ns. Videos below.
Continue reading “Multiplexing Pi Cameras”
TRINKET EDC CONTEST ENTRY: Lazydoro
[Vasilis] has entered Lazydoro in the Trinket Everyday Carry Contest.  Lazydoro is designed to get him up off his backside, and walking around. Recent medical research has determined that sitting too long is a bad thing. In fact,  Dr. David Agus has been quoted by Nike as saying that sitting for several hours is as bad as smoking (wayback machine link). While we’re not exactly up on the latest medical trends, we can definitely see that getting up and walking around a bit never hurt anyone. Lazydoro will alert [Vasilis] once every 20 minutes or so to get up and stretch his legs a bit.
[Vasilis] plans to pair a Pro Trinket with an accelerometer module, specifically an ADXL377 from Analog Devices. The accelerometer will allow Lazydoro to determine if [Vasilis] has moved around. If 20 or 30 minutes go by without major movement, Lazydoro will nudge him to get up and take a walk.
Since shipping to Greece takes awhile, [Vasilis] is developing with an Arduino Uno and a ADXL345 while he waits for his parts to arrive. He’s hacked this into a wrist mounted device for testing. One thing  [Vasilis]  hasn’t figured out yet is how to alert the user to move around. A small vibrating motor would probably work – but we’d suggest electric shocks. A good zap always puts the spring in our step!
There is still plenty of time to enter the Trinket Everyday Carry Contest.  The main contest runs until January 2, but we’re having random drawings every week! Don’t forget to write a project log before the next drawing at 9pm EDT on Tuesday, December 23. You and all of the other entrants have a chance to win a Cordwood Puzzle from The Hackaday Store!
Hacklet 27 – Holiday Hacks
It’s beginning to look a lot like the holidays around here. That means it’s time for holiday hacks here on The Hacklet! This week we’re looking at the coolest festive hacks created by YOU on Hackaday.io!
xmashdrWe start with [charliex] and Cypress PSOC 4 + ESP8266 WS2812 RGB XMAS Lights. The name might be a mouthful, but the goal of the project is a simple one: Awesome Christmas lights! [Charliex] has created WiFi controllable Christmas lights. To do this, he’s utilized ARM core based PSOC4 chips from Cypress. WiFi duty is handled by the popular ESP8266 module, and the lights themselves are WS2812 addressable strips.
[charliex] really outdid himself this time, creating a complete solution from the ground up. He started with a Cypress dev board, but quickly moved to a board of his own design. The PCBs  first were milled at home, then sent out for manufacturing.
Control of the strip is via UDP through a WiFi network. [Charliex] found the strips have plenty of WiFi range to place outside his home.  The last part of the puzzle was control – which [charliex] handled in style by creating his own GUI to handle synchronizing several strips to music played on a central computer.
snowflakeNext up is [nsted] with another LED hack, Glowing Xmas Snowflake Sculpture. [Nsted] was contracted to add some extra LED bling to a sculpture. The problem was that these LEDs would be filling in gaps left in the primary interactive lighting system which ran the entire sculpture. Any time you have to meld two systems, things can get crazy. [Nsted] found this out as he added WS2812B Adafruit NeoPixel strips to the Sensacell modules already designed into the sculpture. Communications happen via RS485, with Arduino Due and Megas handling the processing. Power was a concern with this sculpture, as it was pulling over 100 amps at low voltage. Like many art installations, this was a “work down to the wire” event. Everything came together at the last-minute though, and the project was a success!
musicNext up is [Jeremy Weatherford] with Christmas Orchestra.  [Jeremy] has taken on the task of making the most epic retro electronics orchestra ever created. He’s playing Trans-Siberian Orchestra’s Wizards in Winter on four floppies, three scanners, and an ancient inkjet printer. LED strips on the moving elements add lights to the sound. An Arduino Mega with a RAMPS board controls the show. [Jeremy] had his orchestra professionally recorded both on audio and in video. We’re anxiously awaiting the final video upload so we can rock out to some old hardware!
xmaslightsFinally, we’ve got [crenn6977] with his Solar powered Christmas Light Controller. This was [crenn6977’s] entry in the The Hackaday Prize. While it didn’t take him to space, we’re sure it will bring Santa to his door. Rather than run lots of tiny solar cells for his Sun powered Christmas lights, [crenn6977] is going for a single large panel and wireless control. The nRF24L01+ is handling the wireless connectivity, while a STM32F042 ARM cortex M0 processor is the brains of the operation. Solar power demands efficient design, so [crenn6977] is digging deep into op-amp circuits to keep those LEDs running through the night, and the batteries charging through the day.
It’s just about time for us to settle our brains for a long winter’s nap, so we’ll close this edition of The Hacklet here.  As always, see you next week. Same hack time, same hack channel, bringing you the best of Hackaday.io!
Towards The Perfect Coin Flip: The NIST Randomness Beacon
Since early evening on September 5th, 2013 the US National Institute of Standards and Technology (NIST) has been publishing a 512-bit, full-entropy random number every minute of every day. What’s more, each number is cryptographically signed so that you can easily verify that it was generated by the NIST. A date stamp is included in the process, so that you can tell when the random values were created. And finally, all of the values are linked to the previous value in a chain so that you can detect if any of the past numbers in the series have been altered after the next number is published. This is quite an extensive list of features for a list of random values, and we’ll get into the rationale, methods, and uses behind this scheme in the next section, so stick around.
Continue reading “Towards The Perfect Coin Flip: The NIST Randomness Beacon”
Amateur Builds Super Deep Super Cheap Ocean Vehicle
During the summers [Doug] has been building a 75 foot sailing junk to be launched from America’s most inland port. When Oklahoma’s winter hits he heads indoors to work on an ROV that will prowl 3,000 feet below the surface. Originally building a piloted submarine, he grew bored and decided to use the sailboat as a carrier for his fleet of remote submersibles instead.
A consummate amateur, [Doug] is the first to admit how little he knows about anything and how much he enjoys the open source spirit: collaboration, cooperation and learning from others. Determination and hard work fills in everything in between.
Hackaday covered the beginnings of his ROV last winter. In the year since it has progressed from some sketches and a 10″ steel pipe turned into a pressure testing rig to a nearly-complete, 10 foot long,  custom-lathed 4″ aluminum torpedo laying on his shop table. In a bow-to-stern walk-through [Doug] shows how he is building science equipment for less than a penny on the dollar by using largely off-the-shelf imaginatively-repurposed parts or things he could fabricate himself with only a lathe and a 3d printer.
Continue after the break for a breakdown of the tech used.
Continue reading “Amateur Builds Super Deep Super Cheap Ocean Vehicle”
Yule-Inspired Tool Time With [Becky Stern]
And now for something completely different: [Becky Stern]’s musical tour of her favorite tools around the Adafruit factory is the best holiday tune we’ve heard since The Waitresses’ “Christmas Wrapping”. Of course, good tools are near and dear to us as well, and we found ourselves nodding frequently in agreement and smiling as broadly as [Billie, Ruby, and Gus], the anthropomorphic LED backup singers.
In other Adafruity news, it looks like their new Samsung SM482 pick and place machine was given the gift of eyes as big as pizza pies. What tools would you like to see under the tree, leaning against the Festivus pole, or all wrapped up a safe distance from the menorah this year? Do tell.
Continue reading “Yule-Inspired Tool Time With [Becky Stern]”
