Stovetop Milk Steamer Is Beautiful, Effective
The Moka pot is an industrial design classic, hailing from Italy in the early part of the 20th century. To this day, it remains an excellent way to brew top quality coffee at home with affordable equipment. However, if your tastes for coffee lie more towards lattes than espresso, you’re out of luck – unless you’ve got one of these.
[Create] started with a classic Moka pot for this project, and set out to build a stovetop milk steamer. The top reservoir is quickly cut away, and a tap fitted atop the lower water reservoir. This allows the flow of steam from the lower reservoir to be controlled. A steel pipe is then fitted to the tap, which is bent, crushed, and soldered to form a nozzle for steaming the milk. It’s then finished off with beautiful wooden handles for a nice aesthetic touch.
While we’re not sure the soldering process or tap used are food grade, there are workarounds for that, and it’s a project that could easily be pulled off in a weekend. What’s more, you can celebrate your new creation with a delicious hot cappuccino. What could be better? Now all you need is your own special roast. Video after the break.
[Thanks to Baldpower for the tip!]
Continue reading “Stovetop Milk Steamer Is Beautiful, Effective” →
Cyborg, Or Leafy Sensor Array?
Some plants react quickly enough for our senses to notice, such as a Venus flytrap or mimosa pudica. Most of the time, we need time-lapse photography at a minimum to notice while more exotic sensors can measure things like microscopic pores opening and closing. As with any sensor reading, those measurements can be turned into action through a little trick we call automation. [Harpreet Sareen] and [Pattie Maes] at MIT brought these two ideas together in a way which we haven’t seen before where a plant has taken the driver’s seat in a project called Elowan. Details are sparse but the concept is easy enough to grasp.
We are not sure if this qualifies as a full-fledged cyborg or if this is a case of a robot using biological sensors. Maybe it all depends on which angle you present this mixture of plant and machine. Perhaps it is truly is the symbiotic relationship that the project claims it to be. The robot would not receive any instructions without the plant and the plant would receive sub-optimal light without the robot. What other ways could plants be integrated into robotics to make it a bona fide cyborg?
Continue reading “Cyborg, Or Leafy Sensor Array?” →
Intel Announces Faster Processor Patched For Meltdown And Spectre
Intel just announced their new Sunny Cove Architecture that comes with a lot of new bells and whistles. The Intel processor line-up has been based off the Skylake architecture since 2015, so the new architecture is a fresh breath for the world’s largest chip maker. They’ve been in the limelight this year with hardware vulnerabilities exposed, known as Spectre and Meltdown. The new designs have of course been patched against those weaknesses.
The new architecture (said to be part of the Ice Lake-U CPU) comes with a lot of new promises such as faster core, 5 allocation units and upgrades to the L1 and L2 caches. There is also support for the AVX-512 or Advanced Vector Extensions instructions set which will improve performance for neural networks and other vector arithmetic.
Another significant change is the support for 52-bits of physical space  and 57 bits of linear address support. Today’s x64 CPUs can only use bit 0 to bit 47 for an address space spanning 256TB. The additional bits mean a bump to a whooping 4 PB of physical memory and 128 PB of virtual address space.
The new offering was demoed under the company’s 10nm process which incidentally is the same as the previously launched Cannon Lake. The new processors are due in the second half of 2019 and are being heavily marketed as a boon for the Cryptography and Artificial Intelligence Industries. The claim is that for AI, memory to CPU distance has been reduced for faster access, and that special cryptography-specific instructions have been added.
Electric Drift Trike Needs Water Cooling
Electric vehicles of all types are quickly hitting the market as people realize how inexpensive they can be to operate compared to traditional modes of transportation. From cars and trucks, to smaller vehicles such as bicycles and even electric boats, there’s a lot to be said for simplicity, ease of use, and efficiency. But sometimes we need a little bit more out of our electric vehicles than the obvious benefits they come with. Enter the electric drift trike, an electric vehicle built solely for the enjoyment of high torque electric motors.
This tricycle is built with some serious power behind it. [austiwawa] constructed his own 48V 18Ah battery with lithium ion cells and initially put a hub motor on the front wheel of the trike. When commenters complained that he could do better, he scrapped the front hub motor for a 1500W brushless water-cooled DC motor driving the rear wheels. To put that in perspective, electric bikes in Europe are typically capped at 250W and in the US at 750W. With that much power available, this trike can do some serious drifting, and has a top speed of nearly 50 kph. [austiwawa] did blow out a large number of motor controllers, but was finally able to obtain a beefier one which could handle the intense power requirements of this tricycle.
Be sure to check out the video below to see the trike being test driven. The build video is also worth a view for the attention to detail and high quality of this build. If you want to build your own but don’t want to build something this menacing, we have also seen electric bikes that are small enough to ride down hallways in various buildings, but still fast enough to retain an appropriate level of danger.
Continue reading “Electric Drift Trike Needs Water Cooling” →
Soft Rotating Pneumatic Actuators
When we think of pneumatic actuators, we typically consider the standard varieties of pneumatic cylinder, capable of linear motion. These can be referred to as “hard” actuators, made of rigid components and capable of great accuracy and force delivery. However, “soft” actuators have their own complementary abilities – such as being able to handle more delicate tasks and being less likely to injure human operators when used in collaborative operations. The Whitesides Research Group at Harvard University has undertaken significant research in this field, and released a paper covering a novel type of soft pneumatic actuator.
The actuator consists of a series of soft, flexible sealed chambers which surround a wooden dowel in the center. By applying vacuum to these various chambers, the dowel in the center can be pulled into up to eight different positions. It’s a unique concept, and one we can imagine could have applications in various material processing scenarios.
The actuator was built by moulding elastomers around 3D printed components, so this is a build that could theoretically be tackled by the DIYer. The paper goes into great detail to quantify the performance of the actuator, and workshops several potential applications. Testing is done on a fluid delivery and stirring system, and a tethered robotic walker was built. The team uses the term cVAMS – cyclical vacuum actuated machine – to describe the actuator technology.
The world of soft robotics is a hot bed of development, and we look forward to further work in this field. It’s not just Harvard, either – we’ve seen interesting work from Yale and from the Hackaday community too!
How To Stay Grounded When You Have Zero Potential
Ground is an interesting topic when it comes to engineering. Either it’s the reference level for a digital circuit (not necessarily at zero volts, either), or it’s the return path for current, or it’s the metal chassis, which shouldn’t be the return path for current or else something’s terribly broken. Erika Earl’s talk at this year’s Hackaday Superconference is all about ground.
The first type of ground to talk about is the ground in your outlets and walls. The AC safety ground is the third pin on your plug that should be attached to the chassis of your washer/dryer on one end, and somehow connected to the neutral wire somewhere near your breaker box. The theory of this being if a conductor touches the chassis of a lamp or appliance, all the current will go along that ground bus saving you from electrocution. It should also trip the circuit breaker.
But really we’re rarely dealing with mains power around here. When it comes to electronic design, we’re mostly dealing with analog grounds and digital grounds in circuits. Sometimes these are the same, sometimes they’re not, but they’re both usually referenced to 0 Volts, Add in some considerations for EMC, and ground loops, and you have an astonishing amount of knowledge wrapped up in having zero potential.
If you want to know about what ground actually is, this isn’t a talk to miss. Erika has tons of experience chasing down grounds as an audio engineer, and her career highlights including the director of hardware engineering at Slate Digital and the Senior Technical Engineer at LA’s legendary Village Recording Studios. There’s a lot of experience here, and if you want to where to find your ground, Erika is the person to ask.
My Oscilloscope Uses Fire
If you want to visualize sound waves, you reach for your oscilloscope, right? That wasn’t an option in 1905 so physicist [Heinrich Rubens] came up with another way involving flames. [Luke Guigliano] and [Will Peterson] built one of these tubes — known as a Rubens’ tube — and will show you how you can, too. You can see a video of their results, below. Just in case a flame oscilloscope isn’t enough to attract your interest, they are driving the thing with a theremin for extra nerd points.
The guys show a short flame run and one with tall flames. The results are surprising, especially with the short flames. Of course, the time base is the length of the tube, so that limits your measurements. The tube has many gas jets along the length and with a sound source, the height of the flames correspond to the air pressure from the sound inside the tube.
Continue reading “My Oscilloscope Uses Fire” →
