Caption CERN Contest Is A GO For Week 9
Thanks for another week of great entries in the Caption CERN Contest over at Hackaday.io! We still aren’t sure if our CERN staffer is looking at that machine pensively, amorously, or with a bit of confusion, but you all found some great words to go with the image!
The Funnies:
  • “Dr. Breman’s early attempts to create the perfect robot woman had some early success, but was later scrapped do to a tragic input/output error.” – Terry Davis
  • “You were supposed to be intelligent, my dear. What do you mean by segfault?” –elias.alberto
  • “CERN’s pioneering computer dating service didn’t quite work out as expected.” – Nick Johnson
The winner for this week is Stripeytype with the quote seen in the top image of this article. Stripeytype will be sporting a CRT head T-Shirt From The Hackaday Store at their next hackerspace meeting.
cern-9-smWe’re not done searching out they mysteries of CERN’s history. Week 9 of the Caption CERN Contest has just begun!
Some of CERN’s experiments take place in the miles of tunnels below their labs in and around Meyrin, on the border of France and Switzerland. It looks like this image was taken in one of those tunnels. It’s definitely an interesting shot. CERN’s documentation for the image has been lost to history, so it’s up to you to explain what’s going on here! Add your humorous caption as a comment to the project log. Make sure you’re commenting on the log, not on the project itself. As always, if you actually have information about the image or the people in it, let CERN know on the original image discussion page.
Good Luck!
More MRRF, This Time A Roundtable
Ah, you thought we were done with our coverage of the Midwest RepRap Festival, didn’t you? No, there’s still more, thanks to [Timothy Koscielny] sending in some digital assets that were required to put this post together. This time, it’s the RepRap roundtable with [Johnny Russell] from Ultimachine, [Shane Graber] from MakerJuice, [Lars Brubaker] from MatterHackers, [Sanjay Mortimer] from E3D-Online.
The first video covers the introductions for these very prominent 3D printer developers and their views on what future advances in 3D printers will be, the differences between Delta, Cartesian, and Polar bots (there aren’t many), and when resin printers will start to pick up.
In the Q&A session, the panel fielded a few questions from the audience. Questions included how to get people into 3D modeling, an amazing question dealing with what we should be making (with the implication that we’re only making stupid plastic trinkets), and what needs work to bring 3D printing to the masses.
Special thanks to [Casey Hendrickson] from ninety two point three WOWO for MC’ing the RepRap roundtable and to [Timothy Koscielny] for the audio work. This isn’t it, though: I still need to dump a bunch of pictures after the break.
Continue reading “More MRRF, This Time A Roundtable”
Building A 20 Inch Disk Sander
A small disk sander is a useful and cheap addition to the shop. For about $100, you can buy a cheap combination 6″ disk/belt sander that’s extremely useful. The size and cost of power tools does not scale linearly, and if you want a big disk sander you might as well make your own.
The motor for this build is a 1kW single phase motor pulled from a floor polisher found in the trash. That’s enough to push a sanding disk around, but when you get to tools this large, you need a good base, good tilt mechanism, and everything should be extremely heavy.
This build meets all those requirements while still using mostly recycled components. The work table is actually made of three pieces of recycled aluminum epoxied together. Yes, you should cringe at this, but it actually makes a little bit of sense: thinner pieces can be cut on a table saw, and if you’re extremely careful during the glue-up, you can cut the mitre slot without a mill. This frame attaches to a frame made from aluminum extrusion and filled with a homebrew epoxy granite mix. Remember, heavy is better here.
In keeping with making a huge disk sander out of stuff pulled out of the trash, the trunnions and motor hub were cast out of aluminum melted in an old propane tank furnace. Once these were cleaned up, a disk was mounted on the hub and trued up in the most unsafe manner possible.
With a few additions including a machined mitre gauge, dust collector, and legs made out of wood that’s far too pretty for a simple shop tool, this huge assemblage of trash turned out to be a great sander. You can see a few videos of it below.
Continue reading “Building A 20 Inch Disk Sander”
Use The Internet To Get Your Kadabra To Evolve
If you grew up playing Pokemon Red or Blue, you might have moved far away from your childhood friends by now. If you’re still playing Pokemon Red or Blue, you can now literally reconnect with these friends using [Pepijn]’s new and improved Game Boy link that lets players trade Pokemon over the internet.
Based on [Pepijn]’s previous work building an Arduino-based Pokemon storage system (which was inspired by a separate project that was able to spoof trades), the device allows a Game Boy (including Pocket, Color, and Advance versions) to connect to the Internet via a Teensy shield. The online waiting room software is called TCPoke which facilitates the Internetting of the Game Boys. From there, all you have to do is connect via the project’s wiki!
The TCPoke software is available on the project’s site. Also, be sure to check out the video below which shows a demonstration of how the software works. There is noticeable delay compared to a direct link between Game Boys, but it functions very well. We didn’t see this link system work for a battle, but it would be interesting to see if it is possible. If so, you might never have to go to a Pokemon League meeting again!
Continue reading “Use The Internet To Get Your Kadabra To Evolve”
A Stack Of Boards For An Edison Breadboard Adapter
The Intel Edison is a neat piece of hardware, but the connector for the Edison is extremely intimidating and the Mini breakout board is incompatible with breadboards. What’s [Federico], a builder of Internet of Things to do? Etch their own breakout board.
The Mini Breakout board for the Intel Edison is the official ‘minimal’ offering for getting the Edison up and running with a mess of jumper wires and LEDs. While this breakout board handles the USB to UART bridge, power regulation, and exposes all the pins on the Edison connector, it is terrible for prototyping. It’s a 4×14 array of holes on a 0.1″ grid that are hidden underneath the Edison.
[Federico] handled this problem with a copper clad board and a little bit of ferric chloride. He jumped into Eagle and created a breakout board to turn the 4×14 pin grid into a more sensible breadboard-friendly layout.
The breadboard-friendly adapter doesn’t have level shifters, but by using the mini-breakout board between the Edison and the breadboard adapter [Federico] still has the UART to USB hardware and a battery charging circuit. Still, there’s room for improvement and we can’t wait to see what he comes up with next.
Temperature, Altitude, Pressure Display
During a recent trip to Bhutan, [electronut] wished for a device that would show the temperature and altitude at the various places he visited in the Kingdom. Back home after his trip, he built this simple Temperature, Altitude and Pressure Display Device using a few off the shelf parts.
Following a brief search, he zeroed in on the BMP 180 sensor which can measure temperature and pressure, and which is available in a break-out board format from many sources. He calculates altitude based on pressure. The main parts are an Arduino Pro Mini clone, a BMP180 sensor and a Nokia 5110 LCD module. A standard 9V battery supplies juice to the device. A push button interface allows him to read the current parameters when pressed, thus conserving battery life.
Standard libraries allow him to interface the LCD and sensor easily to the Arduino. He wrapped it all up by enclosing the hardware in a custom laser cut acrylic box. The result is bigger than he would like it to be, so maybe the next iteration would use a custom PCB and a LiPo battery to shrink it in size. While at it, we think it would be nice to add a RTC and some sort of logging capability to the device so it can store data for future analysis. The schematic, code and enclosure drawing are available via his Github repository.
CRAYFIS Hijacks Our Cellphones For A Worldwide Cosmic Ray Detector
Although scientists have known about Ultra-High Energy Cosmic Rays (UHECRs) for years, nobody can pinpoint their origin. When these UHECRs hit the ground, however, they cause a widespread local disturbance called an air shower. This air shower is a wide dispersion of photons, muons, and electrons at sea level. The means of observing this air shower mandates a widespread geographic region for detecting them. One solution would be a very big detector. Physicists [Daniel] and [Michael] discovered an alternative to pricey hardware, though. By leveraging the CMOS sensors in our smartphones, they can borrow some CPU cycles on our phones to create a worldwide detector network.
According to their paper, the CMOS camera in our smartphones is sensitive to the spectrum of radiation induced by muons and photons from these air showers. With an app running on our phones, [Daniel], [Michael], and other scientists can aggregate the data from multiple detections in a similar region to better understand their origins.
If you’re concerned about CRAYFIS taking away from your talk or web-browsing time, fear not; it runs in the background when a power source has been detected, hopefully, when you are asleep. It’s not the first time we see scientists tap into our computing resources, but this is certainly an achievement made possible in only the last few years by the sensor-loaded smartphone that charges on many of our night stands. With over 1.5 billion smartphones active in the world, we’re thrilled to see a team cleverly leveraging a ubiquitous and already-well-distributed resource.
via [NPR]
