How To Make Bisected Pine Cones Look Great, Step-by-Step
[Black Beard Projects] sealed some pine cones in colored resin, then cut them in half and polished them up. The results look great, but what’s really good about this project is that it clearly demonstrates the necessary steps and techniques from beginning to end. He even employs some homemade equipment, to boot.
Briefly, the process is to first bake the pine cones to remove any moisture. Then they get coated in a heat-activated resin for stabilizing, which is a process that infuses and pre-seals the pine cones for better casting results. The prepped pine cones go into molds, clear resin is mixed with coloring and poured in. The resin cures inside a pressure chamber, which helps ensure that it gets into every nook and cranny while also causing any small air bubbles introduced during mixing and pouring to shrink so small that they can’t really be seen. After that is cutting, then sanding and polishing. It’s an excellent overview of the entire process.
The video (which is embedded below) also has an outstanding depth of information in the details section. Not only is there an overview of the process and links to related information, but there’s a complete time-coded index to every action taken in the entire video. Now that’s some attention to detail.
Continue reading “How To Make Bisected Pine Cones Look Great, Step-by-Step”
New Part Day: Mapping With RealSense Cameras For $200
Robot cars, DIY or otherwise, are hot right now. To do this right, you’re going to need cameras, LIDAR, or some other way of sensing the the world. Intel is again getting into the fray with a RealSense tracking camera for simultaneous localization and mapping for robotics, drone, and augmented reality needs.
The tech specs for the Intel RealSense T265 are impressive for small robotics uses. It includes 6DoF tracking gathered by two cameras, each with a 170° FoV. Connection to a computer is through USB 2.0 or 3.0. If you want to get an idea of how seriously Intel is taking the ‘robotics, and other power- and weight-limited platforms’ market, here’s a sample of what is on the one-page spec sheet: the T265 only uses 1.5 Watts, weighs 55 grams, and is 108 x 25 x 13 mm. There are also two M3 taps spaced 50mm apart on the back, which is an astonishing spec to publish on the product landing page. Simply the fact that the location and dimensions of the mounting holes is so prominent gives you an idea of how seriously Intel is taking robotics and prototyping applications.
This new SLAM camera complements Intel’s other tracking camera offerings, including those we’ve seen at Maker Faires past. It’s a competitor to the new crop of solid state LIDAR modules we’ve seen pop up recently. It’s not a Kinect, but we’re years past using a first-gen Kinect for robotics applications. Now, everything is custom chips and SLAM processing, and the RealSense T265 is the smallest platform to do that now.
Hackaday Links Column Banner
Hackaday Links: February 10, 2019
Last month was NAMM, the National Association of Musical Something that begins with ‘M’, which means we’re synthed and guitarded out for the year. The synth news? Behringer are making cheap reproductions and clones of vintage gear. There’s something you need to know about vintage gear: more than half of everything produced today has a Roland 808 or 909 drum machine (or sample), a 303 bass synth, or a 101 mono synth in it. Put an 808, 909, 303, and 101 on the same table, connected to a mixer, and you can make most of the electronic music from the ’80s and ’90s. And Behringer is cloning these synths. Neat times. But there’s a problem: Roland is trademarking these drum machines and synths, with trademark filings in the US and Germany. These are ‘trade dress’, or basically the beautiful red, orange, yellow, and white buttons of the 808 and the digital cyber silver plastic aesthetic of the 303, but there you go. It’s round one in the Roland v. Behringer match, may the first person to give me an 808, 909, 303, and 101 for a thousand dollars win.
Synths? Sure thing. Here’s a stash of New Old Stock 8580 SID chips, the ‘synth on a chip’ found in the Commodore 64. The price? $50. [ben] bought one of these, and the card that came with it said,  “We purchased these chips in 2006 and they’ve been stored in our climate-controlled storage area ever since. Even still, we found a handful of them that didn’t pass testing. Treat them with care!” Yes, a bunch of SID chips for sale is noteworthy, but at $50 a piece for 1980s technology, can someone explain why a chip fab isn’t cranking these things out? If there’s one ancient piece of silicon where the demand meets what it would cost to spin up the silicon line, the SID is it. Where are the modern reproductions?
Excited about making an electronic badge this year? Seeed is offering badge sponsorships for 2019, with an offer of a 5% discount on PCBA, and a 10% discount if you put the Seeed logo on the board. I might be a little biased, but Seeed is a place where you can just ask, “hey, you guys do clear soldermask?” and they find a way to do it.
The best way to tell if someone is rich isn’t by seeing if they have an i8 parked outside their mansion, or just a piece of junk with an M badge. It isn’t whether or not their filet mignon is wagyu or just Kobe, and it isn’t if they’re cruising the skies in a G650 or just puttering around in a Cessna Citation. No, the best way to tell if someone is rich is to notice their AirPods. Yes, Apple’s wireless headphones (which are actually pretty good!) are the best foundation of a class division these days. The best class signal since private railroad cars now has a problem: people are printing their own AirPods. [Brady32] over on Thingiverse has modeled AirPods, and now the design is being given away for free. The horror. Now anyone can print out their own little bits of white plastic, stick them in their ears, and tell the world, ‘I’m better than you. Don’t bother talking back, because I obviously can’t hear you.’
Raspberry Pi has a store! Yes, everyone’s favorite single board computer now has an ‘experimental space’ in Cambridge’s Grand Arcade. The Beeb is saying this store is ‘bucking the retail trend’, yes, but any retail trend doesn’t really apply here; brands have storefronts, and it’s not about revenue per square foot. Makerbot had a store, and it wasn’t about selling printers. Microsoft has stores. Sony built a mall to advertise the original PlayStation. While the Raspberry Pi brick and mortar store will probably never make any money, it is an indication the Raspberry Pi foundation has built a valuable brand worthy of celebration. Here’s some pics of the store itself.
Did you know Hackaday has a retro edition? It’s true! retro.hackaday.com is a lo-fi version of Hackaday without CSS or Javascript or any other cruft. It’s hand-written HTML (assembled by a script) of the first ten thousand or so Hackaday posts. The idea is that old computers could load the retro site, just to prove they could. [Matthias Koch] has an Atari PC3 — Atari’s PC compatible with an 8088 running at 8Mhz, 640k of RAM and a 20 MB hard drive — and got this thing to pull up the retro site. Good work!
What is the current state of 3D printing? What is the current state of 3D printing videos on YouTube? Oh boy we’re going to find out. [Potent Printables] did an ‘analysis’ of 3D printing videos published to YouTube, and found the category riddled with ‘clickbait’, without giving an operational definition of what ‘clickbait’ actually is, or how it’s different from any other content (because who would make a video that doesn’t have the purpose of attracting viewers) Anyway, there’s a problem with the YouTube algorithm, and 3D printing blogs are copying it, filling the entire hobby with disillusioned beginners, or something. After defining ‘The Most Viewed’ as not being a news or documentary footage (okay, that’s fair), having at least three printing videos, not clickbait, and gives the designer proper attribution, [Potent Printables] found a list filled with [Maker’s Muse], [3D Print Guy] and other channels who do 3D printing work, but don’t put 3D printing in the title. This is great; 3D printing isn’t a fascinating new technology that’s the first step towards Star Trek replicators; we’ve slid down the trough of disillusionment and now 3D printers are just tools. It’s great, and in 2018 things are as they should be.
Make Your Lego Fly
We probably all used to make our Lego fly by throwing it across the room, but Flite Test have come up with a slightly more elegant solution: they converted a Lego quadcopter to fly. They did it by adding a  miniature flight controller, battery and motors/rotors to replace the Lego ones in the Lego City Arctic Air Transport kit. This combination flies surprisingly well, thanks to a thoughtful design that balances the heavier components inside the case.
Continue reading “Make Your Lego Fly”
There Are 200 Electronic Kits In That Box
If you grew up in the latter part of the 20th century, you didn’t have the Internet we have today — or maybe not at all. What you did have, though, was Radio Shack within an hour’s drive. They sold consumer electronics, of course, but they also sold parts and kits. In addition to specific kits, they always had some versions of a universal kit where lots of components were mounted on a board and you could easily connect and disconnect them to build different things. [RetoSpector78] found a 200-in-1 kit at a thrift store that was exactly like the one he had as a kid and he shares it with us in the video below.
This was a particularly fancy model since it has a nice looking front panel with a few knobs and displays. The book shows you how to make the 200 different projects ranging from metronomes to rain detectors. The projects really fell into several categories. There were practical circuits like radio receivers, test equipment, and transmitters. Then there were games or circuits even the manual called “silly.” In addition, there were circuits to build simply to understand how they work, like flip flops or counters.
Continue reading “There Are 200 Electronic Kits In That Box”
This 3D Printed LED Softbox Really Shines
Generally speaking, objects made on desktop 3D printers are pretty small. This is of course no surprise, as filament based printers are fairly slow and most don’t have very large beds to begin with. Most people don’t want to wait days for their project to complete, so they use 3D printed parts where it makes sense and supplement them with more traditional components such as aluminum extrusion wherever possible. But not always…
This 3D printed photography softbox created by [Nicholas Sherlock] doesn’t take the easy way out for anything. With the exception of the LEDs and the electronics to drive them, everything in the design has been printed on his Prusa i3. It wasn’t the easiest or fastest way to do it, but it’s hard to argue with the end result. Perhaps even more impressive than the final product is what it took to get there: he actually had to develop a completely new style of part infill he’s calling “Scattered Rectilinear” to pull it off.
Overall the design of the light itself isn’t that complex, ultimately it’s just a box with some LEDs mounted at the back and a pretty simple circuit to control their intensity. The critics will say he could have just used a cardboard box, or maybe wood if he wanted something a little bit stronger. But the point of this project was never the box itself, or the LEDs inside it. It’s all about the diffuser.
[Nicholas] forked Prusa’s version of Slic3r to add in his “Scattered Rectilinear” infill pattern, which is specifically designed to avoid the standard “ribs” inside of a 3D printed object. This is accomplished with randomized straight infill passes, rather than the traditionally overlapped ones. The inside of the print looks very reminiscent of fiberglass mat, which is perhaps the best way to conceptualize its construction. In terms of the final part strength, this infill is abysmal. But on the plus side, the light from the LEDs passing through it emerges with a soft pleasing look that completely obscures the individual points of light.
Anyone with a big enough 3D printer can run off their own copy of his light, as [Nicholas] has released not only his forked version of Slic3r but all of the STL files for the individual components. He’s also put together an exceptionally well documented Thingiverse page that has instructions and detailed build photos, something that’s unfortunately very rare for that platform.
If you’re in the market for a DIY softbox and don’t have a 3D printer handy, fear not. We’ve covered a few that you can build with more traditional methods, as well as several tips and tricks which you can use to get the most out of your photos and videos.
Automated Radiosonde Tracking Via Open Source
Meteorological organisations across the world launch weather balloons on a regular basis as a part of their work in predicting whether or not it will rain on the weekend. Their payloads are called radiosondes, and these balloons deliver both telemetry and location data throughout their flightpath. Hobbyists around the globe have devoted time and effort to tracking and decoding these signals, and now it’s possible to do it all automatically, thanks to Radiosonde Auto RX.
The basis of the project is the RTL-SDR, everyone’s favourite low-cost software defined radio receiver. In this case, software is used to first hunt for potential radiosonde signals, before then decoding them and uploading the results to a variety of online services. Some of these are designed for simple tracking, while others are designed for live chase and recovery operations. Currently, the software only covers 3 varieties of radiosonde, but the team are eager to expand the project and have requested donations of other radiosondes for research purposes.
The team recently conducted a talk at linux.conf.au regarding the project, which goes into detail as to the decoding and tracking of the radiosonde data. If you’re eager to try it out, download the software, fetch your TV dongle and get cracking. You might also consider tracking cubesats while you’re at it. Video after the break.
via [crazyoperator], thanks to Slds Ernesto for the tip!
Continue reading “Automated Radiosonde Tracking Via Open Source”
