3D Printed Stamp Rollers
If you have an artistic bent, you might have seen self-inking stamp rollers. These are like rotary rubber stamps that leave a pattern as you roll across a page. [Becky] wanted a larger custom roller and turned to 3D printing to make it happen. The first prototype used a modified Sharpie. However, she soon moved to an unmodified acrylic marker that had a rectangular tip.
A Tinkercad design produces a cap that fits the marker and a wheel that contains the desired pattern. Text works well, although you can easily do a custom pattern, too, of course.
Continue reading “3D Printed Stamp Rollers”
Using Nuclear Decay As Random Number Generator Source For An MCU
Although there are many ways to get a random number generator (RNG) set up on a microcontroller, it’s hard to argue with the sheer randomness of the various kinds of radiation zipping all around us from nuclear decay events. For [gbonacini] the purchase of a Geiger counter first in 2022 was the reason to tinker with using these as the source for an RNG, which simply runs a counter until a Geiger counter event occurs that ‘selects’ a number and the counter is reset to zero.
With the next version of this system the hardware and layout has changed somewhat, using a commercial handheld Geiger counter (GMC-320+) and its audio output as a generic input for any MCU. The (pulsed) audio signal is amplified with an opamp (left unspecified) that connects to a GPIO pin of the MCU (RP2040-based Pico W). Here the same algorithm is used to create a continuous queue of randomly picked numbers, which can also be queried via the WiFi interface with a custom protocol, essentially making it a network-connected RNG that could be used by other network-connected appliances.
C++ source is provided for the Pico W example, but it should be easy enough to adapt to other platforms. The GMC-320+ is also among the more affordable Geiger counters out there, even if it’s somewhat bulky to pair with just a single MCU, making a more basic Geiger counter module better for a permanent installation. Either way you should get pretty good RNG this way without splurging on exotic hardware.
Thanks to [navigator] for the tip.
Obsolete E-Reader Gets New Life
For those who read often, e-readers are a great niche device that can help prevent eye fatigue with their e-ink displays especially when compared to a backlit display like a tablet or smartphone, all while taking up minimal space unlike a stack of real books. But for all their perks, there are still plenty of reasons to maintain a library of bound paper volumes. For those who have turned back to books or whose e-readers aren’t getting the attention they once did, there are plenty of things to do with them like this e-book picture frame.
The device started life as a PocketBook Basic Touch, or PocketBook 624, a fairly basic e-reader from 2014, but at its core is a decent ARM chip that can do many more things than display text. It also shipped running a version of Linux, which made it fairly easy to get a shell and start probing around. Unlike modern smart phones this e-reader seems to be fairly open and able to run some custom software, and as a result there are already some C++ programs available for these devices. Armed with some example programs, [Peter] was able to write a piece of custom software that displays images from an on-board directory and mounted the new picture display using an old book.
There were a number of options for this specific device that [Peter] explored that didn’t pan out well, like downloading images from the internet to display instead of images on the device, but in the end he went with a simpler setup to avoid feature creep and get his project up and running for “#inktober”, a fediverse-oriented drawing challenge that happened last month. While not strictly in line with a daily piece of hand-drawn artwork, the project still follows the spirit of the event. And, for those with more locked-down e-readers there’s some hope of unlocking the full functionality of older models with this FOSS operating system.
Hot Wheel Car Becomes 1/64 Scale Micro RC Car, Complete With Camera
If you enjoy watching skilled assembly of small mechanical systems with electronics to match, then make some time to watch [Max Imagination] transform a Hot Wheels car into a 1/64th scale RC car complete with video FPV video feed. To say the project took careful planning and assembly would be an understatement, and the results look great.
The sort of affordable electronics available to hobbyists today opens up all kinds of possibilities, but connecting up various integrated modules brings its own challenges. This is especially true when there are physical constraints such as fitting everything into an off-the-shelf 1/64 scale toy car.
There are a lot of interesting build details that [Max] showcases, such as rebuilding a tiny DC motor to have a longer shaft so that it can drive both wheels at once. We also liked the use of 0.2 mm thick nickel strips (intended for connecting cells in a battery pack) as compliant structural components.
There are actually two web servers being run on the car. One provides an interface for throttle and steering (here’s the code it uses), and the other takes care of the video feed with ESP32-CAM sending a motion jpeg stream. [Max]’s mobile phone is used to control the car, and a second device goes into an old phone-based VR headset to display the FPV video feed.
Circuit diagrams and code are available for anyone wanting to perhaps make a similar project. We’ve seen micro RC builds of high quality before, but integrating an FPV camera kicks things up a notch. Want even more complex builds? All the rules change when weight reduction is a non-negotiable #1 priority. Check out a micro RC plane that weighs under three grams and get a few new ideas.
Continue reading “Hot Wheel Car Becomes 1/64 Scale Micro RC Car, Complete With Camera”
Vectorscope KiCad Redrawing Project
When I saw this year’s Supercon Vectorscope badge, I decided that I had to build one for myself. Since I couldn’t attend in-person, I immediately got the PCBs and parts on order. Noting that the GitHub repository only had the KiCad PCB file and not the associated schematics and project file, I assumed this was because everyone was in a rush during the days leading up to Supercon weekend. I later learned, however, that there really wasn’t a KiCad project — the original design was done in Circuit Maker and the PCB was converted into KiCad. I thought, “how hard can this be?” and decided to try my hand at completing the KiCad project.
Fortunately I didn’t have to start from scratch. The PCB schematics were provided, although only as image files. They are nicely laid out and fortunately don’t suffer the scourge of many schematics these days — “visual net lists” that are neither good schematics nor useful net lists. To the contrary, these schematics, while having a slightly unorthodox top to bottom flow, are an example of good schematic design. Continue reading “Vectorscope KiCad Redrawing Project”
Watch Time Roll By On This Strange, Spiral Clock
[Build Some Stuff] created an unusual spiral clock that’s almost entirely made from laser-cut wood, even the curved and bendy parts.
The living hinge is one thing, but getting the spacing, gearing, and numbers right also takes work.
The clock works by using a stepper motor and gear to rotate the clock’s face, which consists of a large dial with a spiral structure. Upon this spiral ramp rolls a ball, whose position relative to the printed numbers indicates the time. Each number is an hour, so if the ball is halfway between six and seven, it’s 6:30. At the center of the spiral is a hole, which drops the ball back down to the twelve at the beginning of the spiral so the cycle can repeat.
The video (embedded below) demonstrates the design elements and construction of the clock in greater detail, and of particular interest is how the curved wall of the spiral structure consists of a big living hinge, a way to allow mostly rigid materials to flex far beyond what they are used to. Laser cutting is well-suited to creating living hinges, but it’s a technique applicable to 3D printing, as well.
Thanks to [Kelton] for the tip!
Continue reading “Watch Time Roll By On This Strange, Spiral Clock”
JawnCon 0x0: A Strong Start With A Bright Future
Last month, I had the pleasure witnessing a birth. No, not of a child. What I’m talking about is something far rarer, though arguably, just as loud and danger fraught — the birth of a new hacker convention.
The very first JawnCon took place on October 19th and 20th at Arcadia University, just outside of Philadelphia. If you’re in the Northeast US and suddenly find yourself surprised to learn that a hacker con managed to slip under your radar, don’t be. The organizers, who previously helped launch the WOPR Summit back in 2019, wisely decided to keep the scale of this first outing in check. Just a single track of talks, a chill out room, and 130 or like-minded individuals.
Although, even if they’d hatched a more ambitious plan, it’s hard to imagine they’d have had enough time to pull it off. Due to various circumstances, JawnCon had to come together at a breakneck pace, with less than 100 days separating the con’s inception and kickoff. That an event such as this could not only be organized so quickly, but go off without a hitch, is a testament to the incredible folks behind the scenes.
As for what a Jawn is…well, that might take a bit more explaining. It’s regional slang that’s perhaps best described as a universal noun in that it can be used to refer to basically anything or anyone. Think “smurf” or “da kine”. According to organizer Russell Handorf, the all-encompassing nature of the word describes not only his personal ethos but the spirit of the event. Rather than focusing too closely on any one aspect of hacking, JawnCon set out to explore a diverse array of tech topics from both the new and old schools. It would be an event where you could listen to a talk on payphone remote management, try your hand at lock picking, and learn about the latest in anti-drone technology, all under the same roof.
To that end, the team did an incredible job. Everyone I spoke to, young or old, newbie or vet, had a fantastic time. What’s more, as revealed in the Closing Remarks, the con actually managed to stay in the black — no mean feat for a first attempt. With a little luck, it seems like JawnCon is well on its way to becoming one of the Northeast’s can’t-miss hacker events. Continue reading “JawnCon 0x0: A Strong Start With A Bright Future”
