Hackaday Prize Entry: Hands|On Gloves Speaks Sign Language
The Hands|On glove looks like it’s a PowerGlove replacement, but it’s a lot more and a lot better. (Which is not to say that the Power Glove wasn’t cool. It was bad.) And it has to be — the task that it’s tackling isn’t playing stripped-down video games, but instead reading out loud the user’s sign-language gestures so that people who don’t understand sign can understand those who do.
The glove needs a lot of sensor data to accurately interpret the user’s gestures, and the Hands|On doesn’t disappoint. Multiple flex sensors are attached to each finger, so that the glove can tell which joints are bent. Some fingers have capacitive touch pads on them so that the glove can know when two fingers are touching each other, which is important in the US sign alphabet. Finally, the glove has a nine degree-of-freedom inertial measurement unit (IMU) so that it can keep track of pitch, yaw, and roll as well as the hand’s orientation.
In short, the glove takes in a lot of data. This data is cleaned up and analyzed in a Teensy 3.2 board, and sent off over Bluetooth to its final destination. There’s a lot of work done (and some still to be done) on the software side as well. Have a read through the project’s report (PDF) if you’re interested in support vector machines for sign classification.
Sign language is most deaf folks’ native language, and it’s a shame that the hearing community can’t understand it directly. Breaking down that barrier is a great idea, and it makes a great entry in the Hackaday Prize!
Resurrecting The Retro-futuristic Poly-1
poly1clean
[Tez] has acquired and resurrected a piece of New Zealand computing history, the Poly-1. To anyone who went to school in 1980s Britain, the Poly-1 appears to be a cooler, mirror universe version of Acorn’s BBC Micro. Like the humble Beeb, the Poly-1 was designed primarily for educational use. It also used a related, but superior, microprocessor (the Motorola 6809).
However while the legacy of Acorn lives on in the ARM architecture, only a few thousand Poly-1s were ever sold and it appears to have been largely forgotten.
poly1inards
The Poly-1’s demise was likely in part due to its high price tag — around $5,000 USD — its lack of support within New Zealand, and the difficulty that the small New Zealand company had breaking into international markets: issues which eventually killed off many similar 1980s computer companies in the UK, Japan and elsewhere.
But it’s still fascinating to look back, not just in nostalgia, but in admiration of the intrepid 1980s hackers who created these beautiful machines and the dream of a world that might have been.
3D Printed Electric Longboard Courtesy Of Stratasys
[Tallaustin] worked at Stratasys as an intern this past summer. They let him know that he was welcome to use their fancy industrial printers as much as he’d like. Not to waste such an opportunity he promptly got to work and designed an electric longboard, printable for a mere $8,000.
Just in case the idea of a 3D printer that can print a whole longboard was causing envy. Here's a photo of a print delaminating inside of it half way. Just in case the idea of a 3D printer that can print a whole longboard was causing envy. Here's a photo of a print delaminating inside of it half way.
Just in case the idea of a 3D printer that can print a whole longboard was inducing acute envy. Here’s a photo of a print delaminating inside of it half way through.
[Tallaustin] is presumably tall, and confided to Reddit that he weighs in at 210 lbs. For those of us who have had the pleasure of designing for FDM 3D printing, we know that getting a skateboard one can actually skate on without it delaminating somewhere unexpected is pretty difficult if you weigh 80 lbs, 200+  is another category entirely. So it’s not surprising that his first version shattered within in moments of testing.
So, he went back to the drawing board. Since he had his pick of all of Stratasys’s most expensive and fine spools of plastic, he picked one of the expensivest and finest, Ultem 1010. Aside from adding a lot of ribbing and plastic, he also gave it a full rundown with some of SolidWorks’s simulation tools to see if there were any obvious weak points.
Six days of exceedingly expensive printing later, he had a working long board. The base holds some batteries, an ESC, and a 2.4 GHz transceiver. The back has a brushless motor that drives a pulley slotted into one of the wheels. The rest is standard skateboard hardware.
If you’d like to build it yourself he’s posted the design on Thingiverse. He was even nice enough to put together a version that’s printable on a plebeian printer, for a hundredth of the price.
Blooming Flower Lamp Will Test Your 3D Printer
[ossum] has a baby on the way. He admits that he got a bit carried away, brimming with parental excitement. What resulted is a fully articulated LED WiFi lamp that blooms and glows dramatically in the friendly confines of the oncoming baby’s room.
We’ve covered [ossum]’s work before. As usual, he started off by showing his complete mastery of Fusion360 and making the rest of us look bad. If you want to learn 360, we recommend scrobbing through his models to see how it’s done.  The base encloses an ESP8266 and a hobby servo. A clever mechanism pulls down on a stranded steel cable that runs through the stem along with some control lines for the LEDS. This opens and closes the petals. The LEDs are all held in a 3D printed frame which produces a nice even glow.
If you’d like to build one yourself, there’s a full video viewable after the break. Files are available on Thingiverse. Just make sure you tune up your printer first, this is a tough one.
Continue reading “Blooming Flower Lamp Will Test Your 3D Printer” →
64×16 LED MQTT Laundry Display
When you have an MQTT broker receiving messages, you want to be able to see them. [Xose Pérez] already had a system set up that sent him notifications, but he had a pair of 32×16 LED matrices, so he decided to make a big, bright sign to let him know when he got an important message sent to the broker.
[Xose Pérez] had already built a laundry monitor which was sending messages to an MQTT broker so he wouldn’t forget his laundry sitting in the washing machine. To communicate with the broker, he used an ESP-12. He had already ported an Arduino library for the Holtek HT1362C display drivers used by the matrices to work with his driver board.
mqtt-led-matrix-driver-boardHe wanted to try out SMD soldering so he built a custom PCB to hold the ESP-12, power supply, passive components, and a connector and he describes his methods and results. Instead of hardcoded messages, he wanted the system to be configurable and display messages coming in, not only from his laundry system, but also from other sensors. A web interface, built with jQuery and WebSockets, running on the ESP-12 allows the user to subscribe to a topic on the broker and show a customized name and value on the display when a payload is available.
All-in-all, [Xose Pérez] has posted a great tutorial in which he goes over the hardware he built, the libraries he used, SMD soldering, how he made the enclosure, and even his choice in IDE (PlatformIO). He also posted the software, board designs and enclosure models software and hardware on bitbucket. The end result is a great looking LED matrix that displays not only his laundry’s status, but also anything else he wants to from his MQTT broker.
If you want to try your hand with MQTT, the ESP8266 is a wonderful device for sensor nodes, and any Linux box (like the Raspberry Pi) makes an easy broker. Check out [Elliot Williams’] Minimal MQTT series and you will be up and running in no time.
Creating A PCB In Everything: Friends Don’t Let Friends Use Fritzing
This week, we’re continuing our Creating A PCB In Everything series, where we go through the steps to create a simple, barebones PCB in different EDA suites. We’re done with Eagle, and now it’s time to move onto Fritzing.
fritzing-logoFritzing came out of the Interaction Design Lab at the University of Applied Sciences of Potsdam in 2007 as a project initiated by Professor Reto Wettach, André Knörig and Zach Eveland. It is frequently compared to Processing, Wiring, or Arduino in that it provides an easy way for artists, creatives, or ‘makers’ to dip their toes into the waters of PCB design.
I feel it is necessary to contextualize Fritzing in the space of ‘maker movement’, DIY electronics, and the last decade of Hackaday. Simply by virtue of being an editor for Hackaday, I have seen thousands of homebrew PCBs, and tens of thousands of amateur and hobbyist electronics projects. Despite what the Fritzing’s Wikipedia talk page claims, Fritzing is an important piece of software. The story of the ‘maker movement’ – however ill-defined that phrase is – cannot be told without mentioning Fritzing. It was the inspiration for CircuitLab, and the Fritzing influence can easily be seen in Autodesk’s 123D Circuits.
Just because a piece of software is important doesn’t mean it’s good. I am, perhaps, the world’s leading expert at assessing poorly designed and just plain shitty PCBs. You may scoff at this, but think about it: simply due to my vocation, I look at a lot of PCBs made by amateurs. EE professors, TAs, or Chris Gammell might beat me on volume, but they’re only looking at boards made by students using one tool. I see amateur boards built in every tool, and without exception, the worst are always designed in Fritzing. It should be unacceptable that I can even tell they’re designed in Fritzing.
Fritzing has its place, and that place is building graphical representations for breadboard circuits. Fritzing has no other equal in this respect, and for this purpose, it’s an excellent tool. You can also make a PCB in Fritzing, and here things aren’t as great. I want to do Fritzing for this Creating A PCB In Everything series only to demonstrate how bad PCB design can be.
For the next few thousand words, I am going to combine a tutorial for Fritzing with a review of Fritzing. Fritzing is an important piece of software, if only for being a great way to create graphics of breadboard circuits. As a PCB design tool, it’s lacking; creating parts from scratch is far too hard, and there’s no way to get around the grid snap tool. No one should ever be forced to create a PCB in Fritzing, but it does have its own very limited place.
Continue reading “Creating A PCB In Everything: Friends Don’t Let Friends Use Fritzing” →
Reverse Engineering The Internet Of Coffee
The public promise of the Internet Of Things from years ago when the first journalists discovered the idea and strove to make it comprehensible to the masses was that your kitchen appliances would be internet-connected and somehow this would make our lives better. Fridges would have screens, we were told, and would magically order more bacon when supplies ran low.
A decade or so later some fridges have screens, but the real boom in IoT applications has not been in such consumer-visible applications. Most of your appliances are still just as unencumbered by connectivity as they were twenty years ago, and that Red Dwarf talking toaster that Lives Only To Toast is still fortunately in the realm of fiction.
The market hasn’t been devoid of IoT kitchen appliances though. One is the Smarter Coffee coffee machine, a network-connected coffeemaker that is controlled from an app. [Simone Margaritelli] bought one, though while he loved the coffee he really wasn’t keen on its not having a console application. He thus set about creating one, starting with reverse engineering its protocol by disassembling the Android version of its app.
What he found was sadly not an implementation of RFC 2324, instead it uses a very simple byte string to issue commands with parameters such as coffee strength. There is no security, and he could even trigger a firmware upgrade. The app requires a registration and login, though this appears to only be used for gathering statistics. His coffee application can thus command all the machine’s capabilities from his terminal, and he can enjoy a drink without reaching for an app.
On the face of it you might think that the machine’s lack of security might not matter as it is on a private network behind a firewall. But it represents yet another example of a worrying trend in IoT devices for completely ignoring security. If someone can reach it, the machine is an open book and the possibility for mischief far exceeds merely pranking its owner with a hundred doppio espressos. We have recently seen the first widely publicised DDoS attack using IoT devices, it’s time manufacturers started taking this threat seriously.
If the prospect of coffee hacks interests you, take a look at our previous coverage.
[via /r/homeautomation]
