SpyTech: The Underwater Wire Tap
In the 1970s, the USSR had an undersea cable connecting a major naval base at Petropavlovsk to the Pacific Fleet headquarters at Vladivostok. The cable traversed the Sea of Okhotsk, which, at the time, the USSR claimed. It was off limits to foreign vessels, heavily patrolled, and laced with detection devices. How much more secure could it be? Against the US Navy, apparently not very secure at all. For about a decade starting in 1972, the Navy delivered tapes of all the traffic on the cable to the NSA.
Top Secret
You need a few things to make this a success. First, you need a stealthy submarine. The Navy had the USS Halibut, which has a strange history. You also need some sort of undetectable listening device that can operate on the ocean floor. You also need a crew that is sworn to secrecy.
That last part was hard to manage. It takes a lot of people to mount a secret operation to the other side of the globe, so they came up with a cover story: officially, the Halibut was in Okhotsk to recover parts of a Soviet weapon for analysis. Only a few people knew the real mission. The whole operation was known as Operation Ivy Bells.
The Halibut
The Halibut is possibly the strangest submarine ever. It started life destined to be a diesel sub. However, before it launched in 1959, it had been converted to nuclear power. In fact, the sub was the first designed to launch guided missiles and was the first sub to successfully launch a guided missile, although it had to surface to launch.
Oddly enough, the sub carried nuclear cruise missiles and its specific target, should the world go to a nuclear war, was the Soviet naval base at Petropavolvsk.
Continue reading “SpyTech: The Underwater Wire Tap”
Site Of Secret 1950s Cold War Iceworm Project Rediscovered
The overall theme of the early part of the Cold War was that of subterfuge — with scientific missions often providing excellent cover for placing missiles right on the USSR’s doorstep. Recently NASA rediscovered Camp Century, while testing a airplane-based synthetic aperture radar instrument (UAVSAR) over Greenland. Although established on the surface in 1959 as a polar research site, and actually producing good science from e.g. ice core samples, beneath this benign surface was the secretive Project Iceworm.
By 1967 the base was forced to be abandoned due to shifting ice caps, which would eventually bury the site under over 30 meters of ice. Before that, the scientists would test out the PM-2A small modular reactor. It not only provided 2 MW of electrical power and heat to the base, but was itself subjected to various experiments. Alongside this public face, Project Iceworm sought to set up a network of mobile nuclear missile launch sites for Minuteman missiles. These would be located below the ice sheet, capable of surviving a first strike scenario by the USSR. A lack of Danish permission, among other complications, led to the project eventually being abandoned.
It was this base that popped up during the NASA scan of the ice bed. Although it was thought that the crushed remains would be safely entombed, it’s estimated that by the year 2100 global warming will have led to the site being exposed again, including the thousands of liters of diesel and tons of hazardous waste that were left behind back in 1967. The positive news here is probably that with this SAR instrument we can keep much better tabs on the condition of the site as the ice cap continues to grind it into a fine paste.
Top image: Camp Century in happier times. (Source: US Army, Wikimedia)
The DEW Line Remembered
The DEW line was one of three radar early warning systems of the time.
If you grew up in the middle of the Cold War, you probably remember hearing about the Distant Early Warning line between duck-and-cover drills. The United States and Canada built the DEW line radar stations throughout the Arctic to detect potential attacks from the other side of the globe.
MIT’s Lincoln Lab proposed the DEW Line in 1952, and the plan was ambitious. In order to spot bombers crossing over the Arctic circle in time, it required radar twice as powerful as the best radar of the day. It also needed communications systems that were 99 percent reliable, even in the face of terrestrial and solar weather.
In the end, there were 33 stations built from Alaska to Greenland in an astonishing 32 months. Keep in mind that these stations were located in a very inhospitable environment, where temperatures reached down to -60 °F (-51 °C). Operators kept the stations running 24/7 for 36 years, from 1957 to 1993.
System of Systems
The DEW line wasn’t the only radar early-warning system that the US and Canada had in place, only the most ambitious. The Pinetree Line was first activated in 1951. However, its simple radar was prone to jamming and couldn’t pick up things close to the ground. It was also too close to main cities along the border to offer them much protection. Even so, the 33 major stations, along with six smaller stations, did better than expected. Continue reading “The DEW Line Remembered”
Radio Apocalypse: Meteor Burst Communications
The world’s militaries have always been at the forefront of communications technology. From trumpets and drums to signal flags and semaphores, anything that allows a military commander to relay orders to troops in the field quickly or call for reinforcements was quickly seized upon and optimized. So once radio was invented, it’s little wonder how quickly military commanders capitalized on it for field communications.
Radiotelegraph systems began showing up as early as the First World War, but World War II was the first real radio war, with every belligerent taking full advantage of the latest radio technology. Chief among these developments was the ability of signals in the high-frequency (HF) bands to reflect off the ionosphere and propagate around the world, an important capability when prosecuting a global war.
But not long after, in the less kinetic but equally dangerous Cold War period, military planners began to see the need to move more information around than HF radio could support while still being able to do it over the horizon. What they needed was the higher bandwidth of the higher frequencies, but to somehow bend the signals around the curvature of the Earth. What they came up with was a fascinating application of practical physics: meteor burst communications.
Continue reading “Radio Apocalypse: Meteor Burst Communications”
The Nuclear War You Didn’t Notice
We always enjoy [The History Guy], and we wish he’d do more history of science and technology. But when he does, he always delivers! His latest video, which you can see below, focuses on the Cold War pursuit of creating transfermium elements. That is, the discovery of elements that appear above fermium using advanced techniques like cyclotrons.
There was a brief history of scientists producing unnatural elements. The two leaders in this work were a Soviet lab, the Joint Institute of Nuclear Research, and a US lab at Berkeley.
Continue reading “The Nuclear War You Didn’t Notice”
British wartime periscope on a workbench
British Wartime Periscope: A Peek Into The Past
We all know periscopes serve for observation where there’s no direct line-of-sight, but did you know they can allow you to peer through history?  That’s what [msylvain59] documented when he picked up a British military night vision periscope, snagged from a German surplus shop for just 49 euros. Despite its Cold War vintage and questionable condition, the unit begged for a teardown.
The periscope is a 15-kilo beast: industrial metal, cryptic shutter controls, and twin optics that haven’t seen action since flares were fashionable. One photo amplifier tube flickers to greenish life, the other’s deader than a disco ball in 1993. With no documentation, unclear symbols, and adjustment dials from hell, the teardown feels more like deciphering a British MoD fever dream than a Sunday project. And of course, everything’s imperial.
Despite corrosion, mysterious bulbs, and non-functional shutters, [msylvian59] uncovers a fascinating mix of precision engineering and Cold War paranoia. There’s a thrill in tracing light paths through mil-spec lenses (the number of graticules seen that are etched on the optics) and wondering what secrets they once guarded. This relic might not see well anymore, but it sure makes us look deeper. Let us know your thoughts in the comments or share your unusual wartime relics below.
Continue reading “British Wartime Periscope: A Peek Into The Past”
Hackaday Links Column Banner
Hackaday Links: November 17, 2024
A couple of weeks back, we covered an interesting method for prototyping PCBs using a modified CNC mill to 3D print solder onto a blank FR4 substrate. The video showing this process generated a lot of interest and no fewer than 20 tips to the Hackaday tips line, which continued to come in dribs and drabs this week. In a world where low-cost, fast-turn PCB fabs exist, the amount of effort that went into this method makes little sense, and readers certainly made that known in the comments section. Given that the blokes who pulled this off are gearheads with no hobby electronics background, it kind of made their approach a little more understandable, but it still left a ton of practical questions about how they pulled it off. And now a new video from the aptly named Bad Obsession Motorsports attempts to explain what went on behind the scenes.
Continue reading “Hackaday Links: November 17, 2024”
