Smooth Moves From Cheap Motors
Building an electric motor isn’t hard or technically challenging, but these motors have very little in the way of control. A stepper motor is usually employed in applications that need precision, but adding this feature to a motor adds complexity and therefore cost. There is a small $3 stepper motor available, but the downside to this motor is that it’s not exactly the Cadillac of motors, nor was it intended to be. With some coaxing, though, [T-Kuhn] was able to get a lot out of this small, cheap motor.
To test out the motors, [T-Kuhn] built a small robotic arm. He began by programming his own pulse generating algorithm that mimics a sine wave in order to smooth out the movement of the motor. An Arduino isn’t fast enough to do these computations, though, so he upgraded to using the ESP32. He also was able to implement the inverse kinematics on his own. The result of all this work for a specific platform and motor type is a robotic arm that has a very low cost but delivers performance of much more expensive hardware.
The robot arm was built by [T-Kuhn] too, and all of the details on that build, as well as all the schematics and code, are available on the project site if you need a low-cost robot arm or a good stepper motor controller for a low cost. There are many other ways of getting the most out of other types of low-cost motors as well.
Continue reading “Smooth Moves From Cheap Motors”
How’s A Gyro Work?
It wasn’t long ago that a gyro — or gyroscope — was an exotic piece of electronics gear. Most of us only saw them as children’s toys that would balance on your finger. That’s changed, though, thanks to microelectronics. Now your game controller, your phone, and your drone all probably use little ICs that are actually three-axis gyroscopes. Ever wonder how they work and what they do? [RCModelReviews] has a video that covers three kinds of gyros: old mechanical gyros, modern MEMS gyros, and even an exotic laser-based gyro. (YouTube, embedded below.)
Gyroscopes allow you to detect orientation by detecting linear forces on a rotating element. They are used in everything from spacecraft to submarines. The device has many origins dating back to antiquity. But the modern gyro showed up around 1800 or so. The children’s toy appeared in 1917 and is still made today.
Continue reading “How’s A Gyro Work?”
Magnets And Printed Parts Make Quick-Disconnect Terminals
The Apple MagSafe power connector is long gone from their product line, but that doesn’t mean that magnetic connectors aren’t without their charms. It just takes the right application, and finding one might be easier with these homebrew magnetic connectors.
We’ll admit that the application that [Wesley Lee] found for his magnetic connectors is perhaps a little odd. He’s building something called Linobyte, a hybrid art and electronics project that pays homage to computing history with very high-style, interactive core memory modules. The connectors are for the sense wire that is weaved through the eight toroids on each module, to program it with a single byte. Each connector has a 3D-printed boot that holds a small, gold-plated neodymium magnet with the sense wire soldered to it. A socket holds another magnet to the underside of a PCB. The magnet in the boot sticks to the PCB and makes contact with pads, completing the circuit. We know what you’re thinking: heating a magnet past the Curie point is a great way to ruin it. [Wesley] admits that happens, but it just makes the connection a little weaker, which works for his application. The short video below shows how he puts them together.
We can think of a couple of ways these connectors would be useful, and we really like the look of the whole project. It’ll be interesting to see where it goes, but in the meantime, brushing up on how magnets work could be fun. Continue reading “Magnets And Printed Parts Make Quick-Disconnect Terminals”
Testing cooling with transformer oil
Measuring The Cooling Effect Of Transformer Oil
Transformer oil has long served two purposes, cooling and insulating. The large, steel encased transformers we see connected to the electrical grid are filled with transformer oil which is circulated through radiator fins for dumping heat to the surrounding air. In the hacker world, we use transformer oil for cooling RF dummy loads and insulating high voltage components. [GreatScott] decided to do some tests of his own to see just how good it is for cooling circuits.
Thermal measurement resultsHe started with testing canola oil but found that it breaks down from contact with air and becomes rancid. So he purchased some transformer oil. First, testing its suitability for submerging circuits, he found that he couldn’t see any current above his meter’s 0.0 ÎĵA limit when applying 15 V no matter how close together he brought his contacts. At 1 cm he got around 2 ÎĵA with 230 VAC, likely from parasitic capacitance, for a resistance of 115 Mohm/cm.
Moving on to thermal testing, he purchased a 4.7 ohm, 100 watt, heatsink encased resistor and attached a temperature probe to it with Kapton tape. Submerging it in transformer oil and applying 25 watts through it continuously, he measured a temperature of 46.8°C after seven minutes. The same test with distilled water reached 35.3°C. Water’s heat capacity is 4187 J/kg∙K, not surprisingly much better than the transformer oil’s 2090 J/kg∙K which in turn is twice as good as air’s 1005 J/kg∙K.
He performed a few more experiments but we’ll leave those to his video below.
We’ve run across a number of tests running boards submerged in various oils before. For example, we’ve seen Raspberry Pi’s running in vegetable oil and mineral oil as well as an Arduino running in a non-conductive liquid coolant, all either overclocked or under heavy load.
Continue reading “Measuring The Cooling Effect Of Transformer Oil”
Foam Airboat Is Cheap RC Fun
Archer fans and residents of Louisiana will already be familiar with the concept of the airboat. Put a powerful engine running an aircraft prop on a flat-bottomed hull, and you’ve got an excellent way to traverse the marshes of the American South. While a fully-fledged airboat might run you the best part of $100,000, this no-frills radio-controlled version is great fun at a much lower price.
The hull is built on a sheet of foam, which is cheap, readily available, and suitably buoyant for the task. It’s then kitted out with a brushless motor to run the prop and a servo to control the rudder. Lace it up with a radio receiver and speed controller and you’re good to go.
The build could readily be completed in well under a couple of hours, and is a great one to tackle with kids due to its mechanical simplicity. There’s room for extra creativity too – you can always substitute a watermelon if you’re feeling peckish. Video after the break. Continue reading “Foam Airboat Is Cheap RC Fun”
Smell Tech over Internet Wide
Researchers Seek To Create The Digital Smell Interface
We hear digital audio, we see digital video, and we feel digital haptic feedback. However, we don’t have an analog for the sense of smell. [Kasun] and his team of researchers from the Imagineering Institute in Malaysia are in the midst of changing that reality. Their project aims to transmit fragrances via electronic stimulation. Though it’s really more of a step toward creating a multi-sensory internet.
The team’s “electric smell machine” consists of a variable power supply connected to silver electrodes wrapped around an endoscopic camera. The camera is necessary to ensure contact with the user’s olfactory bulb as electric current pulses through the electrodes. The current values vary based upon the scent being replicated and are in the 0.2mA neighborhood. Early trials of the machine have revealed that around one-quarter of test subjects are able to identify the smells being replicated. They reported smells being fruity, sweet, and woody though all had a chemical-like odor attached.
The concept of “smell-o-vision” is not a new one, as it has been around longer than motion pictures with sound. Previous attempts at accompanying film and television with scent have been a result of chemical reactions. Devices from these types of experiments typically involved cartridges that would need to be replaced when the chemical substances were depleted. [Kasun]’s team approach is to avoid the chemical approach in favor of directly stimulating the olfactory receptors. Those interested in the gritty details can read the research paper on digitizing smell.
[Kasun] and his team uploaded a video on the project that you can view below. It’s all a work in progress at this point, but sign me up for a trial when they pinpoint the true essence of new car smell.
Continue reading “Researchers Seek To Create The Digital Smell Interface”
An In-Depth Look At Dexter, The Robotic Arm
Dexter, a really great robot arm project, just won top honors in the 2018 Hackaday Prize, and walked away with $50,000 toward continuing their project. As a hat tip to Hackaday and the community, Haddington Dynamics, the company behind Dexter, agreed to open-source their newest version of Dexter as well. As James Newton said when accepting the trophy during the award ceremony, “because of your faith in us, because of this award, we have been moved to open-source the next generation of Dexter.” Some very clever work went into producing Dexter, and we can’t wait to see what further refinements have been made!
Dexter isn’t the only robotic arm in town, by any means. But in terms of hobbyist-level robotics, it’s by far the most complete robot arm that we’ve seen, and it includes a couple of design features that make both its positional accuracy and overall usability stand out above the rest. This is a robot arm with many of the bells and whistles of a hundred-thousand dollar robot, but on a couple-thousand dollar budget. Continue reading “An In-Depth Look At Dexter, The Robotic Arm”
