Teardown Of A 2026 LEGO SMART Brick
LEGO SMART brick from its side. (Credit: EvilmonkeyzDesignz, YouTube)
At the beginning of March this year LEGO released their new SMART brick, which looks like a 2×4 stud brick and is filled to the brim with sensors, LEDs, NFC and Bluetooth functionality, as well as a purported custom ASIC. The central idea behind it appears to be to add a lot of interactivity to LEGO builds while allowing for mesh-style communication with other SMART bricks. Naturally, this makes it a great subject for a teardown, which is what [EvilmonkeyzDesignz] over on YouTube did in a recent video.
Normally the only way you can purchase one of these new bricks is by buying them as part of a ‘Smart Play’ set, but someone was selling singular bricks on EBay. As the brick is inductively recharged, it’s pretty well-sealed, requiring a fairly destructive opening method.
Directly below the transparent top is a speaker, with the opposing PCB on the main body containing a microphone as well as a number of RGB LEDs. On the opposite side of this PCB we find the photo sensor, but to get to this part of the PCB the copper wires that wrap around the entire main assembly have to be disconnected from the PCB’s side pads with some force as they’re apparently pressed in place without the use of solder.
Continue reading “Teardown Of A 2026 LEGO SMART Brick”
DIY Reflow Plate Runs On USB Power Delivery
If you’re working with surface mount components, you’re likely going to want a reflow plate at some point. [Vitaly] was in need of just such a tool, and thus whipped up a compact reflow plate that is conveniently powered via USB-C.
This reflow rig is designed for smaller work, with a working area of 80 mm x 70 mm. There are two options for the heating element—either a metal core PCB-based heater, or a metal ceramic heater. The former is good for working with Sn42Bi58 solder paste at 138 C, according to [Vitaly], while the latter will happily handle Sn63Pb37 at 183 C if the dirty stuff is more your jam.
Running the show is an ESP32-C3-WROOM, which serves up a web-based control panel over Bluetooth for setting the heating profiles. Using Bluetooth over WiFi might seem like an odd choice at first, but it means you don’t have to add the hot plate to the local wireless network to access it, handy if you’re on the move. It’s also worth noting that you can’t run this off any old USB charger—you’ll need one compatible with USB Power Delivery (PD) that can deliver at least 100 watts.
If you’re needing to whip up small boards with regularity, a hotplate like this one can really come in handy. Files are on GitHub for those eager to build their own.
This isn’t the first time we’ve seen USB-C powering a small reflow plate. Of course, if you make your PCBs self heating, you can sidestep all that entirely.
Running Windows 98 On The IPAQ IA-2 Internet Appliance
Devices that were limited to only run a web browser were relatively common around 2000, as many people wanted to surf the Information Super Highway, but didn’t quite want to get a regular PC — being in many ways the retro equivalent of a Chromebook. The Compaq iPAQ IA-2 from 2000 that [Dave Luna] got is no exception, with a Microsoft CE-based OS that is meant to be used with Microsoft Network (MSN) dial-up, which amusingly is still available today.
In order to get a more useful OS on it, like Windows 98, you have to jump through quite a few hoops, as [Dave] found out. Although there is an IDE connection on the mainboard, this cannot be booted from, likely due to BIOS limitations. This means that he had to chain boot via the 16 MB NAND Flash drive that the original OS booted from, which was done by writing MS-DOS to the Flash drive using another workaround as it’s not a standard IDE device either.
From this you can then boot Windows 98 from an IDE drive by pretending that it’s an ATAPI IDE device to dodge a limitation on IDE devices. The system’s hardware isn’t really going to make it into a blazing fast retro computer. It only has a 266 MHz Geode GX1 CPU and supports up to 256 MB of SDRAM. The IA-2 is also limited to 800×600, which required the use of an external monitor (as seen above) hooked up to the internal VGA port to set the proper resolution in the OS.
But at least it can run DOOM, so that bare minimum requirement can be ticked off.
Continue reading “Running Windows 98 On The IPAQ IA-2 Internet Appliance”
Repurposing Old AMD APUs For AI Work
The BC250 is what AMD calls an APU, or Accelerated Processing Unit. It combines a GPU and CPU into a single unit, and was originally built to serve as the heart of certain Samsung rack mount servers. If you know where to find cheap surplus units of the BC250, you can put them to good use for AI work, as [akandr] demonstrates.
The first thing you’ll have to figure out is how to take an individual BC250 APU and get it up and running. It’s effectively a full system-on-chip, combining a Zen 2 CPU with a Cyan Skillfish RDNA 1.5 GPU. However, it was originally intended to run inside a rackmount server unit rather than a standalone machine. To get it going, you’ll need to hook it up with power and some kind of cooling solution.
From there, it’s a matter of software. [akandr] explains how to get AI workflows running on the BC250 using Ollama and Vulkan, while noting useful hacks to improve performance like disabling the GUI and tweaking the CPU governor. The hardware can be used with a wide range of different models depending on what you’re trying to achieve, it just takes some careful management of the APU’s resources to get the most out of it. Thankfully, that’s all in the guide on GitHub.
We’ve already seen these AMD APUs repurposed before for gaming use. Unfortunately the word is out already  about their capabilities, so prices have risen significantly in response to demand. Still, if you manage to score a BC250 and do something cool with it yourself, be sure to let us know on the tipsline!
FLOSS Weekly Episode 866: BreezyBox And Embedded Compilers
This week Jonathan chats with Valentyn Danylchuk about BreezyBox — an interactive shell and toolkit that provides various tools and a compiler on an ESP32 microcontroller. What was the inspiration for this impressive project, and what direction is it heading? Watch to find out!
Continue reading “FLOSS Weekly Episode 866: BreezyBox And Embedded Compilers”
Hackaday Europe Tickets On Sale Now, CFP Extended
Hackaday Europe is approaching, and we’re putting tickets on sale now. “But wait, you haven’t selected the talks yet!” we hear you saying. Indeed! And that’s why we discount the first round of entries for our True Believers™ – the hard core who know that it’s going to be a fantastic event and turn up regardless. So if you want to come to Hackaday Europe on the cheap, go snap up your ticket before they’re gone.
Call for Participation Extended
Of course, giving a talk is always the best way to attend a hacker gathering like this. And we know that we said that today was the deadline for talk submissions. But we also know that many of you have advanced degrees in procrastineering, so we’re giving you a week’s extension.
Selected speakers get in free, and we’ll reserve you an early-bird ticket for putting together a legit talk proposal either way. So if you’re a first-time presenter or a wizened pro, and you have something that you’d like to say to an audience of like-minded hackers, we’d all like to hear from you. We won’t extend the deadline twice, though, so get your proposal in before March 25.
(A few people have reached out to us, wanting to avoid the Google login that the above form requires. If you’re in the same camp, write to us directly and let us know!)
Hackaday Europe
In case you don’t know, Hackaday Europe started out as a bi-annual event that we first held a decade ago in Belgrade. It has been such a success that we’re now doing it every year, and leap-frogging around Europe to spread the love. The last two three events have been in Berlin, and this is our first time in Lecco, Italy. This year, it runs the weekend of May 16th and 17th, with a pre-event on the evening of the 15th, to be announced.
What stays the same? We have a fantastic crowd who bring their passion projects with them, a fun badge to hack on, and of course food, drink, music, and merriment all along. Oh, and the talks. (You are submitting your talk, right?)
We’ll have more details coming your way in the next few weeks, so stay tuned. After March 25th, we’ll get to selecting talks, and let you all know. Get your tickets now – we can’t wait to see you all in eight-and-a-half weeks!
Forgetfulino Puts Back Up Of Source Inside The Binary
How often have you pulled out old MCU-based project that still works fine, but you have no idea where the original source code has gone? Having the binary image and the source code as separate things to keep track of usually isn’t a problem, but there’s something to be said for adding the source — and documentation — to this image if you have some flash to spare. This is basically what the Forgetfulino Arduino library by [Nader Al Khatib] does.
Essentially, the library compresses the source files and assigns it to be burned onto the flash alongside the binary. There is also a bit of code added to the firmware so that this code can be retrieved via the serial port at any time, negating the need for a firmware dump and manual disassembly. For ease of use, the library has an Arduino IDE extension that automates the process. The basic idea could also be adapted to different environments should anyone wish to take up the challenge.
You probably wouldn’t want debug builds to feature this additional payload as writing it to flash will eat up time and write cycles. But for a release build that will be put out in the (literal) field for a few years or even decades, it could be very convenient. After all, you never know when that Git repository that you relied on might go AWOL.
