Running Zork On The Steam Controller
The Steam Controller is a device capable of many interesting feats. It’s intended to act simply as an input device, and yet, it can run games all on its own. As [Owen Feldman] has demonstrated, by having the Steam Controller play Zork.
[Owen] took quite an interesting route to get the there: he wrote a Rust program to emulate the Intel 8080 CPU and CP/M, as one does. This was ported to the Steam Controller, which emulates the CPU and memory on its own internal processor. I/O is streamed over USB, since the Steam Controller lacks a keyboard or screen. The CP/M disk lives in the controller, but the Zork disk data is streamed over USB as well.
If you’re wondering how [Owen] got all this running on the controller, he explains on his personal website. He used what appears to be an undocumented tool included with Steam that allows flashing firmware on the device. Helpfully, Valve also include the original firmware in the same folder, unsigned and only relying on a simple CRC checksum. [Owen] bricked his controller a couple times experimenting with this tool and loading his own firmware, but all came good in the end.
The Steam Controller is probably the oddest device to run CP/M for a while, but hey—it’s a neat party trick. Not much is going to top the auto-docking hack from a few months ago, though.
Continue reading “Running Zork On The Steam Controller” →
Superconducting Temperature Record Set At Ambient Pressure
An interesting type of superconductors available to us today are the ones that achieve this property at room temperature, with only the small snag that they require crushing pressures that would render biological lifeforms into a very thin layer of molecules. What these however suggest is that something in these materials changes at these high pressures, and if we could retain that state upon releasing said pressure, we might be able to have our superconducting cake and eat it too.
This is effectively what researchers recently achieved, with a research article in PNAS Physics by [Liangzi Deng] et al. covering the pressure-quench protocol (PQP) that they used for this feat. There is also an associated easy-to-read press release by Argonne National Laboratory (ANL) as well as one by the University of Houston.
Target material was a cuprate, specifically HgBa2Ca2Cu3O8+δ, also known as the HBCCO series or Hg1223 for short. Hg1223 has been the subject of much research and experimentation since the 1990s, with it demonstrating a transition temperature (Tc) of 133 K (-140°C). With this quenching method – which sees the high pressures on the cooled sample suddenly released – this bumped the Tc up to 151 K, or -122°C.
While still a far cry from room temperature superconductors, managing to lock in these superconducting properties at an 18 K higher temperature using a straightforward procedure does raise the prospect of massively reducing the cooling needs for superconductors.
Samsung Printer Is The Next Frontier Of Minecraft Servers
While DOOM remains the undisputed champion of ‘game you play on every piece of hardware’ it seems that the role of ‘game you play on everything just because you can’ is slowly being shifted to Minecraft, as we have yet another Minecraft server somewhere Minecraft has no business being served– in this case, a Samsung Printer.
The hack actually requires opening up the printer to get at the debug ports to bang your way in via serial, but as any security expert will tell you, once the black hats have physical access to a machine, they own it. That isn’t to say it’s easy– [vimpo] had to dump the firmware and find an exploit. Since it’s 2026 [vimpo] tried to get an LLM to do all that hard work for him, and while it helped with identifying functions in the dump, ultimately the hacking still fell upon [vimpo]’s human intelligence, though not before burning through millions of tokens.  Having found a good old fashioned UDP overflow exploit, he’s gets control of the printer and puts an improved version of his lightweight Minecraft server, UCraft, on it.  Like the server, the exploit is also on GitHub but you’ll very likely need the exact same printer to get it to work: a Samsung C410W with firmware V3.00.02.20, DEC-15-2015. One important caveat is that while you can still use the printer as intended after this hack, you cannot do so while playing Minecraft: it crashes the server if you try. Good to know.
In case you’re wondering, yes, this is the same guy who got a Minecraft server running on a light-bulb, which arguably more impressive. Where he might mine and/or craft next is anybody’s guess. Somebody else already did the ESP32-C3, and while we suspect nothing will ever beat the 1960s Univac implementation for sheer impracticality, we’re willing to be surprised.
Continue reading “Samsung Printer Is The Next Frontier Of Minecraft Servers” →
Homebrew 68K Machine Has A PCI Bus
The Peripheral Component Interconnect (PCI) bus was first introduced all the way back in 1992. It quickly became the standard way to interface add-on cards on the PC platform, supplanting earlier buses like ISA and various other oddball standards. You wouldn’t expect to see a PCI bus on a Motorola-based machine, but [maniek86]’s homebrew rig offers just that.
That’s a lot of soldering.
This computer is a beautiful piece of homebrew engineering, constructed out of protoboard and loose wires rather than any fancy PCB. At the heart of the build lies a Motorola 68000 running at 10 MHz. It’s got 1 MB of SRAM, 4 KB of ROM, and a MC68681P acting as a UART, timer source, and I/O controller. Where things get special, though, is in the inclusion of a Xilinx Spartan II FPGA (XC2S100), which acts as a PCI bridge. It provides the machine with two 32-bit 5-volt PCI slots which are interrupt capable, albeit with no bus mastering. A XC95144XL CPLD also sits present to act as glue logic to help lace everything together.
[maniek86] does a great job of explaining exactly why the PCI bus was hard to implement, and how it was pulled off in the end. The guide also covers how the system was able to interface various cards, from a PCI serial expansion to a Cirrus VGA adapter. It’s all good stuff.
We’ve featured other work from [maniek86] before, too, like this brilliant 486-based single-board computer. Video after the break.
Continue reading “Homebrew 68K Machine Has A PCI Bus” →
Foldable OLED Displays And The Bane Of Dust
Much like Apple’s once vaunted super-slim butterfly keyboard, today’s range of portable devices featuring flexible OLED displays – which can fold said display into a much smaller form factor – are a marvel of engineering.
The foldable phone after a dusty encounter. (Credit: iFixit, YouTube)
Unfortunately engineering can only do so much against fundamental flaws. In the case of both these flexible OLEDs and butterfly keyboards the main issue is that of dust intrusion, with a recent teardown by [iFixit] going over the reasons for this.
As test subject we got a Galaxy Z Fold 8, as an example of a modern-day foldable smartphone-tablet hybrid. This phone has an IP48 rating, meaning that it’s water-resistant, but not dust-resistant for particles smaller than 1 mm. To test this, [iFixit] used UV-reactive dust particles, making sure that they got literally everywhere inside the phone’s hinge mechanism.
After this treatment, trying to fold the phone caused the hinge mechanism to make absolutely horrific crunching noises, confirming that it’s reached dust-under-butterfly-keycap levels of unusable. During the subsequent teardown a quick pass with the UV lamp showed that not much of the dust had penetrated into the two halves of the device at least, but the hinge mechanism wasn’t as lucky.
Getting to the hinge is sadly rather destructive, as it involves removing the flexible OLED. Once the hinge was exposed and subjected to UV light the spectacle was something to marvel at, as can be seen in the above screenshot. With the dust caking literally every part of the mechanism, it was little wonder that the hinge had ceased to work.
Although this was obviously an extreme case of dust exposure, and the average flexible OLED screen’s hinge won’t see nearly as much dust, one can’t help but feel slightly disconcerted at that crunching noise, knowing that it’s just one big dust exposure away.
Continue reading “Foldable OLED Displays And The Bane Of Dust” →
Art of 3D printer in the middle of printing a Hackaday Jolly Wrencher logo
3D Printering: Why Is My PLA So Brittle?
Over the years poly(lactic acid) (PLA) – also known as polylactide – has become a popular thermoplastic for a variety of reasons. One of these reasons is that it’s easily produced from a renewable resource, i.e. lactic acid, with the resulting polymer even being compostable if you assume that your compost pile hits a steady 65°C or more, well above the polymer’s glass transition temperature (Tg).
That said, PLA by itself is a pretty crummy material, being exceedingly brittle and inferior to common alternatives like PET(G) in many metrics. Over the decades much research has gone into figuring out this material, its amorphous and crystalline states, as well as how to use plasticizers, copolymers, mechanical manipulation and PLLA/PDLA blends to produce more useful variants of PLA.
Today’s spools of thermoplastic filament that gets marketed as ‘PLA’ are the result of such engineering, though with plenty of remaining issues, as anyone who has struggled through a spool of brittle PLA filament can attest to. Although you can find plenty of tips online about how you should ‘just’ toss said spool into an filament dryer, oven or similar to bake it – with accusing fingers pointed at moisture intrusion, hydrolysis and kin – it helps to understand the fundamentals of how PLA works, and how it degrades.
Continue reading “3D Printering: Why Is My PLA So Brittle?” →
Miniaturizing The Atari 2600 Console
For as popular as Atari was in their heyday, it wasn’t until well after they were on their famous decline that they released their first handheld, the Atari Lynx. In retrospect, competing with the Game Boy was not going to be a recipe for success even without considering their other problems as a company, and as a result was their penultimate console before exiting the market completely. But [Nick]’s most recent project asks what the world would have been like with an Atari handheld from their golden era, and has been working on this miniaturized version of the 2600.
Unlike any modern emulators which can easily handle Atari 2600 games in almost any form factor today, this console is doing it all with as much original hardware as possible. It uses much smaller switches and buttons compared to the original, and omits some other unnecessary hardware for today’s world like the RF modulator. [Nick] has also designed a custom PCB that reduces the overall footprint considerably as well, and has relocated the cartridge port in preparation for its eventual handheld shape. The result is a console using original hardware that’s less than half the footprint of the original.
Although there were around 30 million Atari 2600 consoles sold and the system is unlikely to be a real collector’s item anytime soon, [Nick] makes sure to note that no real 2600 hardware was harmed in this build. And, as far as its handheld nature, this is a stepping stone on the path to that eventual goal. We’ll look forward to an eventual system that integrates a screen and controller as well as a port for the original cartridges. In the meantime, here’s another handheld 2600 that fits completely inside one of those cartridges.
Continue reading “Miniaturizing The Atari 2600 Console” →
