Retro Inspired Cyberdeck Scrolls Around Cyberspace
It’s difficult to nail down exactly what counts as a “real” cyberdeck in this brave new era of bespoke computing. But at the minimum, most in the community would agree that a proper deck should have a non-traditional form factor, and be designed to meet the unique needs of the builder. If you’re looking for a fantastic example of both concepts, check out the Cyberdore 2064 from [Tommi L].
At first glance the 3D printed enclosure of the Cyberdore looks a bit like a Speak & Spell, but it’s really more of an amalgamation of everything that made 1980s computers so unique. You’ve got the vents, the chunky switches, the undersized display, and of course, the handle. The case might have been extruded in 2024, but it’s doing a fantastic impression of a piece of tech from 40 years ago.
One of the key external features of the Cyberdore 2064 is the side-mounted rotary encoder that allows for smoothly scrolling through online feeds (such as your favorite hardware hacking site) or long documents. The cheap and easy to work with KY-040 encoder has been converted to a USB input device by way of a Pi Pico, and has been paired with an over-sized 3D printed knob that really makes this build stand out — not only visually, but in terms of usability. These cyberdeck builds often rely on touch screens for input, but we always appreciate a physical interface.
Under the hood you’ve got a Raspberry Pi Zero and an 18650 cell to keep the whole thing running while on the go. Though the Zero is certainly showing its age compared to the more modern variants of the Pi, for a device like this, raw computing power isn’t really the driving concern. A mechanical keyboard usually rounds out these cyberdeck builds, but in this case, [Tommi] went with a fairly common Rii 518BT portable board that’s been skillfully integrated into the front of the Cyberdore.
All of the STL files necessary to print out your own Cyberdore 2064 are available on Printables, and while [Tommi] didn’t exactly provide build instructions, the write-up provides plenty of information to get you started.
So is it just us, or does looking at Cyberdore 2064 make you think it’s time for another Hackaday Cyberdeck Challenge?
Pnut: A Self-Compiling C Transpiler Targeting Human-Readable POSIX Shell
Shell scripting is one of those skills that are absolutely invaluable on especially UNIX and BSD-based systems like the BSDs, the two zillion Linux distributions as well as MacOS. Yet not every shell is the same, and not everybody can be bothered to learn the differences between the sh, bash, ksh, zsh, dash, fish and other shells, which can make a project like Pnut seem rather tempting. Rather than dealing with shell scripting directly, the user writes their code in the Lingua Franca of computing, AKA C, which is then transpiled into a shell script that should run in any POSIX-compliant shell.
The transpiler can be used both online via the main Pnut website, as well as locally using the (BSD 2-clause) open source code on GitHub. Here the main limitations are also listed, which mostly concern the C constructs that do not map nicely to a POSIX shell. These are: no support for floating point numbers and unsigned integers, no goto and switch nor taking the address of a variable with &. These and preprocessor-related limitations and issues are largely to be expected, as especially POSIX shells are hardly direct replacements for full-blown C code.
As a self-professed research project, Pnut seems like an interesting project, although if you are writing shell scripts for anything important, you probably just want to buckle down and learn the ins and outs of POSIX shell scripting and beyond. Although it’s a bit of a learning curve, we’d be remiss if we said that it’s not totally worth it, if only because it makes overall shell usage even beyond scripting so much better.
Hacking An IoT Camera Reveals Hard-Coded Root Password
Hacking — at least the kind where you’re breaking into stuff — is very much a learn-by-doing skill. There’s simply no substitute for getting your hands dirty and just trying something. But that doesn’t mean you can’t learn something by watching, with this root password exploit on a cheap IP video camera being a good look at the basics.
By way of background on this project, [Matt Brown] had previously torn into a VStarcam CB73 security camera, a more or less generic IP camera that he picked up on the cheap, and identified a flash memory chip from which he extracted the firmware. His initial goal was to see if the camera was contacting sketchy servers, and while searching the strings for the expected unsavory items, he found hard-coded IP addresses plus confirmation that the camera was running some Linux variant.
With evidence of sloppy coding practices, [Matt] set off on a search for a hard-coded root password. The second video covers this effort, which started with finding UART pins and getting a console session. Luckily, the bootloader wasn’t locked, which allowed [Matt] to force the camera to boot into a shell session and find the root password hash. With no luck brute-forcing the hash, he turned to Ghidra to understand the structure of a suspicious program in the firmware called encoder. After a little bit of poking and some endian twiddling, he was able to identify the hard-coded root password for every camera made by this outfit, and likely others as well.
Granted, the camera manufacturer made this a lot easier than it should have been, but with a lot of IoT stuff similarly afflicted by security as an afterthought, the skills on display here are probably broadly applicable. Kudos to [Matt] for the effort and the clear, concise presentation that makes us want to dig into the junk bin and get hacking.
Continue reading “Hacking An IoT Camera Reveals Hard-Coded Root Password”
Manually Computing Logarithms To Grok Calculators
Logarithms are everywhere in mathematics and derived fields, but we rarely think about how trigonometric functions, exponentials, square roots and others are calculated after we punch the numbers into a calculator of some description and hit ‘calculate’. How do we even know that the answer which it returns is remotely correct? This was the basic question that [Zachary Chartrand] set out to answer for [3Blue1Brown]’s Summer of Math Exposition 3 (SoME-3). Inspired by learning to script Python, he dug into how such calculations are implemented by the scripting language, which naturally led to the standard C library. Here he found an interesting implementation for the natural algorithm and the way geometric series convergence is sped up.
The short answer is that fundamental properties of these series are used to decrease the number of terms and thus calculations required to get a result. One example provided in the article reduces the naïve approach from 36 terms down to 12 with some optimization, while the versions used in the standard C library are even more optimized. This not only reduces the time needed, but also the memory required, both of which makes many types of calculations more feasible on less powerful systems.
Even if most of us are probably more than happy to just keep mashing that ‘calculate’ button and (rightfully) assume that the answer is correct, such a glimpse at the internals of the calculations involved definitely provides a measure of confidence and understanding, if not the utmost appreciation for those who did the hard work to make all of this possible.
A Lenticular Clock Spells Out The Hours
So many are the clock projects which cross the Hackaday threshold, that it’s very rare indeed to see something that hasn’t already been done. We think we’ve not seen a lenticular clock before though, and we’re thus impressed by this one produced by [Moritz Sivers].
You may well be familiar with lenticular images from toys and novelties, an animation is sliced into lines and placed behind an array of multi-faceted linear lenses. It gives the effect of movement as from different viewing angles a different frame of the animation is perceived. In this clock the animation is replaced by the clock digits, and by rotating the whole with a servo driven by an ESP8266 microcontroller it can display different digits to the viewer. The write-up and the video below are of value both for the clock itself and the description of how these animations are produced. The clock itself doesn’t sacrifice usability for all its novelty, and we can see this technique might find a place in other projects requiring custom displays.
The lenticular lenses used here are off the shelf, but if you are of an adventurous mind, you could try printing some of your own.
Continue reading “A Lenticular Clock Spells Out The Hours”
A 3D-printed puzzle for the visually impaired. The pieces have both a texture and a slant.
A Puzzle For The Visually Impaired, Or Blindfolded
There’s no reason why a visually impaired person can’t enjoy putting together a jigsaw puzzle. It just needs to look a little different. Or, in this case, feel different.
16-year-old [feazellecw] has come up with just the solution — a puzzle with pieces that have both a defining texture and a slant in the z-height to them. While there is no picture on the puzzle face to speak of, instead there is a satisfying end result. You could change it up and add a relief image if you wanted, as long as you still observed the diagonal lines, the z-slant, and the little hole in the bottom that helps differentiate it from the top.
As [feazellecw] says, it’s important to find a box to help keep the pieces together during assembly; a 3D-printed box would be a nice touch. Files for this 15-piece puzzle are available if you’d like to make one for yourself or someone else, but just the idea might inspire you to make your own variant.
Don’t like putting puzzles together? Build a robot to do it for you.
FLOSS Weekly Episode 793: Keeping An Eye On Things With Hilight.io
This week Jonathan Bennett and Aaron Newcomb chat with Jay Khatri, the co-founder of Highlight.io. That’s a web application monitoring tool that can help you troubleshoot performance problems, find bugs, and improve experiences for anything that runs in a browser or browser-like environment. Why did they opt to make this tool Open Source? What’s the funding model? And what’s the surprising challenge we tried to help Jay solve, live on the show? Listen to find out!
Continue reading “FLOSS Weekly Episode 793: Keeping An Eye On Things With Hilight.io”
