The Birdy44 Keyboard Is Something To Crow About
The funny thing about keyboard end game is that it usually involves more than one keyboard. Rare is the board that is great for both home and away. Having finished their dactyl build, [RalphCoder13] was looking to build something slimmer and more portable, and the Birdy44 was born.
This hand-wired beauty uses a pair of Waveshare RP2040 Zeros and features a pair of 40mm Cirque track pads that were salvaged from a Steam controller.
As you may have guessed, there are 44 Kailh Chocs that sit underneath a combination of MBK and 3D-printed keycaps. Our favorite part might be the tenting legs, which are optional and connect magnetically.
Part of portability is how you decide to carry the thing. You probably don’t want it naked and loose in your backpack if you can avoid it, right? To that end, he designed a nice little case for the halves. The original plan was to use magnets to hold them in place inside the topless case, but that didn’t work out so well, so he added wide elastic bands to stretch around the case.
Is this still not portable enough for you? Check out this folding split keyboard.
Via KBD
Daily Inspections Keep Your Spitfire In Tip-Top Shape
What ho, chaps? Look, we know this is a bally nuisance and all, but those desk jockeys at HQ want us all to watch this film about daily insepction of your Spitfire. No Vera and no Greta in this one, more’s the pity, but it is jolly important. We all know that our Spitfires are complicated buckets of bolts, but those kites won’t stay in the air if we don’t maintain them. Yes, the boring stuff, like purging the fuel system of water and refueling outside of the hanger. And, yes, Captain Molesworth, that means putting out that cigar while the tech boys are topping off your tank. Now shut up and watch the film we’ve placed below the break, what?
All right, all right, wake up at the back there. I heard you snoring, Peason. The bally Germans could hear you snoring. I know that wasn’t Errol Flynn, but this stuff is damned essential. You may be pilots, but you all rely on those people you just saw. Your lives depend on the riggers, armorers, instrument repairers, and others. While you are out carousing, these men are taking your plane apart and ensuring the engine is running smoother than the legs of the barmaid at the Dog & Duck. Every time one of you chaps calls Bingo Fuel, you get home because some chap checked your fuel gauge was accurate. Every time one of you glances at the Rate of Climb indicator to judge an intercept, you are relying on the chap who tested and zeroed it while you were snoring in your bunk, sleeping off last nights debauch. So, don’t forget that you are part of a team. You may be full of dauntless spirit  up there, but you won’t get anywhere without those chaps on the ground.
Now, let’s talk about tonight’s mission…
Continue reading “Daily Inspections Keep Your Spitfire In Tip-Top Shape”
The Insatiable Hunger Of Paper Shredder-Based Locomotion
We enjoy hacks that combine or alter devices, enhancing (or subverting) their purpose in the process, but [Japhy Riddle] reminds us all that sometimes it’s fun just to enjoy a spectacle. In this case, it’s an old paper shredder given wheels and a continuous line of paper to rip into.
The result is a device demonstrating a shredder-based form of locomotion, noisily pulling itself along by its own insatiable appetite.
It even looks like a robot, even though there’s nothing really going on inside. It just mindlessly and noisily consumes, converting paper into shreds, moving inexorably forward and limited only by the supply of paper or the length of its power cable, whichever is shorter. Powerful artistic statement, or simple spectacle? You be the judge.
Want to try your hand at a paper shredder-inspired piece? You can take artistic inspiration from the stock tracker that literally shreds your money when the market is down, or if you’re more interested in the worky bits, make your own shredder from LEGO.
Continue reading “The Insatiable Hunger Of Paper Shredder-Based Locomotion”
Designing A PCB GPS Antenna From Scratch
These days, when it comes to GPS devices the antenna is typically part of the package. But what better opportunity for [Pepijn] to learn how to make a GPS antenna from scratch for a badge add-on?
A patch antenna is an antenna of a flat design, which [Pepijn] was going to put directly on a PCB. However, there was added complexity due to GPS being a circularly polarized signal, and that meant doing some research.
Sadly, nowhere did [Pepijn] encounter a straightforward reference design or examples, but in the end success came from going with a truncated corner patch antenna design and using simulation software to figure out exactly what dimensions were needed. (The openEMS free simulation software didn’t bring success, but the non-free Sonnet with a trial license did the trick.) The resulting PCB may not look particularly complex, but every detail matters in such designs.
KiCad handled the PCB CAD design but the prototype came from cutting the PCB on a CNC machine instead of having it fabricated and shipped; a much cheaper and faster option for those with access to the right tools. A bit more testing had the prototype looking good, but the real proof came when it successfully received GPS signals and spewed valid NMEA messages. The design files are on GitHub but as [Pepijn] says, the project was about the journey more than anything else.
2023 Halloween Hackfest: A Spooky “Severance” Speaker
If you know, you know. After becoming fully engrossed in the sci-fi psycho-thriller “Severance“, [Ben Brooks] absolutely needed to have a version of the ominous speaker known as the Board.
This speaker represents the Board, who is the enigmatic governing body of Lumon Industries, the fictional and gigantic biotechnology company featured in the show.
The Board cultivates an air of mystery by rarely speaking, and when it does, it speaks through a single person who paraphrases the Board’s responses. The audio that comes out is a mix of the show’s theme song, pertinent show quotes, and static.
The guts of this freaky little thing are pretty simple — an ESP8266, a DF Player Mini, and a couple of small speakers. In fact, [Ben] had all the parts leftover from a previous home automation project, including the PCB.
Although the original plan was to program it in Arduino, [Ben] ended up using ESPHome to make it easier to integrate with sensors for the big night. Be sure to check out the demo video after the break.
We’ve seen a few fun hacks for the porch this year, including the treat trough of terror and this Ouija robot that out-creeps the real thing.
Continue reading “2023 Halloween Hackfest: A Spooky “Severance” Speaker”
2023 Hackaday Supercon Badge: Welcome To The Vectorscope
This year, the Supercon badge goes analog! (Or at least fakes it pretty convincingly.) Taking inspiration from the phosphor scopes of yesteryear, the 2023 Vectorscope badge is part analog audio playground, part art project, and all about prototyping. Who doesn’t like the warm glow and lovely green fade of an old Tektronix tube scope? That’s what we’re after.
Conceptually, the badge is two separate devices in one. Most obvious is the vectorscope, which takes in voltages in the 0 V – 3 V range and plots them out in X-Y mode in glorious fake-phosphor effect on the lovely round IPS screen. We’ve also tied an audio amplifier to the Y input that plays whatever waveform you’re watching.
But you don’t have to bring your own waveforms with you – the other half of the badge is an arbitrary programmable waveform generator that drives two channels. Off the bat, it’s configurable with the front panel controls, so you’re obviously invited to make Lissajous figures and store them in the program memories.
Combining the two halves lets you draw in voltages and time, but not until you connect them together, naturally. You see, this isn’t an analog simulation – it’s the programmable equivalent of the real deal, courtesy of the AK4619 ADC/DAC. Voltages go out on one set of pins and come back in on the other.
And you get to play around with these voltages in through-hole space too, because we’ve included a very generous prototyping board for your analog explorations. Does this instantly suggest a curve tracer to you? Be our guest! Other forms of analog video-mangling? We want to see what you come up with. Make an audio filter and watch it work on the screen in front of your very eyes.
Of course we’re not leaving you code monkeys out in the cold. MicroPython puts the “programming” in the programmable waveform generator. If you’re not content with the four stock waveforms, you’re invited to write your own. And this is where it gets artsy.
You can upload your own repetitive waveforms to the onboard direct digital synth routine, but why stop there? We’ve left most of the processing power of the underlying RP2040 untouched, for you to use. And four buttons on the front panel let you store and play back your code, so you have space to stash your demos, and a sweet joystick with a custom keycap gives you control.
Continue reading “2023 Hackaday Supercon Badge: Welcome To The Vectorscope”
Vector Network Analyzer Demo And Teardown
[Kerry Wong], ever interested in trying out and tearing down electrical devices, demonstrates and examines the SV 6301a Handheld Vector Network Analyzer. He puts the machine through its paces, noting that the 7 inch touchscreen is a pretty nice feature for those whose eyesight isn’t quite what it used to be.
The internals are similar to the nanoVNA-F V3, but not identical.
What’s a Vector Network Analyzer (VNA)? It’s not for testing Ethernet or WiFi. It’s aimed at a more classical type of “network”. The VNA tests and evaluates characteristics of electrical networks, especially as related to RF and microwave.
It provides detailed information about properties across a specified frequency range, making it an indispensable tool for advanced work. Tektronix has a resource page that goes into detail about exactly what kinds of things a VNA is good for.
[Kerry] shows off a few different features and sample tests before pulling the unit apart. In the end, he’s satisfied with the features and performance of the device, especially the large screen and sensible user interface.
After all, not every piece of test equipment does a great job at fulfilling its primary function, like the cheap oscilloscope that was a perhaps a little too cheap.
Continue reading “Vector Network Analyzer Demo And Teardown”
