Restoring Apple’s Terrible But Awesome IBook Laptop
Before the Apple MacBook there was the Apple iBook, fruity 1999 colors included. These PowerPC-based laptops targeted low-cost PC-compatible laptops much like the iMac did, albeit it the latter with more success. That said, these laptops are said to be a nightmare to repair, so when [This Does Not Compute] got his hands on a shiny first generation, 300 MHz PowerPC powered, tangerine-colored one, he somewhat dreaded trying to fix it.
Aside from some relatively minor cosmetic issues such as typical cracks in the plastic and a missing optical drive door it seemed in good condition. The first issue came on boot, when MacOS 9.0 would throw up an error message about an issue with cache memory. After booting into the OS this cache memory did indeed show up as missing. Next issue was the optical drive doing absolutely nothing and restarting leading to the system locking up and not starting until plugging in the power adapter.
Fortunately the optical drive started working after addressing a software issue, but the power and cache issues were concerning. Cue a long troubleshooting and repair session that involved purchasing a ‘parts unit’ from Japan to merge both into a single iBook with hopefully a working system at the end.
Along the way the reason why people dislike maintaining these systems, as to do something like getting to the hard drive requires removing the entire display. The cause for the first iBook’s problems also seemed to be due to a liquid spill of some type, as on boot there was no chime either, indicating a wider board-level issue. Unfortunately this was left further undiagnosed and the Japanese mainboard used instead. It’d be interesting to see the deeper cause, but most likely the mainboard will be used for components.
Continue reading “Restoring Apple’s Terrible But Awesome IBook Laptop” →
After The Dust Settles: Building Pebble Apps
For a piece of wearable technology, Pebble has had a fairly “rocky” history. One of the most successful Kickstarters of its era, it went on to get acquired by FitBit, quietly shelved by them, then acquired by Google and open-sourced, where it’s now somewhat back in the hands of its original creator. Its new open source nature means that regular people can develop for these popular watches again, and [Coconauts] have developed a guide for these watches, new and old.
The original watches had to be coded using C, which is a fundamental language but one that generally isn’t used much in the modern world outside of embedded systems and other areas where efficieny is important. C does much less hand-holding than modern languages, so there are a number of things to keep an eye on when coding for these watches that languages like Rust, Go, and Python handle on their own. Regardless, the two-person team recently built a pair of apps for the Pebble platform as part of an app-making contest, one which notifies the user that the watch is charged to 80%, and another that shows an interactive kitten on the watch’s face.
Both of the apps are available from the Pebble app repository, and from there the source code can be found on respective GitHub pages if you’re looking for some examples to dust off old C skills. If you happen to have an old Pebble watch or always wanted one but didn’t want to deal with FitBit, now might be a good time to get them out and start tinkering around with it since it’s now in the open-source domain.
Bilingual E-paper News Feed Helps Brush Up Language Skills
[Bob] recently completed LanguageLearner, a desktop device that increases his exposure to a second language by offering up bite-sized news items in Italian, with a complementary English translation. Even better, it’s a project made almost entirely from inexpensive parts he had on hand; it consists of little more than a Raspberry Pi Pico W, a 4.2″ E-paper display, and a 3D-printed stand.
Here’s how it works: once every few hours, the system wakes up and uses its WiFi connection to fetch news from an Italian RSS feed. Having chosen a slice of current events, it translates to English with an API call then displays both versions on the display: original Italian up top, translated English below.
Consisting of little more than a Raspberry Pi Pico W, an E-paper display, and a 3D-printed stand, it’s a great use of spare parts.
E-paper is ideal for a semi-passive project like this because once data is written to the display, there it remains without needing power or upkeep of any kind. Perfect for a device that only wakes up every few hours for an update before going right back to sleep.
Due to the limited RAM of the Raspberry Pi Pico [Bob] has to be purposeful about fetching data, so he relies on text from a simple RSS feed to avoid running out of memory while making web requests. The other minor quibble is that the driver for the display only handles plain ASCII; characters that cannot be rendered are displayed as grey boxes, which you can see in the image up top. Still, it gets the job done.
Increasing exposure to a language one is learning is beneficial, and people like to experiment. From trying to optimize human wait times by inserting language micro-lessons to a calculator that works in Toki Pona, technology offers new ways for folks to experiment with how we learn and play with language.
On The Wisdom Of Replacing A NiMH Module In A Prius Battery Pack
Old versus new Prius NiMH module. (Credit: HubNut, YouTube)
It’s possible to get a pretty good deal on used Toyota Prius cars, but as with all hybrid cars that also means a used battery pack and resulting issues. In the case of the Gen 2 Prius that [HubNut] recently acquired it was clear that its battery was effectively toast, with the engine running constantly and the car often giving up due to detected issues with the pack. After getting to an EV-focused garage for repairs, a spare NiMH module was used to replace a problematic module to bring it back to good health, while raising the question of how sensible such a repair is.
Certainly, compared to the average BEV where a much larger battery is generally integrated well into the frame, a Prius makes things very easy, with the compact battery readily accessible and removable from the trunk. It is also a very modular battery, with some elbow grease and bolt-twisting enough to disassemble it.
Even with that it still a high-voltage battery with all the associated risks, and as raised in the comments there’s a big question about putting a new(er) cell into a pack with more worn-out NiMH cells as generally the cells wear out fairly evenly. While this fix can give the pack some more life, the new cell won’t match the internal resistance and other parameters of the pack, leading to issues like voltage drift. Then there’s the issue that if one cell failed, others probably aren’t far behind, so this hack would soon become a regular ritual.
Much like swapping one bad 18650 Li-ion cell in a bigger battery, it’s probably a more sustainable solution to simply replace the entire battery at once, or at least replace all modules or cells to properly refurbish it. For [HubNut] this fix suffices because he suspects that this pack was already assembled from random modules, it’s an important consideration to make if you don’t enjoy ending up stranded during a trip.
Continue reading “On The Wisdom Of Replacing A NiMH Module In A Prius Battery Pack” →
Know Your Food: Cheesemaking
There’s a thing that people who grew up on farms all share: a connection with food production that isn’t some mystical rose-tinted woo from a TV chef, but instead a practical general knowledge from being there on the ground. A glance at a crop in a field and you immediately recognise what it is, if it’s ploughing time you’ll know the soil type, and there’s always either too little, or too much rain. For a given foodstuff you’ll know far too much about where it came from, because if your dad wasn’t involved in its production, the chances are someone he knew was. You take this for granted, after all doesn’t everyone have this general knowledge? Seemingly not.
Hackaday is not a cooking channel, but I know we’re all interested here in how things are made. Shouldn’t that also extend to what we eat? It’s fashionable to follow a back-to-nature line that all commercial foodstuffs are somehow over-processed junk, but without the requisite knowledge you’re flying blind there. To know both how common foodstuffs should be made, as well as how they are made industrially, should be an essential for everyone.
Continue reading “Know Your Food: Cheesemaking” →
Like A Wire Bender, But For Pop Tubes
Are you familiar with pop tubes? Resembling the corrugated section of a bendy straw, they are at the core of PopTuber, an intriguing research project from the Actuated Experience Lab at the University of Chicago.
With five motors and specialized gears a pop tube can be formed into complex, arbitrary shapes, and just as easily reset.
PopTuber shows how five motors and some specialized gears are all it takes to bend pop tubes into complex and stable 3D shapes. One can design the shapes in software, feed a pop tube into the shaper, and watch the device do the work. Importantly, the device can just as easily reset and re-use the tube. Watch the video (embedded below the page break) to see it in action and get a feel for what it can do.
In concept, it’s a little like a wire-bending machine, although wire benders are bulkier in comparison, more complex to scale, and unbending a wire is a separate process with its own hardware.
This project explores possibilities for a machine that can crank out complex curves on demand, such as oddball user interfaces, physical prototyping, and even a strange sort of physical display. But the real forward-thinking and interesting question researchers asked is whether this idea could be a form of programmable matter. The project shows that five actuators in a relatively compact package are all that’s needed to shape (and reset) a pop tube of arbitrary length in a programmable way, and it can scale easily to different sizes.
Continue reading “Like A Wire Bender, But For Pop Tubes” →
Revisiting Making Your Own Internet Router In 2026
After my recent misadventures setting up an OpenWrt installation on a scruffy e-waste-level x86 PC, quite a few people chimed in with feedback, criticism and friendly hostility regarding things like a presumed ‘x86 bias’. There were also some system-related things that simply didn’t seem to want to work, such as booting from an SD card with a USB adapter, which cut short a lot of the actual OpenWrt testing that I had intended. This made it mostly an enlightening look at what issues you can run into when ‘quickly’ throwing an OpenWrt router together with some junk parts these days.
In this second article I’ll try to address as many of these points as possible, as well as attempt to show off an actual working OpenWrt installation in action. In addition, since just using random junk x86 PC parts was the way to go back in the late 90s/early 2000s doesn’t mean that this is still the way in 2026, so I’ll be taking a look at alternatives that exist today. This includes everything from mini PCs, to ancient business PCs being sold for peanuts, as well as more dedicated (ARM-based) hardware solutions.
Continue reading “Revisiting Making Your Own Internet Router In 2026” →
