Color Your Workspace, Calm Your Mind
Every day, it seems to get harder and harder to relax and unwind. A person can only take so many lava-hot showers before they start cutting into work time. Listening to music is a wonderful option, but it can be difficult to find something to listen to that’s soothing without being disruptive. So what else can we try? Oh yes, blinkenlights. Frosted, glowing blinkenlights that bathe the room in color. Ahhhh.
There’s something about those enclosures that completes these so well. [ChrisParkerTech] used Alder wood sprayed with clear coat, which gives them a delightfully clean mid-century look. We also dig the lack of ceiling and unfinished top edge, because it gives the leaking light a bit of infinity pool mystique.
Of course, these wouldn’t be much of a relaxation tool if you have to get up up from your couch, chair, or bean bag every time you want to adjust them. Each strip is connected to a Wemos D1 mini, so [Chris] can control them with his phone via WLED, or make Alexa do it. Check out the build video after the break.
If you really love LEDs, don’t leave home without them. Show the world how you feel with a stylish LED hat.
Continue reading “Color Your Workspace, Calm Your Mind” →
Gaming In Different Languages
One of the perks of using older hardware is its comparative simplicity and extensive documentation. After years or decades of users programming on a platform, the amount of knowledge available for it can become extensive. This is certainly the case with the 6502 microprocessor, used in old Apple computers and some video game systems from the ’80s. The extensive amount of resources available make it a prime candidate in exploring various programming languages, and their advantages and disadvantage.
This project looks into those differences using a robot game, which has been programmed four different ways in three languages. [Joey] created the game in Python first and then began to port it to the 65C02, a CMOS variant of the 6502. The first iteration is its assembly language, and then a second iteration with optimized assembly code. From there, he ports it to C and then finally to Forth. Each version of the game is available to play in a browser using an emulator to run the 6502 hardware.
Since the games run in the browser, other tools are available to examine the way the game runs in each language. Registers can be viewed in real time, as well as the values stored in the memory. It’s an interesting look at an old piece of hardware and of its inner workings. For an even deeper dive into the 6502, it’s possible to build a working computer on breadboards using one.
Salvaged Drill Gets A Magnetic Upgrade
For most people, a broken tool is at the end of its useful life. But rather than toss a heavy-duty drill that had its handle broken off, [Workshop From Scratch] thought it was a perfect opportunity to create something new. In his latest video, he shows how he converted this old hand tool into a magnetic drill press with predictably impressive results.
Despite being assembled largely from pieces of scrap metal cut into shape with an angle grinder, we wouldn’t blame you for believing the end result was a commercial product. From the handles salvaged from chewed up old screwdrivers to the scratch-built rack and pinion assembly, the attention to detail here is really fantastic.
Removing what was left of the broken handle.
It’s difficult to pick a favorite detail, but the reinvented enclosure for the drill certainly ranks up there. [Workshop From Scratch] could have simply bolted on the tool as-is, but instead he surgically removed the vestigial handle to make it look as though the drill was always meant for this application. After cutting, it was finished off with some body filler, a bit of sanding, and a coat of his signature orange spray paint.
When he built his magnetic vise, [Workshop From Scratch] used magnets pulled from automotive air conditioning systems. They got the job done, but were somewhat annoying to work with given their round shape. This time around, he’s used off-the-shelf magnetic locks intended for steel doors. When energized with a 19 V laptop power supply, he says the three rectangular electromagnets have a combined pull of 540 kilograms.
If you don’t have a broken drill to use as a donor for this type of project, don’t worry. You could always use a salvaged hoverboard motor instead.
Continue reading “Salvaged Drill Gets A Magnetic Upgrade” →
RC Car Becomes Useful Little Mower
When we think of lawn mowers, our first thought is of heavy, rusty old machines that take the best part of an afternoon to get started. Of course, there’s always another way, as [Mark] ably demonstrates with his own build.
Beginning from an unconventional starting point, [Mark] chose a remote control car, of the type that can flip and drive in both orientations. Having lost the controller, he started by ripping out the original electronics. In its place, an ESP32 receives signals from a FlySky RC receiver, and runs the drive motors with a Sparkfun Monster Motor Shield. Another channel on the receiver is hooked up directly to a drone speed controller driving a brushless motor, outfitted with a sawblade to cut the grass.
It’s a small platform, and one that ordinarily you might doubt could do the job. However, for [Mark]’s purposes, the rig works just fine, and has been doing good work for the last two years! We’ve seen mowers hacked before too, like this autonomous rig out in the wild. Video after break.
Continue reading “RC Car Becomes Useful Little Mower” →
Bantam Tools PCB Mill Gets A Ferocious New Sequel
When the first Bantam Tools’ Milling Machine landed, it put PCB prototyping at the forefront with a smooth software and hardware pipeline for spinning out circuit boards in a manner of minutes. Now the folks at Bantam Tools are back, putting those insights into a new machine that makes cutting aluminum a first class feature. While machine details are still sparse from their announcement page, knowing that Bantam Tools has spent a few years turning classrooms of students into hardware prototypes reassures us that we’re in good hands. Now let’s spill some beans on this beast. Continue reading “Bantam Tools PCB Mill Gets A Ferocious New Sequel” →
Marian Croak Is The MVP Of VoIP Adoption
If you’ve ever used FaceTime, Skype, own a Magic Jack, or have donated money after a disaster by sending a text message, then you have Marian Croak to thank. Her leadership and forward thinking changed how Ma Bell used its reach and made all of these things possible.
Marian Croak is a soft-spoken woman and a self-described non-talker, but her actions spoke loudly in support of Internet Protocol (IP) as the future of communication. Humans are always looking for the next best communication medium, the fastest path to understanding each other clearly. We are still making phone calls today, but voice has been joined by text and video as the next best thing to being there. All of it is riding on a versatile network strongly rooted in Marian’s work.
Continue reading “Marian Croak Is The MVP Of VoIP Adoption” →
Magnetic Couplings Make This Lego Submarine Watertight
Although you’d be hard-pressed to tell in some areas, it’s summer in the northern hemisphere, which always seems to bring out the projects that require a swimming pool for adequate testing. The [Brick Experiment Channel]’s latest build, a submersible made almost entirely from Lego, is one such project and has us pining for weather that makes a dip sensible rather than suicidal.
The sub featured in the video below is a significant improvement over the “Sub in a Jug” approach the [Brick Experiment Channel] favored for version 1. Rather than starting with a vessel specifically designed not to hold water, the hull for this vessel is an IKEA food container, with a stout glass body and a flexible lid with silicone seals. And instead of penetrating the hull for driveshafts and attempting to seal them, this time around he built clever magnetic couplings.
The couplings transmit torque from the motors on the inside to gears and props on the outside. And where the first version used a syringe-pump ballast tank to control the depth, this one uses vertical thrusters. The flexible lid proved to be a problem with that scheme, since it tended to collapse as the depth increased, preventing the sub from surfacing. That was solved with some Lego bracing and adjustment of the lead shot ballast used to keep the sub neutrally buoyant.
This looks like a ton of summer fun, and even if you don’t have Legos galore to work with, it could easily be adapted to other materials. There are a ton of other fun [BEC] Lego builds to check out, some of which we’ve covered, including a Lego drone and a playing card shooter.
Continue reading “Magnetic Couplings Make This Lego Submarine Watertight” →
