Build An Everlasting Continuity Tester
When you need a continuity tester at the bench, what do you reach for? Probably your multimeter, right? It may surprise you to know that the continuity tester in the meter isn’t all that sensitive, even if it’s the yellow expensive kind. [Leo]’s will beep even if there is 50Ω of resistance in the line.
Disgusted by modern commercial testers, [Leo] set out to make the ideal continuity tester in the spirit of old school tools that do one thing and do it really well. It had to be simple to use, always ready to go, and capable of measuring continuity at 5Ω or less resistance (video, embedded below).
There’s no power switch or even labels, because it doesn’t need any. Just put the probes where you want ’em, and it either beeps and lights the LED or it doesn’t. It looks simple, but inside that blast-resistant enclosure are lots of cool features that certainly make it seem like the ideal tester to us.
Our favorite has to be the transient blocking unit that works like a little circuit breaker. They’re used to protect circuits from lighting and electrostatic discharge by way of depletion-mode MOSFETs and switches to protected mode in under a microsecond. Watch [Leo] build this workbench necessity and then abuse test it with mains power after the break.
Making your own tools, however simple or complex is a great experience. If you want to up your speedy prototyping game, [Leo]’s got you covered there with a special scratching tool for hand-scribing copper PCBs. Continue reading “Build An Everlasting Continuity Tester” →
Changing System Architectures And The Complexities Of Apple’s Butterfly Approach To ISAs
Apple computers will be moving away from Intel chips to its own ARM-based design. An interesting thing about Apple as a company is that it has never felt the need to tie itself to a particular system architecture or ISA. Whereas a company like Microsoft mostly tied its fortunes to Intel’s x86 architecture, and IBM, Sun, HP and other giants preferred vertical integration, Apple is currently moving towards its fifth system architecture for its computers since the company was formed.
What makes this latest change possibly unique, however, is that instead of Apple relying on an external supplier for CPUs and peripheral ICs, they are now targeting a vertical integration approach. Although the ARM ISA is licensed to Apple by Arm Holdings, the ‘Apple Silicon’ design that is used in Apple’s ARM processors is their own, produced by Apple’s own engineers and produced by foundries at the behest of Apple.
In this article I would like to take a look back at Apple’s architectural decisions over the decades and how they made Apple’s move towards vertical integration practically a certainty.
Continue reading “Changing System Architectures And The Complexities Of Apple’s Butterfly Approach To ISAs” →
500 Lasers Are Not Necessarily Better Than One, But They Look Great
If playing with but a single laser pointer is fun, then playing with 500 laser pointers must be 500 times the fun, right? So by extension, training 500 laser pointers on a single point must be the pinnacle of pointless mirth. And indeed it is.
When we first spotted this project, we thought for sure it was yet another case of lockdown-induced  boredom producing an over-the-top build. Mind you, we have no problem with that, but in this case, [nanoslavic] relates that this is actually a project from a few years back. It’s really as simple as it looks: 500 laser pointer modules arranged on a plate with a grid of holes in a 25 by 20 array. As he placed the laser modules on the board with a glob of hot glue, he carefully aimed each one to hit a single point about a meter and a half away.  There are also a handful of blue LEDs nestled into the array, because what project is complete without blue LEDs?
The modules are wired in concentric circuits and controlled by a simple bank of toggle switches. Alas, 500 converging 150-mW 5 mW lasers do not a 75-W 2.5 W laser make; when fully powered, the effect at the focal point is reported to be only a bit warm. But it looks incredible, especially through smoke. Throwing mirrors and lenses into the beam results in some interesting patterns, too.
You’ll still need to take safety seriously if you build something like this, of course, but this one is really just for show. If you’re really serious about doing some damage with lasers, check out the long list of inadvisable laser builds that [Styropyro] has accumulated — from a high-powered “lightsaber” to a 200-Watt laser bazooka.
(Terminate your beams carefully, folks. We don’t want anyone going blind.)
Continue reading “500 Lasers Are Not Necessarily Better Than One, But They Look Great” →
NASA Making Big Upgrades To Their Big Dish DSS43
When it comes to antenna projects, we usually cover little ones here. From copper traces on a circuit board to hand-made units for ham radio. But every once in a while it’s fun to look at the opposite end of the spectrum, and anyone who craves such change of pace should check out DSS43’s upgrade currently underway.
Part of NASA’s Deep Space Network (DSN) built to communicate with spacecraft that venture far beyond Earth, Deep Space Station 43 is a large dish antenna with a diameter of 70 meters and largest of the Canberra, Australia DSN complex. However, the raw reflective surface area is only as good as the radio equipment at its center, which are now outdated and thus focus of this round of upgrades.
The NASA page linked above offers a few pieces of fun trivia about DSS43 and its capabilities. If that whets an appetite for more, head over to Twitter for a huge treasure trove. Whoever is in charge of Canberra DSN’s Twitter account has an endless fountain of facts and very eager to share them in response to questions, usually tagged with #DSS43. Example: the weight of DSS43 is roughly 8.5 million kilograms, 4 million of which is moving structure. They also shared time lapse video clips of work in progress, one of which is embedded after the break.
Taking the uniquely capable DSS43 offline for upgrades does have some consequences, one of which is losing our ability to send commands to distant interplanetary probe Voyager 2. (Apparently smaller DSN dishes can be arrayed to receive data, but only DSS43 can send commands.) Such sacrifices are necessary as an investment for the future, with upgrade completion scheduled for January 2021. Just in time to help support Perseverance (formerly “Mars 2020”) rover‘s arrival in February and many more missions for years to come.
Continue reading “NASA Making Big Upgrades To Their Big Dish DSS43” →
(Re)Making A ColecoVision
[Leaded Solder] found some ColecoVision game cartridges at a flea market, and like most of us would, thought, “I’ll build a ColecoVision console from scratch to play them!” Well, maybe most of us would think of that, but not actually do it. He did and you can read about the results in great detail since he wrote up two posts, one covering the design and one covering the construction.
The ColecoVision was a game console that famously could be expanded into a nice — for its day — personal computer. It even had a daisy wheel printer in that configuration. However, in either configuration, the game console was the brains of the operation. According to [Leaded Solder] the price of a unit in working order is high even though over 2 million were made because of several design problems that make them less likely to survive the decades. Rather than repair and modify an original unit, it was cheaper and much more educational to build new.
Continue reading “(Re)Making A ColecoVision” →
Making Smalltalk On A Raspberry Pi
Today, you probably don’t think much about object-oriented programming, it’s just part of the landscape. But decades ago, it was strange and obscure technology. While there were several languages that led up to the current object-oriented tools we use today, one of the most influential was Xerox PARC’s Smalltalk language. [Michael Engel] took a C++ implementation of the Smalltalk VM, some byte code for a complete Smalltalk system, a Raspberry Pi “bare metal” library, and produced a Smalltalk workstation running on a bare Raspberry Pi — even a Pi Zero. The code is on GitHub and is admittedly a work in progress.
Smalltalk was interesting — and sometimes annoying — because everything was an object. Literally everything. The system took over the entire machine. It provided the GUI, the compiler, and the run time libraries. That’s probably why it was easy for [Michael] to forego the usual Linux OS for his project.
Continue reading “Making Smalltalk On A Raspberry Pi” →
Hackaday Links Column Banner
Hackaday Links: July 12, 2020
Based in the US as Hackaday is, it’s easy to overload the news with stories from home. That’s particularly true with dark tales of the expanding surveillance state, which seem to just get worse here on a daily basis. So we’re not exactly sure how we feel to share not one but two international stories of a dystopian bent; one the one hand, pleased that it’s not us for a change, but on the other, sad to see the trend toward less freedom and more monitoring spreading.
The first story comes from Mexico, where apparently everything our community does will soon be illegal. We couch that statement because the analysis is based on Google translations of reports from Mexico, possibly masking the linguistic nuances that undergird legislative prose. So we did some digging and it indeed appears that the Mexican Senate approved a package of reforms to existing federal copyright laws that will make it illegal to do things like installing a non-OEM operating system on a PC, or to use non-branded ink cartridges in a printer. Reverse engineering ROMs will be right out too, making any meaningful security research illegal. There appear to be exceptions to the law, but those are mostly to the benefit of the Mexican government for “national security purposes.” It’ll be a sad day indeed for Mexican hackers if this law is passed.
The other story comes from Germany, where a proposed law would grant sweeping surveillance powers to 19 state intelligence bodies. The law would require ISPs to install hardware in their data centers that would allow law enforcement to receive data and potentially modify it before sending it on to where it was supposed to go. So German Internet users can look forward to state-sponsored man-in-the-middle attacks and trojan injections if this thing passes.
OK, time for a palate cleanser: take an hour to watch a time-lapse of the last decade of activity of our star. NASA put the film together from data sent back by the Solar Dynamics Observatory, a satellite that has been keeping an eye on the Sun from geosynchronous orbit since 2010. Each frame of the film is one hour of solar activity, which may sound like it would be boring to watch, but it’s actually quite interesting and very relaxing. There are exciting moments, too, like enormous solar eruptions and the beautiful but somehow terrifying lunar transits. More terrifying still is a massive coronal mass ejection (CME) captured in June 2011. A more subtle but fascinating phenomenon is the gradual decrease in the number of sunspots over the decade as the Sun goes through its normal eleven-year cycle.
You’ll recall that as a public service to our more gear-headed readers that we recently covered the recall of automotive jack stands sold at Harbor Freight, purveyor of discount tools in the USA. Parts for the jack stands in question had been cast with a degraded mold, making the pawls liable to kick out under load and drop the vehicle, with potentially catastrophic results for anyone working beneath. To their credit, Harbor Freight responded immediately and replaced tons of stands with a new version. But now, Harbor Freight is forced to recall the replacement stands as well, due to a welding error. It’s an embarrassment, to be sure, but to make it as right as possible, Harbor Freight is now accepting any of their brand jack stands for refund or store credit.
And finally, if you thought that the experience of buying a new car couldn’t be any more miserable, wait till you have to pay to use the windshield wipers. Exaggeration? Perhaps only slightly, now that BMW “is planning to move some features of its new cars to a subscription model.” Plans like that are common enough as cars get increasingly complex infotainment systems, or with vehicles like Teslas which can be upgraded remotely. But BMW is actually planning on making options such as heated seats and adaptive cruise control available only by subscription — try it out for a month and if you like it, pay to keep them on for a year. It would aggravate us to no end knowing that the hardware supporting these features had already been installed and were just being held ransom by software. Sounds like a perfect job for a hacker — just not one in Mexico.
