Abusing DuckDB-WASM To Create Doom In SQL
These days you can run Doom anywhere on just about anything, with things like porting Doom to JavaScript these days about as interesting as writing Snake in BASIC on one’s graphical calculator. In a twist, [Patrick Trainer] had the idea to use SQL instead of JS to do the heavy lifting of the Doom game loop. Backed by the Web ASM version of  the analytical DuckDB database software, a Doom-lite clone was coded that demonstrates the principle that anything in life can be captured in a spreadsheet or database application.
Rather than having the game world state implemented in JavaScript objects, or pixels drawn to a Canvas/WebGL surface, this implementation models the entire world state in the database. To render the player’s view, the SQL VIEW feature is used to perform raytracing (in SQL, of course). Any events are defined as SQL statements, including movement. Bullets hitting a wall or impacting an enemy result in the bullet and possibly the enemy getting DELETE-ed.
The role of JavaScript in this Doom clone is reduced to gluing the chunks of SQL together and handling sprite Z-buffer checks as well as keyboard input. The result is a glorious ASCII-based game of Doom which you can experience yourself with the DuckDB-Doom project on GitHub. While not very practical, it was absolutely educational, showing that not only is it fun to make domain specific languages do things they were never designed for, but you also get to learn a lot about it along the way.
Thanks to [Particlem] for the tip.
Black and white photo of Evertop computer on desk
The Evertop: A Low-Power, Off-Grid Solar Gem
When was the last time you saw a computer actually outlast your weekend trip – and then some? Enter the Evertop, a portable IBM XT emulator powered by an ESP32 that doesn’t just flirt with low power; it basically lives off the grid. Designed by [ericjenott], hacker with a love for old-school computing and survivalist flair, this machine emulates 1980s PCs, runs DOS, Windows 3.0, and even MINIX, and stays powered for hundreds of hours. It has a built-in solar panel and 20,000mAh of battery, basically making it an old-school dream in a new-school shell.
What makes this build truly outstanding – besides the specs – is how it survives with no access to external power. It sports a 5.83-inch e-ink display that consumes zilch when static, hardware switches to cut off unused peripherals (because why waste power on a serial port you’re not using?), and a solar panel that pulls 700mA in full sun. And you guessed it – yes, it can hibernate to disk and resume where you left off. The Evertop is a tribute to 1980s computing, and a serious tool to gain some traction at remote hacker camps.
For the full breakdown, the original post has everything from firmware details to hibernation circuitry. Whether you’re a retro purist or an off-grid prepper, the Evertop deserves a place on your bench. Check out [ericjenott]’s project on Github here.
Open Source Commercial Synthesisers You Will Love
Drumboy and Synthgirl from Randomwaves are a a pair of compact electronic instruments, a drum machine and a synthesiser. They are commercial products which were launched on Kickstarter, and if you’re in the market for such a thing you can buy one for yourself. What’s made them of interest to us here at Hackaday though is not their musical capabilities though, instead it’s that they’ve honoured their commitment to release them as open source in the entirety.
So for your download, you get everything you need to build a pair of rather good 24-bit synthesisers based upon the STM32 family of microcontrollers. We’re guessing that few of you will build your own when it’s an easier job to just buy one from Randomwaves, and we’re guessing that this open-sourcing will lead to interesting new features and extensions from the community of owners.
It will be interesting to watch how this progresses, because of course with the files out there, now anyone can produce and market a clone. Will AliExpress now be full of knock-off Drumboys and Synthgirls? It’s a problem we’ve looked at in the past with respect to closed-source projects, and doubtless there will be enterprising electronics shops eyeing this one up. By our observation though it seems to be those projects with cheaper bills of materials which suffer the most from clones, so perhaps that higher-end choice of parts will work in their favour.
Either way we look forward to more open-source from Randomwaves in the future, and if you’d like to buy either instrument you can go to their website.
Thanks [Eilís] for the tip.
To See Within: Detecting X-Rays
It’s amazing how quickly medical science made radiography one of its main diagnostic tools. Medicine had barely emerged from its Dark Age of bloodletting and the four humours when X-rays were discovered, and the realization that the internal structure of our bodies could cast shadows of this mysterious “X-Light” opened up diagnostic possibilities that went far beyond the educated guesswork and exploratory surgery doctors had relied on for centuries.
The problem is, X-rays are one of those things that you can’t see, feel, or smell, at least mostly; X-rays cause visible artifacts in some people’s eyes, and the pencil-thin beam of a CT scanner can create a distinct smell of ozone when it passes through the nasal cavity — ask me how I know. But to be diagnostically useful, the varying intensities created by X-rays passing through living tissue need to be translated into an image. We’ve already looked at how X-rays are produced, so now it’s time to take a look at how X-rays are detected and turned into medical miracles.
Continue reading “To See Within: Detecting X-Rays”
A false colour image of the region of sky containing the CMZ.
Unsolved Questions In Astronomy? Try Dark Matter!
Sometimes in fantasy fiction, you don’t want to explain something that seems inexplicable, so you throw your hands up and say, “A wizard did it.” Sometimes in astronomy, instead of a wizard, the answer is dark matter (DM). If you are interested in astronomy, you’ve probably heard that dark matter solves the problem of the “missing mass” to explain galactic light curves, and the motion of galaxies in clusters.
Now [Pedro De la Torre Luque] and others are proposing that DM can solve another pair of long-standing galactic mysteries: ionization of the central molecular zone (CMZ) in our galaxy, and mysterious 511 keV gamma-rays.
The Central Molecular Zone is a region near the heart of the Milky Way that has a very high density of interstellar gases– around sixty million times the mass of our sun, in a volume 1600 to 1900 light years across. It happens to be more ionized than it ought to be, and ionized in a very even manner across its volume. As astronomers cannot identify (or at least agree on) the mechanism to explain this ionization, the CMZ ionization is mystery number one.
Feynman diagram: Space-time vectors for electron-positron annihilation
Feynman diagram of electron-positron annihilation, showing the characteristic gamma-ray emission.
Mystery number two is a diffuse glow of gamma rays seen in the same part of the sky as the CMZ, which we know as the constellation Sagittarius. The emissions correspond to an energy of 515 keV, which is a very interesting number– it’s what you get when an electron annihilates with the antimatter version of itself. Again, there’s no universally accepted explanation for these emissions.
So [Pedro De la Torre Luque] and team asked themselves: “What if a wizard did it?” And set about trying to solve the mystery using dark matter. As it turns out, computer models including a form of light dark matter (called sub-GeV DM in the paper, for the particle’s rest masses) can explain both phenomena within the bounds of error.
In the model, the DM particles annihilate to form electron-positron pairs. In the dense interstellar gas of the CMZ, those positrons quickly form electrons to produce the 511 keV gamma rays observed. The energy released from this annihilation results in enough energy to produce the observed ionization, and even replicate the very flat ionization profile seen across the CMZ. (Any other proposed ionization source tends to radiate out from its source, producing an uneven profile.) Even better, this sort of light dark matter is consistent with cosmological observations and has not been ruled out by Earth-side dark matter detectors, unlike some heavier particles.
Further observations will help confirm or deny these findings, but it seems dark matter is truly the gift that keeps on giving for astrophysicists. We eagerly await what other unsolved questions in astronomy can be answered by it next, but it leaves us wondering how lazy the universe’s game master is if the answer to all our questions is: “A wizard did it.”
We can’t talk about dark matter without remembering [Vera Rubin].
A Scratch-Built Commodore 64, Turing Style
Building a Commodore 64 is among the easier projects for retrocomputing fans to tackle. That’s because the C64’s core chipset does most of the heavy lifting; source those and you’re probably 80% of the way there. But what if you can’t find those chips, or if you want more of a challenge than plugging and chugging? Are you out of luck?
Hardly. The video below from [DrMattRegan] is the first in a series on his scratch-built C64 that doesn’t use the core chipset, and it looks pretty promising. This video concentrates on building a replacement for the 6502 microprocessor — actually the 6510, but close enough — using just a couple of EPROMs, some SRAM chips, and a few standard logic chips to glue everything together. He uses the EPROMs as a “rulebook” that contains the code to emulate the 6502 — derived from his earlier Turing 6502 project — and the SRAM chips as a “notebook” for scratch memory and registers to make a Turing-complete random access machine.
[DrMatt] has made good progress so far, with the core 6502 CPU built on a PCB and able to run the Apple II version of Pac-Man as a benchmark. We’re looking forward to the rest of this series, but in the meantime, a look back at his VIC-less VIC-20 project might be informative.
Continue reading “A Scratch-Built Commodore 64, Turing Style”
