Vinyl Cut Your Way Into An Edge-Lit Glass Display
The chances are you’ve seen the myriad cheap copyright-infringing edge-lit acrylic displays from Chinese suppliers everywhere on the internet, and indeed, etching acrylic with a modest CNC laser cutter has become easily viable to a lot of us in more recent years. However, if you want to kick things up a notch, [Michael Vieau] shows us how to build a plaque from scratch using not acrylic, but rather etched glass to make the finished product look that much more professional.
There are a few different steps to this build and each one is beautifully detailed for anyone who wants to follow along. First, the electronics driving the WS2812 lights are designed from scratch based on an ATtiny microcontroller on a PCB designed in Fritzing, and the sources necessary for replicating those at home are all available on [Michael’s] GitHub. He even notes how he custom-built a pogo-pin header at the end of the USBASP programmer to be able to easily use the same ICSP pinout in future projects.
But since a lot of you are likely all too familiar with the ins and outs of your basic Arduino projects, you’ll be more interested in the next steps, detailing how he milled the solid wood base and etched the glass that fits onto it. The process is actually surprisingly simple, all you need is to mask out the design you want through the use of a vinyl cutter and then pouring some etching solution over it. [Michael] recommends double-etching the design for a crisper look, and putting everything together is just as simple with his fastener of choice: hot glue.
Much as there was an age when Nixie displays adorned every piece of equipment, it seems like ease of manufacture is veering us towards an age of edge-lit displays. From word clocks to pendants and badges, we’re delighted to see this style of decoration emerge, including in replacing Nixies themselves!
Scorigami Bot Charts NFL History In The Making
NFL Football is a curious game to those who live beyond the borders of the continental United States. Its rules are many and complex, and its scoring system is built on arcane magic. This system means that there are many possible final game scores that have never actually happened in practice. For fans keen to hear of any first-time scores as they happen, Scorigami bot is here to help.
Charting and researching these is the practice of Scorigami, an idea first posited by Jon Bois, and is explored in this SB Nation video. It covers the many impossible scores in NFL, such as 1-0 and 1-1, as well as the possible-but-extremely-unlikely, like 6-1. To keep track of the state of Scorigami means following every score of every NFL game as its played. The ‘bot makes this easier; scraping the NFL livescores page with some nifty Javascript, it tracks each game live for potential first-time scores; the most recent as of writing being the Chiefs beating the Texans 51-31. Not only that, but the ‘bot estimates the most likely possible scorigami scores of games in progress, keeping fans on tenterhooks until the final whistle is blown. Or is it a siren in NFL? Inquiring minds need to know.
Code is naturally available on Github if you want to independently audit the Twitter feed; obviously the sanctity of scorigami results is absolutely paramount, and ensuring as such is a community responsibility. We’ve seen other live-score projects before, like this glowing Super Bowl football.
Paper Glows Up With This Origami Wall Piece
[Charlyn] recently found herself dissatisfied with the blank expanse of her bedroom walls. Deciding to take matters into her own hands, she set out to build this exquisite origami wall sculpture.
The piece was inspired by a work originally created by [Coco Sato], which she saw on Design Sponge. Materials were sourced, and [Charlyn] began the arduous process of cutting and folding the many, many pieces of paper that would make up the final piece. There were some missteps along the way, which served as a lesson to test early and test often, but a cup of tea and perseverance got the job done.
With the paper components completed, she looked to the electronics. Ten Neopixel LEDs were hooked up to a Particle Photon, giving the project easy IoT functionality. Thanks to IFTTT, the display can be controlled via Google Home, either glowing to create a relaxing vibe, or shutting off when it’s time to sleep. There’s also a smattering of flowers decorating the piece, somewhat of a [Charlyn] trademark.
The LEDs shine from behind the paper structure, creating a subtle, attractive glow. We’re big fans of the combination of LEDs with origami, and hope to see more projects using the material as an effective diffuser. You can even experiment with conductive materials to take things further. Video after the break.
Continue reading “Paper Glows Up With This Origami Wall Piece”
Winners Of The Take Flight With Feather Contest
It’s hard to beat the fidelity and durability of printed text on paper. But the e-paper display gets pretty close, and if you couple it will great design and dependable features, you might just prefer an e-reader over a bookshelf full of paperbacks. What if the deal is sweetened by making it Open Hardware? The Open Book Project rises to that challenge and has just been named the winner of the Take Flight with Feather contest.
This e-reader will now find its way into the wild, with a small manufacturing run to be put into stock by Digi-Key who sponsored this contest. Let’s take a closer look at the Open Book, as well as the five other top entries.
Continue reading “Winners Of The Take Flight With Feather Contest”
A Battery Sipping Cellular Mailbox Notifier
Like many of us, [Zak Kemble] has an indeterminate number of tiny packages coming his way from all over the globe at any given time. Unfortunately, the somewhat unpredictable nature of the postal service where he lives meant he found himself making a lot of wasted trips out to the mailbox to see if any overseas treasures had arrived for him. To solve the problem, he decided to build an Internet-connected mailbox notification system that could work within some fairly specific parameters.
For one thing, the mailbox is too distant to connect directly to it over WiFi. [Zak] mentions that 433 MHz might have been an option, but he decided to skip that entirely and just connect it to the cellular network with an A9G GPRS/GSM module from A.I. Thinker. This device actually has its own SDK that allows you to create a custom firmware for it, but unfortunately the high energy consumption of the radio meant it would chew through batteries too quickly unless it had a little extra help.
Not wanting to have to change the batteries every couple months, [Zak] added a ATtiny402 to handle the notifier’s power management needs. By using a P-MOSFET to completely cut power to the A9G, the notifier can save an incredible amount of energy by only activating the cellular connection once it actually needs to send a notification; which in this case takes the form of an HTTP request that eventually works its way to a Telegram group chat.
To cut a long story short, testing seems to indicate that the notifier can fire off approximately 800 requests before needing its 10440 lithium battery recharged. Given how often [Zak] usually receives mail, he says that should last him around five years.
The A9G module, the ATtiny402, a BME280 environmental sensor (because, why not?), the battery, and all the ancillary support hardware are on a very professional looking PCB. That goes into a relatively rugged enclosure that’s designed to keep the electronics from shorting out on the mailbox’s metal case as well as keeping any particularly weighty parcels from crushing it.
If you’ve got the freedom so mount whatever you want outside, then you can certainly build a more technically impressive mailbox. But considering the limitations [Zak] had to work around, we think he did an excellent job.
Bringing The Blockchain To Network Monitoring
If you need to make sure your computer isn’t being messed with, you’ll have a look at the log files. If something seems fishy, that’s grounds for further investigation. If you run a large network of computers, you’ll probably want to look over all of the logs, but you won’t want to run around to each computer individually. Setting up a central server to analyze the logs exposes an additional attack surface: the logs in transit. How do you make sure that the attackers aren’t also intercepting and sanitizing your log file reports?
The answer to this question, and nearly everything else, is blockchain! Or maybe it’s not, but in this short presentation from the 2019 Hackaday Superconference, Shanni Prutchi, Jeff Wood, and six other college students intend to find out. While Shanni “rolls her eyes” at much of blockchain technology along with the rest of us, you have to admit one thing: recursively hashing your log data to make sure they’re not tampered with doesn’t sound like such a bad idea. Continue reading “Bringing The Blockchain To Network Monitoring”
P-51 Cockpit Recreated With Help Of Local Makerspace
It’s surprisingly easy to misjudge tips that come into the Hackaday tip line. After filtering out the omnipresent spam, a quick scan of tip titles will often form a quick impression that turns out to be completely wrong. Such was the case with a recent tip that seemed from the subject line to be a flight simulator cockpit. The mental picture I had was of a model cockpit hooked to Flight Simulator or some other off-the-shelf flying game, many of which we’ve seen over the years.
I couldn’t have been more wrong about the project that Grant Hobbs undertook. His cockpit simulator turned out to be so much more than what I thought, and after trading a few emails with him to get all the details, I felt like I had to share the series of hacks that led to the short video below and the story about how he somehow managed to build the set despite having no previous experience with the usual tools of the trade.
Continue reading “P-51 Cockpit Recreated With Help Of Local Makerspace”
