Putting Some Numbers On Your NEMAs
It’s official: [Engineer Bo] wins the internet with a video titled “Finding NEMA 17,” wherein he builds a dynamometer to find the best stepper motor in the popular NEMA 17 frame size.
Like a lot of subjective questions, the only correct answer to which stepper is best is, “It depends,” and [Bo] certainly has that in mind while gathering the data needed to construct torque-speed curves for five samples of NEMA 17 motors using his homebrew dyno. The dyno itself is pretty cool, with a bicycle disc brake to provide drag, a load cell to measure braking force, and an optical encoder to measure the rotation of the motor under test. The selected motors represent a cross-section of what’s commonly available today, some of which appear in big-name 3D printers and other common applications.
[Bo] tested each motor with two different drivers: the TMC2209 silent driver to start with, and because he released the Magic Smoke from those, the higher current TB6600 module. The difference between the two drivers was striking, with lower torque and top speeds for the same settings on each motor using the TB6600, as well as more variability in the data. Motors did better across the board with the TBC6600 at 24 volts, showing improved torque at higher speeds, and slightly higher top speeds. He also tested the effect of microstepping on torque using the TBC6600 and found that using full steps resulted in higher torque across a greater speed range.
At the end of the day, it seems as if these tests say more about the driver than they do about any of the motors tested. Perhaps the lesson here is to match the motor to the driver in light of what the application will be. Regardless, it’s a nice piece of work, and we really appreciate the dyno design to boot — reminds us of a scaled-down version of the one [Jeremey Fielding] demonstrated a few years back.
Continue reading “Putting Some Numbers On Your NEMAs”
Make A Cheap Robot Mower Much Smarter
The Parkside range of tools as sold in European Lidl stores may be reasonably priced, but it contains some products of far better quality than their modest cost would suggest. This means that Parkside hacking has become as much of a cottage industry as IKEA hacking, and they’re a firm favorite for modifications. [Lambertus] has taken a Parkside robot mower, and converted it from a relatively mundane device to a fully-connected smart robot, with the aid of an ESP8266.
The hardware is surprisingly simple, as all that’s really needed is a stop/go command. This can be readily found by hooking up to the input from the mower’s rain sensor, allowing the ESP to control its operation. Then there’s an accelerometer to allow it to count motion, and a hookup tot he battery to measure voltage. The firmware uses ESPHome, resulting in a mower now connected to home automation.
This isn’t the first time we’ve shown you someone upgrading the smarts on  robot mover, and of course we’ve also taken a tour through the history of lawn mowers in general.
Access To Fresh And Potable Water: An Ancient And Very Current Challenge
Throughout history, clean and potable water has been one of the most prized possessions, without which no human civilization could have ever sustained itself. Not only is water crucial for drinking and food preparation, but also for agriculture, cleaning and the production of countless materials, chemicals and much more. And this isn’t a modern problem: good water supplies and the most successful ancient cultures go hand in hand.
For instance, the retention and management of fresh water in reservoirs played a major role in the Khmer Empire, with many of its reservoirs (baray) surviving to today. Similarly, the Anuradhapure Kingdom in Ceylon (now Sri Lanka) featured massive reservoirs like Kala Wewa that was constructed in 460 CE with a capacity of 123 million m3. In the New World, the Maya civilization similarly created reservoirs with intricate canals to capture rainwater before the dry season started, as due to the karst landscape wells were not possible.
Keeping this water fresh and free from contaminants and pollution was a major problem for especially the Maya, with a recent perspective by Lisa J. Lucera in PNAS Anthropology suggesting that they used an approach similar to modern day constructed wetlands to keep disease and illness at bay, while earlier discoveries also suggest the use of filtration including the use of zeolite.
Continue reading “Access To Fresh And Potable Water: An Ancient And Very Current Challenge”
A devboard with the CH32V003, with a few resistors and bodges, with a USB-C cable plugged into it, and a programmer plus an extra probe attached.
USB PD On CH32V003 Teaches You Everything
How do you talk USB Power Delivery (PD)? Grab a PHY? Use a MCU with one built-in? Well, if you’re hardcore enough, you can do it with just a few resistors and GPIOs. [eeucalyptus] shows you their implementation of USB-PD on a CH32V003, which has no PD peripheral. This includes building a PD trigger, completely open source, and walking you through the entire low-level PD basics, too!
It helps that CH32V003 is a 32-bit MCU with a good few resources and peripherals, for instance, an internal comparator. Other than that, you don’t need much in terms of hardware resources, but you do need a steady hand — parts of the firmware had to be written in assembly to keep up with PD timing. Want to tinker with the fruit of this research, perhaps, further build upon the code? There’s an example board on GitHub, too!
Want to try your own luck with this method? There’s a schematic, and logic analyzer captures, and a board to refer to. Again, more than enough information on every single low-level detail! Otherwise, grab an MCU pre-programmed to talk PD, maybe a trigger board chip, or maybe even a PD PHY and implement PD communications with it directly – it’s pretty easy!
We thank [Julianna] for sharing this with us!
Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Keebin’ With Kristina: The One With The Tasty Snacks Board
A pocket cyberdeck-looking thing with a screen and a thumb keyboard.
Image by [MakerM0] via Hackaday.IO
[MakerM0]’s LangCard is an entry into our 2024 Business Card Challenge that just so happens to fit the Keebin’ bill as well.
You might label this a pocket cyberdeck, and that’s just fine with me. The idea here is to have a full-keyboard development board for learning programming languages like CircuitPython, MicroPython, C++, and so on, wherever [MakerM0] happens to be at a given moment.
Open up the LangCard and you’ll find an RP2040 and a slim LiPo battery. I’m not sure what display that is, but there are probably a few that would work just fine were you to make one of these fun learning devices for yourself.
Continue reading “Keebin’ With Kristina: The One With The Tasty Snacks Board”
Fork! Ladybird Browser And SerenityOS To Go Separate Ways
In the monthly Ladybird Browser update video which we’ve placed below, SerenityOS founder [Andreas Kling] announced an interesting development. The browser has been forked from the OS that has been its progenitor, and both projects will now proceed separately. This frees the browser from the SerenityOS insistence on avoiding external libraries, and allows it to take advantage of stable, fast, and mature open source alternatives. This is already paying dividends in compatibility and speed, and is likely to lead further towards a usable everyday browser as time goes by.
As the world of fully-featured web browser engines has contracted from a number of different projects to little more than Google’s Blink and Mozilla’s Gecko, Ladybird has found itself in an unexpected position. It is vital that the browser market retains some competition and does not become a Google monoculture, so while it might not seem so at first glance, the news of Ladybird going alone has the potential to be one of the most far-reaching open source stories of the year.
If you’d like to try Ladybird you’ll have to get your hands slightly dirty and build it yourself, but we’d expect ready-built versions to appear in due course. We took a look at an earlier version of Ladybird last year, as well as SerenityOS itself.
Continue reading “Fork! Ladybird Browser And SerenityOS To Go Separate Ways”
Meccano-based Hellschreiber Machine
[ZXGuesser] has pulled off a true feat of Meccano engineering: building a Meccano Hellschreiber machine. The design is a close replica of the original Siemens Feld-Hell machine as documented here. What is Hellschreiber, you might ask? It’s a very neat method of sending written messages over the air by synchronizing a printing wheel on the receiving end with pulses generated on the transmitter. By quickly moving the print wheel up and down, arbitrary figures can be printed out. If you want to learn more about Hellschreiber, check out this excellent Hackaday post from almost a decade ago!
The Mastodon thread linked above goes into more detail about the difficulty in building this behemoth — and the slight regret of sticking with the authentic QWERTZ keyboard layout! In order to use the Hellschreiber mode, you have to keep up a steady rhythm of typing at about 2.5 characters per second, otherwise, the receiving end will see randomly spaced gaps between each letter. So while having to type at a steady speed [ZXGuesser] also had to work with a slightly different keyboard layout. Despite this difficulty, some very good quality output was generated!
Incredibly, the output looks just like the output from the original, century-old design. We think this is an absolutely incredible accomplishment, and we hope [ZXGuesser] doesn’t follow through on disassembling this amazing replica — or if they do, we hope it’s documented well enough for others to try their hand at it!
Thanks [BB] for the tip!
