Closeup of WOPR interface on Raspberry Pi
Rebooting WarGames‘ WOPR With A Pi And Gemini
WarGames fans, rejoice: [Nick Bild] has rebooted WOPR for real. In his latest hack, the Falcon, he recreates the iconic AI from the 1983 film using a Raspberry Pi 400, a vintage SP0256-AL2 speech chip from General Instrument, and Google’s Gemini LLM. A build to bring us back to the Reagan-era.
Where most stop at visual homage, this one simulates true interaction. The Python script acts as dungeon master for Gemini 2.5 Flash, guiding it to roleplay as the WOPR computer. Keypress sounds click-clack in synchrony with every input. Gemini replies are filtered into allophones, through GI-Pi, [Nick]’s own Python library. The SP0256 then gives it an eerily authentic robotic voice, straight out of 1983.
[Nick] himself is no unfamiliar name to Hackaday. Back in 2020, he hosted a Hack Chat where he talked us through getting from ideas to prototype builds. He practices what he preaches, since he carried out projects like a breadboard 6502 computer, home-automation controlling AI sunglasses, and more silly inventions, like dazzle-proof glasses.
So… shall we play a game? If you’ve ever longed to chat with an 80s military AI about thermonuclear war or tic-tac-toe without doubting you end the world in a blink, start on this build.
Continue reading “Rebooting WarGames‘ WOPR With A Pi And Gemini”
Legally Distinct Space Invaders Display WiFi Info
In the early 00s there was a tiny moment before the widespread adoption of mobile broadband, after the adoption of home WiFi, and yet before the widespread use of encryption. For this brief time a unique practice arose called wardriving — where people would drive around, document, and use these open wireless networks.
Although the pursuit has diminished with the rise of mobile broadband and WPA encryption, there are still a few use cases for the types of hardware a wardriver would have used. [arduinocelentano] recently built a Wi-Fi strength monitor in this style but with a unique theme.
Continue reading “Legally Distinct Space Invaders Display WiFi Info”
Stephen Hawes operating his LumenPnP
The LumenPnP Pasting Utility: Never Buy Solder Stencils Again?
Over on his YouTube channel the vivacious [Stephen Hawes] tells us that we never need to buy solder stencils again!
A big claim! And he is quick to admit that his printed solder paste isn’t presently quite as precise as solder stencils, but he is reporting good success with his technique so far.
[Stephen] found that he could print PCBs with his fiber laser, populate his boards with his LumenPnP, and reflow with his oven, but… what about paste? [Stephen] tried making stencils, and in his words: “it sucked!” So he asked himself: what if he didn’t need a stencil? He built a Gerber processing, G-code generating, machine-vision implemented… website. The LumenPnP Pasting Utility: https://paste.opulo.io/
Continue reading “The LumenPnP Pasting Utility: Never Buy Solder Stencils Again?”
Soldered RAM Upgrades Finally Available For Mac-PPC
In the retrocomputing world, [DosDude1] is a name spoken with more than a little respect. He’s back again with a long-awaited hack for PowerPC Macintosh: soldered RAM upgrades!
[DosDude1] is no stranger to soldering his way to more storage– upgrading the SSD on an M4 Mac Mini, or doubling  the VRAM on an old GPU. For a PPC Mac, though, it is not enough just to solder more RAM onto the board; if that’s all it was, we’d have been doing it 20 years ago. Once the RAM is in place, you have to have some way to make sure the computer knows the RAM is in place. For a WinTel machine, getting that information to the BIOS can be as easy as plugging in the right resistors. Continue reading “Soldered RAM Upgrades Finally Available For Mac-PPC”
2025 One-Hertz Challenge: A Software-Only AM Radio Transmitter
We’ve been loving the variety of entries to the 2025 One-Hertz Challenge. Many a clock has been entered, to be sure, but also some projects that step well outside simple timekeeping. Case in point, this AM transmitter from [oldradiofixer.]
The software-only transmitter uses an ATTiny85 processor to output an AM radio signal in the broadcast band. It transmits a simple melody that you can tune in on any old radio you might have lying around the house. Achieving this was simple. [oldradiofixer] set up the cheap microcontroller to toggle pin PB0 at 1 MHz to create an RF carrier. Further code then turns the 1MHz carrier on and off at varying rates to play the four notes—G#, A, G#, and E—of the Twilight Zone theme. This is set up to repeat every second—hence, it’s a perfectly valid entry to the 2025 One-Hertz Challenge!
It’s a simple project, but one that demonstrates the basics of AM radio transmission quite well. The microcontroller may not put out a powerful transmission, but it’s funny to think just how easy it is to generate a broadcast AM signal with a bit of software and a length of wire hanging off one pin. Video after the break.
Continue reading “2025 One-Hertz Challenge: A Software-Only AM Radio Transmitter”
One Man’s Trash… Bicycle Edition
[Remy van Elst] found an obsolete bike navigation system, the Navman Bike 1000, in a thrift store for €10. The device was a rebadged Mio Cyclo 200 from 2015. Can a decade-old GPS be useful? Well, the answer depends on a little reverse engineering.
There were some newer maps available, but they wouldn’t download using the official software. Out comes WireShark and mitmproxy. That allowed [Remy] to eavesdrop on what was going on between the box and its home server. From there he could intercept the downloaded software image, which in turn yielded to scrutiny. There was one executable, but since the device mounted as a drive, he was able to rename that executable and put his own in using the same name.
The device turns out to run Windows CE. It could even run DOOM! Once he was into the box with a file manager, it was fairly straightforward to add newer software and even update the maps using OpenStreetMaps.
This is a great example of how a little ingenuity and open source tools can extend the life of consumer electronics. It isn’t always as easy to find an entry point into some device like this. Then again, sometimes it’s a little easier than maybe it should be.
We’d all but forgotten Windows CE. We see many people using WireShark, but fewer running mitmproxy. It sure is useful.
Linux Fu: The Cheap Macropad Conundrum
You can get cheap no-brand macropads for almost nothing now. Some of them have just a couple of keys. Others have lots of keys, knobs, and LEDs. You can spring for a name brand, and it’ll be a good bet that it runs QMK. But the cheap ones? Get ready to download Windows-only software from suspicious Google Drive accounts. Will they work with Linux? Maybe.
Of course, if you don’t mind the keypad doing whatever it normally does, that’s fine. These are little more than HID devices with USB or Bluetooth. But what do those keys send by default? You will really want a way to remap them, especially since they may just send normal characters. So now you want to reverse engineer it. That’s a lot of work. Luckily, someone already has, at least for many of the common pads based around the CH57x chips.
Continue reading “Linux Fu: The Cheap Macropad Conundrum”
