What do you get when you put together a husband/wife team of a machinist and mechanical engineer? If you’re [Matt and Michelle Hertel], you get a 5 axis CNC, which we think was one of the hidden gems at Maker Faire NY.
Hobby CNC machines have grown by leaps and bounds over the last few years. Nearly all these machines have been 3 axis (X,Y,Z). 5 (and more) axis machines have been around for years in the industrial world. These higher level machines never have made the jump to the hobby/home shop world.
The P5’s two extra axis allow for extremely complex parts to be created in one setup. A good example of this would be a turbine wheel. Compound curves on (and behind) each blade would make this an impossible job for a 3 axis CNC. The P5 was machining these parts all weekend at Maker Faire NY. Even more impressive is the fact that it was cutting Delrin, not wax.
Continue reading “PocketNC P5 Takes Desktop CNC To The 5th Dimension”
